Cyclocross For Trade Thread
#151
Have:
NEW 6600 Ultegra shifters (set)
NEW 6600 Ultegra shifter (left/front only)
Used Dura Ace 7800 left shifter
Sidi Dominator (4 i believe) mtb shoes size 40
various oval stems/bars
various 9/10 sp cassets
Want:
Rival or up sram shifters
44/446t chainring for sram compact cranks 110bcd
maybe some other sram drive train components
Want:
#152
L-time Cat4 & proud of it
Bikes: There's 4... 1 of ea
I have a T34 and an Elite 34c (red) that have been run for a bit but have lots of life left.
For those that are thinking single ring: I have a pair of Specialized cold-forged cranks (170mm) with a 42t inner ring. Outer ring has had the teeth ground off to make a chain guard. 144mm BCD (track: so you can find almost any ring you want to 55t) Square taper. Have a few of the square taper BBs to go with it too!
Need: 1 x Fango or Grifo in 32-34c, 28h hubs (D/A or XTR), 10sp cassettes, etc
#153
kdboxerdog
2007 Specialized Tricross frameset XXL. No damage, no dings or dents. Couple paint scuffs and/or chips.
Trade for similar framset in L or about a 56cm, Tubular wheelset, or ??? whatcha got?
#154
Embracing my inner Fred
Bikes: Early 90s Specialized Epic Pro carbon/DA
Have: 2008 Fuji Cross Comp 54cm frameset. Lightly used, raced maybe five times. It's too small, so I'm looking for a 58cm frameset.
This frame is the really fast blue/white color combination.
#155
I have a pair of Low Mileage Kenda Small Block 8 in 35
I could use a Velocity Escape 32 hole rim or similar 32 hole tubular rim.
A pair of more all round CX tires
An Arione or Selle SLR in useable but non mint shape (could trade an OG Flite for one of these)
#156
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Scrub, also check out the velocity Major Toms. A 23mm wide version of the escapes.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
#157
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Have:
Tubular Wheels and Tires - Shimano 600 (tricolor) rear hub laced to unknown aero rim and Campy front hub laced to Sun Mistral aero rim. Both rims show no wear and are true and tensioned. The tires are Tufo T34 Pro's and in excellent shape.
Need: SRAM force crank or something equivalent.
The wheels and tires were my spare set this year and only saw a practice lap or two. I got them for mud wheels due to the aero shape of the rims but we had mostly dry conditions this year.
I'm pretty flexible on this, PM me if you have other ideas.
#158
The major toms are too wide since my clincher rim is an open 4 CD. Also my Pompino doesn't have the best clearance in the rear and which may be worse with the wider profile rim. I test mounted the front wheel I got (GP4) with the Tufo T34 and inflated it but it only measured out to about 32 on my calipers, does that seem right?
#159
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I'll measure mine when I get home. I should be able to get some garage time tonight.
Also, I doubt that rim width would effect the tire width and create clearance issues but i'll let others chime in on that. I may have a couple of tubular rims sitting around. I'll look at that too tonight.
#160
Update: Found a Redline Conquest Team frame, now I just need to get rid of the Fuji.
#161
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
@ Scrub, I measured both my T34pro's and they are 33-34mm at 40 lbs pressure. If you are looking for a matching GP4 rear wheel, I have an old campy freewheel hub laced to one. Just needs respacing and redishing to make it a great SS tubie.
#162
Looking for BB7 disk brakes for road lever.
Have:
Dura ace & ultegra cranks, both integrated spindle, w/single 42 ring & outer guard. 172.5mm
Campy record 10 sp levers x 2 sets
bunch of 9sp 12/27 cassettes, some DA some ult.
Ult & DA rear der; I think da is 9sp & ult 10sp.
Tektro CR720 brake set F & R
Sram Red 172.5mm cranks w/no rings, GXP (NON BB30).
Have:
#163
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Availpunk, Is that Red crank the GXP model or BB30?
#164
I have some miscellaneous wheels and forks folks might be interested in.
-One old (late seventies, early eighties?) front Record hub laced to a Mavic tubular rim of unkown make. It is missing half of the sticker so I don't know which model. It is very low profile and polished silver. It is true and has what looks like the original QR. And an old road tire still glued up that doesn't hold air.
-Rear Ultegra 6600 hub to Salsa Delgado Cross rim, 32h. Used but tons of life left. Hub has been maintained and spins great. Perfectly true. Some scuffs on the quick release from laying the bike down (oops).
-Front Tiagra hub to WTB something or other touring rim. Heavy but bomber.
- Nashbar/Winwood carbon fork but it is missing the canti bosses including the little plastic pieces this fork uses for the return springs. So disc only unless you can track those parts down. Some paint chips on the aluminum crown.
-Kona P2 700c canti steel fork. Like what used to come on the Jake.
I want cross or maybe road tires, canti brakes, high quality singlespeed cogs,fixed gear cogs, geared drivetrain parts, maybe 130 bcd chainrings, 29er wheels/tires, but open to other stuff.
Also I will be in the Portland area for the next month. It is always nice to avoid shipping...
#166
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
PM sent.
#167
Señor Member
Bikes: Bedford, IF, Hampsten, DeSalvo, Intense Carbine 27.5, Raleigh Sports, Bianchi C.u.S.S, Soma DC Disc, Bill Boston Tandem
Found.
#169
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have a 48 in 130bcd. Pm sent.
#171
Bikes: 2012 redline conquest pro / 2008 yeti 575 / motobecan fantom cross uno
have: DA 7900 standard crankset. 53/39... used, but in good shape.
want: ONLY DA 7900 COMPACT crankset... 50/34... used, but in good shape.
nothing else. no 7800, no sram red, no ultegra SL. thanks though.
located in costa mesa, CA. willing to meet in IE, maybe LA or SD.
email crawford.davidh at gmail.com
#172
Señor Member
Have: This fork.
Want: Something interesting?
Flyte SLX carbon cyclocross fork. 1-1/8, 45 rake. 24.5cm of alloy steerer. Disc and canti compatible. Fender eyelets. Good shape, no cracks or major damage. Some scratches on the decals/clear coat/paint but no damage to the carbon.
#173
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Have:
9 speed Tiagra STI's in good shape
FSA SLK-Light BB30 crank 172.5 130 BCD - some heal rub but good overall
Need:
9 speed barcon shifters - would trade straight across for the tiagra shifters
some thing interesting?
Need:
#174
Bikes: 1984 Club Fuji, 1970 Schwinn Continetal, 90's Roadmaster ATB, 2003 Raliegh C40
Have: 56 Cm Redline Conquest Frame/Fork/Headset
58cm KHS Flite Road Frame (Reynolds 953 Tubing)
Want: Something comparable to the Redline in a 54cm or a 56 that runs smaller
#175
Have: Like new Ultegra 6750 compact road crank.
Want: A comparable cross-specific crankset.
