derailleur cage size?
All work and no play...
I'm running a 53/39 set of chainrings and a Ultegra 11-23 casette on my TT build. I can get a heck of a deal on a new DA 7800 rear derailleur at my LBS, but it is a GS cage and I know that my set up is probably best with an SS cage. Can I go with the GS or will this just not work?
Quoted: 143 Post(s)
Liked 163 Times
It'll work. Will it shift as crisply as a shorter cage model? Some say yes, some say no, most say if it doesn't it's not enough to matter, probably not perceptible.
Quoted: 380 Post(s)
Liked 107 Times
It will shift the same. The only disadvantage is the GS might be a gram or two heavier. If you are not a weight wiener it shouldn't be a problem, Roger
Bikes: something
I swapped to a GS from an SS a few weeks ago. Acutually found that the GS is shifting cleaner.... But I also added a few links that were badly needed.
