will slicker tires make a notable difference?
I have what could be considered a flatbar gravel bike. its light, nippy and has 40mm schwalbe G-one All rounds.
I enjoy these tires a lot, for commuting, its quick taking off at lights, comfortable, gives good control and i feel i can clip along at a reasonable rate in an urban setting & as some of my commute is literally a gravel canal path, so once i got the pressure right for my weight, they fit the bill nicely.
Im planning more longer trips, which will all be on the road however, and Im considering changing up to something less gravelly. Considering the bike is not a racebike,
- will slicker tires help reduce the effort required over a 8+ hour journey?
- As the schwalbe g-one allround's are super comfortable and I already like them, would the comfort factor be something to outweight minimal benefits of a slicker "faster" tire?
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I had to look them up (pic below) and they do have small nubs. I "think" a smoother tire would give a more comfortable ride on pavement.
I have a CX bike wilt 2 sets of wheels, one with 35mm knobby and a second with 32mm tubeless all weather road. It give me the best for each activity. I think the road tires would be excellent for you.
Your tires
My tires, Bontrager AW2
https://www.trekbicyclesuperstore.co...e-366538-1.htm
Your tires
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
It's not just the slickness of the thread that makes a performance difference, but the entire design of the tire including the sidewalls. If you really want to notice a difference pony up and go all the way:
https://www.renehersecycles.com/shop...-bon-jon-pass/
Likes For AlmostTrick:
Quoted: 668 Post(s)
Liked 529 Times
Lots of good choices.
for an all around tire I use donnelly ush tires, nice center strip for pavement with knobbies outsides for decent traction in gravel/dirt
https://www.donnellycycling.com/prod...t=724110999570
For nastier trails I have a second set of wheels and tires with Gravel King SK's
I've been looking at bicyclerollingresistance but I'm a little skeptical of the results. The test seems very different to real world usage. It's a very curved surface, which IMO causes a smaller point of contact so more pressure and an amplified result.
The results are also not hugely useful. They find, almost every time that a stiffer harder tire has better rolling resistance, and most tires have lower rolling resistance at their highest psi, but it's well kown that in the real world, running a rock hard tire at its max psi is not beneficial to reducing rolling resistance.
To follow their logic to conclusion I think if they tested a thin solid wheel it would have fantastically low rolling resistance, and technically top their tables, but it's real world usage would be non existant.
For these reasons I take all results on that site with quite a few pinches of salt.
Likes For wilson_smyth:
Quoted: 20810 Post(s)
Liked 9,456 Times
It'll make a difference, yes. If you're not going to be doing (much) gravel, then I'd either look at the 30mm G-One Speed (if there are new Addix versions out there, I haven't seen or tried them) or the 30/32mm Pro One Addix.
Likes For asgelle:
Quoted: 4560 Post(s)
Liked 2,802 Times
Overall tire design, materials, sidewalls, etc, often matters more than tread -- unless we're talking MTB knobbies.
I've used Vittoria Zaffiro entry level 700x23 road tires, basically slicks, that I really disliked. They were harsh, unpleasant with poor grip near full pressure, sluggish and squirmy at lower pressure.
And Continental SpeedRide tires for light gravel riding, basically great all around hybrid tires for pavement, multi-use trails including chat/crushed limestone trails, etc., that feel surprisingly fast and smooth for 700x42 tires with diamond/file tread similar to those Schwalbes, and vestigial side knobbies that don't really do much unless you're banking hard on grass. Sweetest hybrid tires I've ridden that cost only $20-$25.
I've had Conti Sport Contact II that have a similar diamond/file tread (Conti used to call it "slick" but it has shallow tread), but are harsh at high pressure, sluggish at lower pressure, with no sweet spot. Decent tires for all around use, grippy, long wearing, puncture resistant, but not pleasant. The sidewalls are too thick and rigid, which really seems to compromise ride quality.
I've had Schwalbe One V-Guards, circa 2014, slicks, very light and fast, great handling, grip on fast curves, a great training tire and even fast enough for local crits. A bit fragile -- nicked and cut easily -- but I still got 1,500 miles from the rear before it was cut up too badly by construction debris, glass, etc., along my favorite rural route. The front tire is still fine after more than 2,000 miles and mounted on an aero rim from my old time trial bike with cracked frame. Occasionally I still use it on my road bikes when I feel like tackling a PR or humiliating myself in a vain attempt at a KOM.
My current faves aren't slicks, per se, but have a bit of tread pattern that may be mostly cosmetic: Continental Grand Prix Classic skinwalls (700x25 only) and Soma Supple Vitesse SL (700x23) skinwalls. The Conti's are my current fave everyday road bike tire. The Somas are great for go-fast days. The Somas have a peculiar squarish tread pattern that might offer a bit more bite on some pavement in wet conditions, but I rarely push my luck anymore. They just roll nicely even over loose gravel scattered on chipseal, feel comfortable with latex tubes, and make themselves invisible by behaving well and not giving me any grief.
Best value in a slick tire if you're just curious to try a set -- Continental Ultra Sport II or III. I think they're available up to 700x32 They're really good cheap tires -- smooth rolling despite a fairly thick sidewall, grippy, long wearing, resistant to cuts and punctures, reasonably low rolling resistance. Only caveat is they are a b4st4rd to mount on most rims. You'll really want a bead jack. When I used Conti Ultra Sports as my everyday tires I always tucked a Kool Stop bead jack in my jersey pocket or strapped to the saddle bag. But Conti GP Classics are now my everyday tire (I can mount 'em with just my hands), and I use the Ultra Sports only for use on the indoor trainer -- they're really tough and don't wear out prematurely on my Cycelops magnetic trainer with metal roller. If Conti ever changes the Ultra Sport fit so I don't need a bead jack I'll go back to using them on my old steel road bike for everyday use.
Quoted: 3450 Post(s)
Liked 420 Times
What makes tires fast, and this applies to motorcycle/car/truck tires as well, is flexibility. A flexible tire is faster than a non flexible tire.
Now often it just happens to be that flexible tires are also slick tires but it doesn't have to be so, so you need to be careful in your choice and not just judge a tire by its looks/tread pattern.
Some slick tires are made for general purpose/urban use and have fairly strong and rigid treads. They look smooth but aren't fast.
Some micro knobby tires are quite flexible and so are also quite fast.
I have some micro knobby tires on my current bike and I was about to get rid of them on principle until I realised that they were quite flexible and fast tires so I am letting them wear out before replacing them.
OP here again.
I was one click away from buying a set of schwalbe almotions but a a number of forum posts across the internet mentioned that although they are super quick when up to speed, they are slow to accelerate and not agile in for urban commutes, taking off quickly at lights etc.
I'm probably going to go with the g-one Allround again, I know it, I like it and at my level, the increased resistance will probably only amount to an extra 10-15 mins over a 100 mile cycle.
That's one question I don't have enough experience to answer and would like to hear some opinions on, how many kw of a difference are realistically noticeable to a normal cyclist not trying to eek every last second out of their times?
Likes For rydabent:
Quoted: 6972 Post(s)
Liked 10,970 Times
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Likes For Kapusta:
Advanced Slacker
Liked 2,537 Times
Liked 942 Times
Now I see RH also offers an "Endurance" option with extra sidewall protection for those concerned with such things. I've probably done over 10,000 miles total now on Compass/RH standard casing tires with nothing more than a couple of punctures from small wires. No need for any more "protection" (that will slow things down and compromise the ride quality) for me.
Liked 10,970 Times
I was tempted to try the extralights and am sure they roll nice and are even more comfortable than the standard casing. But since the standards are more than plenty supple (and light!) I don't see a need.
I've had the same experience (as you) with the standards: they are smooth and supple, reliable (so far, anyway), and better than anything else I've tried. Though I am curious about the Extralights, I will probably stick with the standard casings.
Liked 942 Times
I've not used the Extralights, but my shop won't carry them -- they tell me that they are just too much trouble. Reliability and sealing problems, I gather.
Schwalbe lists my G-Ones at 480g. (40-266)
They list the marathon almotion v guard (non microskin) is 490g. the microskin one is over 600g.
Even with variation between avg weight vs what ends up leaving the factory, i cant see a diffence of 30-40g making any notable difference to my acceleration at traffic lights.
I think im leaning more toward the almotion v-guard non microskin, nice balance of speed & durability that should be as agile on the road as my current g-one allround.
Advanced Slacker
Liked 2,537 Times
It does make sense, as the sidewalls on the ELs are thinner and more flexible.
What I would be interested to know is if the standard casings weep less sealant.
Previous versions of several models were not good at tubeless, but I have been running a new set of Barlow Pass ELs for about a year, and other than needing sealant more often than I would think they should need, they have been fine. I use Orange Seal.
As far as durability, I ride about 60/40 pavement/gravel, including some rough gravel. Been running various EL casings (32mm Stampede Pass, 35mm Bon Jon Pass, and 38mm Barlow Pass) for the past 5 years and have never cut a sidewall. I weigh ~175 lbs.
Liked 9,456 Times
