Building New Wheel for "Old" Bike
Bikes: Miele Gara '88 - Shimano 600 Ultegra
Hi Everyone!
I'm new to these forums. This being only my 2nd post, since my introduction.
I have what seems to be a rather uniques position in today's market of cycling equipment and parts. First, I need to declare that I'm a mature rider in my 50's; and I've largely done my own bicycle maintenance, as long as I've had the tools. Next, I need to be upfront about my bike: It's a Miele Gara '88 with a Shimano 600 Ultegra groupo (Yes! I bought it new, in 1988) It's in pretty good shape; and the reason that I've kept it is that I'm 6'6" tall; and the frame is triple-butted, which suits my size very well. I've maintained the Shimano groupo; and I'm still quite happy with it. I can't justify spending thousands to simply replace the groupo, when I'm only riding for pleasure. Also, I suffer from sciatica; and the Biopace crank allows me to be able to cycle without any adverse effects. (I lucked out with that)
Here's the interesting part! Last Summer, the Ambrosio 19 rims that came with my bike finally died, after untold thousands of miles of use over the decades. They saw me through racing as a novice; charity rides (including centuries); and me simply being a silly drunk young fool. So, now I'm looking to build a new set of rims for my bike; and I've got my eyes on the DT Swiss RR511 rims (non-disc brake). Why? Because they're solid rims, which will handle by weight without any problems (as I get back into shape). Back in the 90's, I would simply have gone into the bicycle shop that I purchased my bike from; purchased the rims and spokes; and simply rebuilt the wheels. Today? I've encountered what I can only call strange behaviour! Bicycle shops are refusing to sell only the rims and spokes; and some have even claimed that my Shimano 600 Ultegra rear hub/sprocket is "incompatible" with the DT Swiss RR511 rim. Again, I declare that I'm not a bicycle mechanic, but as soon as I heard that last claim, red flags started to go up. I'm getting the feeling that people are trying to take me for a ride $$$$$.
I understand that with the DT Swiss RR511 rims, I not only need to use all new spokes, but I'll also get matching nipples, as well as the PHR washers; and I don't plan on going tubeless, as it's not necessary.
So, the question that I have (in multiple parts) for anyone who has a great deal more knowledge than I about bicycle mechanics than I do, is:
Thanks in advance!
Mick
- Can you think of any reason why I can't use my existing Shimano 600 rear hub/sprocket, which would prevent me from being able to use the DT Swiss RR511 rims?
- If the answer to the previous question is "yes", can you explain it to me in terms that I will understand? (Admittedly, I'm extremely skeptical; and I need to understand why)
- If you think that this should NOT be a problem, but that I should be aware of any considerations as I build my new front and rear wheels with the DT Swiss RR511 rims, could you please share that knowledge?
Thanks in advance!
Mick
aka: Dr. Cannondale
Quoted: 2156 Post(s)
Liked 3,414 Times
You don’t mention the number of holes/spokes in your existing Tricolor rims, but unless they are an unusual drilling, should be no problem. Those DT rims seem to come in all popular hole sizes. Personally, I’d go with Kinlin rims in that aero size, but hey, you be you.
BTW, kudos to you for keeping those Tricolor hubs in service. They will likely survive you. And me. And a nuclear holocaust.
Likes For rccardr:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 166 Post(s)
Liked 269 Times
I've never used those DT rims, but it's still just a rim. If your hubs have the same number of holes, you'll be fine, have fun. The only incompatibility I could see would be if your 600 hubs have 36 holes, because the RR511 looks to only be offered with 32 as the highest drilling. If you have hubs with the same number as the rims, then your LBS is trying to take you to the cleaners.
Likes For PhilFo:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 740 Times
are your 600 Hubs 32 or 36 hole? 36 hole is not available in that rim...Excellent hubs, no matter the spoke count!
here's the Numbers for the 32 hole DT swiis rim with Rim Brake Tracks ...
RR 511 700C 32 mm RB VI
RDRR51RPN32S011419Last edited by maddog34; 04-13-23 at 09:55 PM.
Likes For maddog34:
Friendship is Magic
Bikes: old ones
Quoted: 26434 Post(s)
Liked 10,394 Times
...if the case turns out to be that your hubs are 36 hole, replacement rims are still available that are drilled for 36 holes. Just not those.
There were some shortages and out of stock problems a couple of years ago, when last I bought some. But I think that was Covid factory issues.
Likes For 3alarmer:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
The DT Swiss RR511 does not come in 36 hole, only 32 hole or lower. I don't know if it's true that you need to use PHR washers with these.
Another great DT Swiss rim is the R460:
https://www.prowheelbuilder.com/dt-s...k-msw-rim.html
These are a great bang for the buck. I built up a set of these with Dura-Ace 9000 hubs, DT Aero Comp spokes and DT brass nipples (no PHR washers). I have logged over 10K miles on these and have not had to re-true them once. These also only come in 32 hole or lower counts.
Senior member
Quoted: 944 Post(s)
Liked 659 Times
A bike from 1988 would have a high probability of having 36 spoke wheels. 36 hole rims are not impossible to find yet, but fewer manufacturers are offering them. Even the Ambrosio classics are topping out at 32 hole.
Velocity fusion would be a good choice for that bike. A 25mm profile and 14mm inner width would suit it well. Available with all drillings from 18 to 40.
https://www.velocityusa.com/product/rims/fusion-622
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
The h plus son archetype could be another good option if you need 36h
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 369 Post(s)
Liked 469 Times
You mentioned "thousands of miles," but not if you periodically cleaned & rebuilt the hubs.
For example, if you rode these 50k miles and never rebuilt, the races and cones could exhibit pitting/wear.
Riding in wet conditions could contribute to premature wear, too. Spin the wheels by hand to feel for any grinding action.
Sounds like 7-speed hubs and 130mm rear spacing. Betting you could find suitable replacements online, if needed.
If the OP wants a silver HPlus Son rims and Miche hub wheelset - choice of freehub - butted spokes - here it is for $359. Just under 2000 grams if that's you're thing.
https://velomine.com/products/h-plus...set-campagnolo
I bought a similar rim brake wheelset from Velomine - 28 hole H Plus Son silver 700c with 105 hubs. Very nice so far.
Thanks, everyone!
Apologies for the delayed follow-up. Our place has been in a buzz with other priorities, since my wife’s return from visiting her family in China.
I really appreciate all of your replies! And yes, I should have included that my Shimano hubs are 32H. You’ve all provided some good recommendations. I’ll look into them. One of the reasons I have my eyes on the DT Swiss RR511 is that it’s much more durable than the Ambrosio 19’s that I’ve enjoyed. Whichever rim I go with should handle the weight of my 6’6” frame, as well as the combination of imperfect roads, railway crossings (I can’t hop as well as I used to) and the occasional trail (more like paths that the local government has cleared for people to walk, run and ride bikes on… not rough, but not as smooth as pavement).
I agree about the Tricolor hubs! Back when I ordered the bike, I deliberately chose the 600 Ultegra groupo, because it had a great reputation. The store actually offered to install a Campagnolo groupo for the same price, because they didn’t have the Shimano in inventory, but I decided to wait the extra couple of weeks. The hubs are easy to maintain, too; and yes… they still spin freely. They only time the wheels made any grinding noises was when the rims went out of true; and rubbed against the brake pads.
Well, I have my homework… to check out those rims you’ve all recommended. I may still go with the DT Swiss RR511… who knows? Maybe one of those recommend?
Once again, I really appreciate the feedback!
Likes For Mick Psyphon:
Really Old Senior Member
If you're strong, heavy or pack cargo, I'm a fan of an OC spoke bed rim like these-
https://www.velocityusa.com/product/rims/a23-oc-622
w/ a front to compliment-
https://www.velocityusa.com/product/rims/a23-622
Likes For Bill Kapaun:
Quoted: 18386 Post(s)
Liked 4,520 Times
DT Swiss does make what they call Asymmetric Rims for some of their models. Probably other brands too.
You may need to calculate your own spoke lengths. There are several good spoke length calculators online. And, you can measure your own hubs.
Now, one thing to keep in mind. Well, I like the newer triangular shaped rims. But, some purists like the flat top rims on vintage bikes. You can find a variety of rims on E-Bay.
Or the company Velo Orange will have some vintage looking rims.
This would be the time to upgrade should you choose to convert to 9 speed, 10 speed, 11 speed, or even 12 speed. Friction shifting can work with newer cassettes, if you have the range with your derailleurs.
Make sure your hubs are good with good cones.
