Go Back  Bike Forums > Bike Forums > Fitting Your Bike
43cm seat tube and 5'5 height, frame size too small?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 11-13-16, 05:14 AM
daryldeal
daryldeal's Avatar
Bikes: Celt Steel Frame
Quoted: 44 Post(s)
52cm seat tube and 5'5 height, frame size too small?
Is the seat tube too short? can this be 'compensated' by a higher seat post?
daryldeal is offline
Old 11-13-16, 10:15 AM
bargainguy
bargainguy's Avatar
Quoted: 517 Post(s)
Liked 310 Times in 191 Posts
Short answer: It depends.
Long answer: The reach to the handlebars is less adjustable than saddle height. Does the reach feel comfortable for you? Does it feel like you're really stretching to reach the handlebars or is it the opposite, do you feel "cramped in the cockpit" as if the bars were way too close?
If the reach is fine, then sure, you can go with a longer seatpost. Got to have at least two or three inches of seatpost inside the frame, more is better.
I'm 5'4, and I have three Independent Fabrication road bikes I picked up used. Two of them have 650c wheels and are 46 & 47cm frames respectively. The other is a 43cm frame with 700c wheels. The 43cm frame fits me just fine, the reach is good, and I don't have too much seatpost sticking out of the frame.
So that winds back to the short answer, it depends. Depends on your proportions, the wheel size of the bike, and the particular bike geometry involved.
bargainguy is online now
Old 11-13-16, 02:45 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
In order to fix a problem, we need to know what the actual problem is. So far you've listed a height (almost useless for fitting) and a frame size. What's the problem??
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 11-13-16, 03:47 PM
daryldeal
daryldeal's Avatar
Quoted: 44 Post(s)
i measured it again and its 52cm, sorry guys
im not really sure whats the problem, maybe just wanna know if the frame size fits my height
Old 11-13-16, 04:33 PM
ThermionicScott
Only you can answer that. How does it feel when riding?
RUSA #7498
Old 11-13-16, 04:38 PM
daryldeal
daryldeal's Avatar
Quoted: 44 Post(s)
When riding, the bike seems ok but i have the saddle a bit high though, not sure if its because the seat tube is short that id have to do that. Is it optimal that the saddle should be close to level with the handle bars?
Old 11-14-16, 09:00 AM
ThermionicScott
Depends on the bike, and how you ride. Some of my bikes have the handlebars below the saddle, others have it above.
By the way, you should adjust the saddle so that you get nearly complete leg extension at the bottom, not so that it's an arbitrary position compared to the handlebars.
Can you see the minimum insertion line on your seatpost?
RUSA #7498
Old 11-15-16, 04:54 PM
daryldeal
daryldeal's Avatar
Quoted: 44 Post(s)
yup i can. bout the leg ext, is it with flat on the heels or with bended feet?
Old 11-15-16, 05:23 PM
ThermionicScott
A good rule of thumb is, legs straight with heels on the pedals, a little bent with the balls of your feet on the pedals.
RUSA #7498
Old 11-16-16, 05:35 PM
Road Fan
Road Fan's Avatar
Quoted: 1858 Post(s)
Liked 664 Times in 506 Posts
Sooooo, what's next?
Road Fan is offline
erbfarm
25
04-16-20 10:16 AM
Ali89
Fitting Your Bike
3
04-26-19 10:24 AM
RocThrower
Fitting Your Bike
9
02-02-16 02:42 PM
bikefitcm
Fitting Your Bike
7
10-17-15 06:30 PM
ForSureForSure
Singlespeed & Fixed Gear
9
07-23-11 04:57 PM
