FSA Omega compatible with BB30?
Quoted: 25 Post(s)
Hi Everyone,
I am wondering if this crankset which is an FSA Omega crankset is compatible/ can be installed on a BB30 bottom bracket?
FSA OMEGA Crankset 175mm 50/34T and MEGA EXO BB-4000 Bottom Bracket | eBay
Thanks for any insight you can provide
My 2014 Sirrus came with this crankset. When i searched for a new BB for this set i found that the spindle on this crankset is 19mm wide and the only BB that works with it is the one that comes with it.
PBP Ancien (2007)
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times
No it's not compatible with BB30.
It's very much like a Shimano external BB but with a 19mm axle. I use one on my commuter bike (which originally came with a square taper BB).
Quoted: 6196 Post(s)
Liked 4,811 Times
Are you simply wanting to replace the crankset without replacing the BB? If so you need to know what the BB is that is currently in it or what the crank is that is currently in it. Then you'll know the spindle size of the crank that you must look for.
But if you know what your BB shell is actually made for, then you can buy cranksets that also have BB's for them that will fit your BB shell and not have to worry about spindle diameter.
Likes For Iride01:
