Headset for 1984 Trek 560
What Headset for 1984 Trek 560?
So I've been scratching my head trying to figure out what headset to get for this Trek frame I have. I've taken measurements twice and they don't seem to line up exactly with any of the standards, I think. I've looked at the Sheldon Brown chart o and read an article on Velo Orange's site. I was hoping you all could tell me what sort of new headset I should be looking for. My guess is things are not perfectly round so depending on the direction I measured it varied a bit, so I captured those as a range, Here are the measurements I took (all in mm):
Crown race: 26.45 - 26.5
Head tube top ID: 29.7 - 30.0
Head tube bottom ID: 30.0
Steerer OD: 25.2
Steerer ID: 22.2
For more clues, the catalog says it came with a "Stronglight B10 Black Delrin", and the fork has "Tange made in Japan 3J" engraced on it.
My guess is an ISO headset could work, even though it is not spot on. But before I go buying/installing the wrong thing, I thought I'd consult your knowledgable brains. Thanks for your help!
The frame in question:
Steerer OD: 25.2
Steerer ID: 22.2
Quoted: 1084 Post(s)
Liked 688 Times
Any 1" threaded headset will work. Here's a bunch of them.
https://www.amazon.com/1-inch-thread...readed+headset
There are plenty of other choices too. Given the vintage of your Trek, you'll probably want to go silver. Here's a nice one from Velo Orange.
1" Sealed Bearing Threaded Headset
I'm not sure just any 1" headset will work though. As I understand, there are a few different specs for how they are built, with varying measurements, and they aren’t all interchangeable. I'm trying to figure out which of these my frame and fork were built for.
Edumacator
Quoted: 2454 Post(s)
Liked 3,170 Times
My 560 Pro Series is a few years newer model, so dimensions and stack height might be different. But it came with Hatta Vesta like this one:
https://www.ebay.com/itm/391321970881
Liked 688 Times
Thanks for the reply!
This is the most common headset size on my bikes - four of them. Cane Creek used to make a nice one that was also affordable, but I don't see it listed any more. If I had to buy one now, the Grand Cru from Velo Orange looks pretty sweet. But again, there are a lot of choices and you'll get other recommendations.
Likes For Jeff Neese:
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
Wasn't there like a combination JIS/ISO sort of thing where one measurement was JIS and the other ISO like JIS for the cups and ISO for the race? Was a nice pdf on bf somewhere I forgot which thread it was in.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 339 Times
Ive had good luck with the....
...velo orange headset. Just the regular ball bearing one.
Quoted: 1946 Post(s)
Liked 2,175 Times
If it indeed came with a B10 headset, then the stack height is 43mm; According to Velo Base. https://www.velobase.com/ViewCompone...b49b6&Enum=111
The Velo Orange 1" threaded headsets have a stack height of 41mm. If the steerer was cut for 43mm you might have to add a headset washer, or two, between the cup and the nut. I'm sure these headsets are made for Velo Orange, so you can source them elsewhere if you identify the mfg.
Under no circumstances should you cut the steerer tube. As years go by you most likely will want as much bar height as possible before you go to a Nitto Tecnomic stem.
John
John
John
John
starting to suspect this. I measured 30mm for the head tube ID, top and bottom, so I’d be hesitant to put 30.2mm cups in. What should I do if I have a combo situation?
Liked 2,175 Times
I’m not an expert on tolerances, but I think .2mm “should” be okay.
Unfortunately Summer is over or I’d tell you to put the frame out in the sun and the cups in the freezer.
Worked great for installing wheel bearing races years ago.
John
John
Quoted: 1641 Post(s)
Liked 832 Times
True, a lot of 80's Treks came with a Stronight needle bearings headsets.
If it came with the ones with the Delrin top and bottom cups it would be best to replace it with an all aluminum version of the A9 headset as there's quite a bit of flex on the Delrin cups that make them harder to put the proper preload on them so the steering will he smooth and secure. The flex on the cups makes it hard to dial out all of looseness completely without causing a bit of binding on the headst. Some people insist that they could make them work, but all the ones I encountered so far.had the described problem.
I've also definitely seen cases where the Delrin cups had cracked from UV deterioration.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Old fart
Quoted: 3594 Post(s)
Liked 3,404 Times
The OEM headset for this was a Stronglight B-10, which has 30.2mm pressed head tube fittings, so any ISO-spec headset of similar or lower stack should work. This is an interference fit, so it is expected that the head tube ID is slightly undersized.
Likes For JohnDThompson:
Quoted: 795 Post(s)
Liked 1,795 Times
Quoted: 879 Post(s)
Liked 2,300 Times
I have worked on a few Trek bikes from the 80’s and they had Stronglight needle bearing type headsets. They were 600 series bikes , I think. Nice headsets and easily serviced . There should be good used ones out there. Maybe check with local bike shops that have been around a while or work on vintage bikes.
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 57 Times
I have found that the Chris King and Shimano Ultegra and Dura Ace threaded headsets are bulletproof and very long-lasting.
Liked 688 Times
You don't. You're making this more complicated than it needs to be. Any 1" ISO Standard headset will fit. The only caveat is as 70sSanO mentioned, and that is to pay attention to stack height. You may need spacers.
Who is installing this? Are you going to press the cups in yourself, or take it to a shop? Talk to them. If you buy the headset through a shop they may press the cups in for free.
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 265 Times
Car free since 2018
Quoted: 259 Post(s)
Liked 269 Times
Just following up here—
I ended up buying an Tange Levin CDS with 26.4 crown race. I wanted to try installing the headset myself to gain the experience, so I borrowed a press from a friend and did just that. It definitely felt like a tight fit, though I have nothing to compare it to. It appeared to seat fine, and I assembled everything. I've taken it on a couple rides, and everything seems to be working smoothly, so I'm going to call it a success. Thanks for the troubleshooting.
