MTB drop bar conversion questions
Bikes: C1970 to 74 Peugeot, 80's Lotus 3000 m mountain bike
I have just picked up a Giant Boulder MTB that I want to do this conversion to. I have found a drop bar that has the same dimension as the bar on it now at a LBS.My question is can I leave the shifter and brake levers that are on it now and just use them up on the hood. I prefer to sit up when coming to a stop anyways.
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
Your stem also may not be the correct clamp diameter for a road bar
The drop bar that I have found has the same diameter as the bar that is on there now.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
+1 If you think it will work, give it a try. Trekking bars are a good choice if you want to keep original controls.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
Most drop bars are 23.8 mm diameter in the grip/control mounting area, while most drop bars are 22.2 mm diameter grip/control. There are exceptions but they are quite rare. It is more likely the diameter that matches on your mtb and new road bars is the stem clamp diameter.
Explanation near the bottom of this page: https://sheldonbrown.com/deakins/handlebars.html
Also, MTB controls are designed to work well and be easy to use with straight bars - if you mount mtb brake levers on a curved road bar they will likely not be nearly as easy to use.
THe easiest solution for controls on a mtb drop bar conversion is drop bar brake levers that will work with your brakes*, and bar-end shifters. Road STI levers ('brifters) don't work properly with mtb front derailleurs, and bar end shifters have front friction shifting which work with any front derailleur.
*Brakes: If you have V brakes (side-pull or direct pull cantilvers) or cable actuated disc brakes you need long-travel brake levers. If you have centre-pull cantilevers or caliper brakes then you need short pull brake levers.
