Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Copying Fit From My Old Bike
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 05-03-21, 08:52 AM
Sojodave
Sojodave's Avatar
Bikes: The Blurple Specialized Roubaix Pro
Quoted: 220 Post(s)
Liked 143 Times in 75 Posts
I built up a Roubaix 2017 Pro frame over the winter. I got a bike fit on my old bike and I'm trying to copy the same measurements onto the new bike. Both bikes have a Specialized Power Expert saddle and I copied length from the hoods to the front of the saddle to 31.5". I have the exact same handlebar height and yet the bikes feel completely different. On my old bike, I have no pressure on my hands and feel super comfortable. On the Roubaix, I feel more pressure on my hands and shoulders. I'm 6'4" and both frames are 61cm. The reach on my old bike is 411 and the Roubaix is 396. I added a 130 stem to the Roubaix to get the same measurement to the end of the stem because the old bike has a 120 stem. The only thing I can figure out is the stack in the Roubaix is longer than my old bike. The stack on the Roubaix is 650 and my old bike is 617. Can someone help me figure out how to compensate for the difference in stack?
Sojodave is offline
Old 05-03-21, 09:28 AM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3890 Post(s)
Liked 1,939 Times in 1,384 Posts
Do it this way: Start by using a long level (or a short one taped to a straight edge) to measure the horizontal distance between the saddle nose and the center of the bottom bracket on the old bike. Transfer that measurement to the new bike. Then measure saddle to hoods.
Results matter
Carbonfiberboy is offline
Likes For Carbonfiberboy:
Old 05-03-21, 10:23 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
If the seat tube is a different angle from the other, then you may never feel quite the same on it. That's not to say you can't make it just as comfortable.
Iride01 is offline
Old 05-03-21, 11:23 AM
Sojodave
Sojodave's Avatar
Quoted: 220 Post(s)
I just checked and the seat angle for my original bike is 73 and the Roubaix is 73.5...pretty close. The head angle is exact for both at 74.
Sojodave is offline
Old 05-03-21, 02:47 PM
Iride01
Iride01's Avatar
Are the handlebars the same reach and drop? And if you don't have your STI's at the same position or the bend profile of the handlebar is different, that might be putting you in a slightly different position that alters where you put your butt.
You are riding both and deciding about fit aren't you? Don't just sit on them and think bad of one.
Iride01 is offline
Old 05-04-21, 09:18 AM
Sojodave
Sojodave's Avatar
Quoted: 220 Post(s)
Update: I measured my bottom bracket to the saddle setback on my old bike and I moved my saddle on my new bike to match the setback. I had the saddle on my new bike all the way back on the rails and it now sets halfway on the rails. I went for a ride and there is noticeably more comfort. Being 6'4", I've always had my saddle back as far as it will go to accommodate my long torso.
Sojodave is offline
Old 05-04-21, 12:36 PM
tomato coupe
Quoted: 3956 Post(s)
Liked 7,307 Times in 2,949 Posts
Easier to put the bike in a corner, with the back wheel against one wall. Measure from the wall to the saddle nose, and then from the wall to the bottom bracket, and subtract. Use the floor as reference for vertical measurements. No fussing with levels or plumb bobs.
tomato coupe is offline
Likes For tomato coupe:
Old 05-05-21, 03:49 PM
Sojodave
Sojodave's Avatar
Quoted: 220 Post(s)
Originally Posted by tomato coupe
Easier to put the bike in a corner, with the back wheel against one wall. Measure from the wall to the saddle nose, and then from the wall to the bottom bracket, and subtract. Use the floor as a reference for vertical measurements. No fussing with levels or plumb bobs.
That is the method I used.
Sojodave is offline
