Chain tension on SS Conversion
Old 04-27-23, 06:29 AM
Zaskar
Quoted: 479 Post(s)
Liked 277 Times in 156 Posts
If you've built a single speed around a frame with dropouts with no fore/aft adjustability, you know how hard it can be to find that magic gear. Now, add in a narrow/wide chainring. Oof. But, I think I got it. My question is about chain tension.
The chain has some slight sag. But, I can't it off the sprocket or chainring without "helping" it, i.e., pushing it to the side while pedaling - same method as when the chains are tight. I've run looser without issues. But, figured I'd see what you guys think. Any issues from what you can see?
Zaskar is offline
Likes For Zaskar:
Old 04-27-23, 06:51 AM
IAmSam
Quoted: 399 Post(s)
Liked 274 Times in 136 Posts
Track slack, amirite?
What size chain do you use on a narrow-wide ring anyway? You obviously know the ins and outs of conversion and are willing to live without being able to adjust your chain tension but if it exists for your size chain a single half-link can be a wonderful help in situations like yours. Good luck - have fun...
IAmSam is offline
Old 04-27-23, 07:48 AM
Zaskar
Quoted: 479 Post(s)
Track slack - wow. Yeah, that's what makes me think I'm fine. 2000 watts with two extra links may work on the track, but seems like it's a bunnyhopped pothole away from flying off. A single speed sprocket (deep compared to a multi-speed cog), a well-aligned chain should keep even a very loose chain in place. The narrow/wide is supposed to take it even further. But, they're not compatible with half-links since it creates a "narrow-narrow" link.
Zaskar is offline
Old 04-27-23, 09:32 AM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times in 432 Posts
I've run my singlespeed chains a lot looser than that, and never had one fall off. As to using a half link with a narrow/wide chainring, it will work OK with a 1/8" wide chain, since the narrow link side will still be wider than the wide tooth on the narrow/wide chainring. Also, narrow/wide chainrings are really only needed on multi-speed setups, where the chain is not straight, and is constantly trying to derail.
Taking it a step further, if it were me, I would ditch the NW chainring, replace it with a standard 3/32" chainring with no ramps or twisted teeth and add a 3/32" half-link. I am assuming you are currently using a 3/32" chain and your freewheel has a 3/32" cog.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
