Hybrid Tire Choices
Hybrid Tire Choices
I hope this is in the correct category. I'm looking for advice on 700c x 38c tires for a Crossroads hybrid. Like advice on mid range, folding tires with puncture resistance.
Most of my riding is on paved surfaces - up to 10 - 12 mile rides.
Thanks for any advice, suggestions.
RR
RR
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Panaracer Paselas come in 700x38 and are a great all-around tire. Good following in the commuting/touring/urban bike world, and I've used them myself. Solidly-midrange, but a good value, and actually not really heavy for its size which will be good for comfort and efficiency (45-50 psi range for 38s is a good starting point to work from).
Quoted: 102 Post(s)
Liked 55 Times
If it's mostly paved, would you be going tubeless or tubed? All weather or mostly dry?
I only run tubeless, and my go to commuter/travel tire for my hybrid is the Marathon Supreme TLE, in 622-37, but it's more of a 35c. They are higher in price and now getting a little scarce. The Paselas are also nice and moderately priced, but not as fast nor as puncture resistant. I recently just started testing the GP Urban by continental, which is only available in 35c. It's nice rolling, faster than the Supremes, and lighter too. It is thinner and higher priced though.
I will be also testing the G1 as a gravel tire.
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times
Lots of choices. I’ve purchased Continental Contact Plus and Michelin Protek and happy with both. Less than 500 miles traveled with each set so far though.
Has anyone tries these - Kenda City Slickers II? Amazon has them in a package - 2 tires, 2 tubes and a rim strip.
Thoughts?
Thoughts?
I have used Panaracer Gravelking Semi Slicks in 700cx43 (current tires), Gravelking Slicks in 32mm and T-Serves in 35mm on my bikes and i like all of them (all tubed). Also have used a pair of 42mm Panaracer Tour wirebead tires that are super comfortable and great value if budget is tight.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
RR
RR
One option I'll throw into the mix is the Continental Speed Ride. They're labeled 42mm tires, but they're undersized and inflate to a true 38-39mm on most rims. They're relatively light, they're a great value, they're foldable, and I think they'd work well for you. They don't have the indestructible type of puncture protection that something like a Contact Plus Travel or a Ride Tour, but those touring tires also aren't foldable.
You can get some really nice folding touring tires. Like the Schwalbe Marathon Supreme. But I wouldn't call them "mid range" in terms of price. More on them here: https://www.bicyclerollingresistance...n-supreme-2016 Note that, although they're really expensive tires, they don't offer the ultimate in puncture protection that other non-folding options in the Marathon line can provide.
I think your options will open up a lot if you can relax your requirements list a little bit. If you really want a compact, foldable tire, it won't offer the best puncture protection out there. And if you need that top-level puncture protection, the tire probably won't be foldable.
Likes For hokiefyd:
If you truly need both a folding bead and (presumably strong) puncture resistance, your choices may be limited. Most of the tires known for good durability (like most of the Schwalbe Marathon line and the like) are not folding -- folding tires are typically thinner, more supple tires (they fold easier). I'm not saying what you're looking for isn't out there -- but I don't think you have a lot of selection.
RR
Quoted: 1400 Post(s)
Liked 1,885 Times
Panaracer Gravelking SS+ might be good option
SS+ has added material to prevent punctures and snakebites
would also consider 35mm in addition to 38mm
Likes For t2p:
Hybrid vigor climber.
Best for puncture: Continental SportContact 37C
Best for performance: Maxxis Refuse 40C
Best for value: Kenda K180 38C
Here in 2022 Brazil.
Liked 1,885 Times
( one online vendor recently had them for under $20 in damaged packaging )
limited size availability - but as mentioned in thread above tire is closer to 38mm than listed 42 mm
I ended up getting Michelin 700 x 38 tires along with Conti tubes. Stuck with Schrader stems to match the existing rim holes. Not a big investment, so if they are not the way to go, I will change.
Thoughts on the Michelins?
Liked 762 Times
I presume they're Michelin Proteks of some sort (Protek City, Protek Cross, etc.). If so, they're not light or folding, but they're certainly durable tires that I'd wager will provide lots of happy and flat-free miles for you!
I would not recommend Michelin Protek, they're still on my old bike, but they wore rather quickly. The stock Giant tires were far better.
I have Specialized Pathfinder on my new bike, I'm curious on how they do, I like the design, as Spartazoo suggests.
