Suggestions for my next C&V bike?
Bikes: 1984 Gitane TdF, 1986 Look Équipe, 1983 Colnago Super
Quoted: 113 Post(s)
Liked 137 Times
I’d like it to be steel, but geared for climbing, from approximately the 1980 – 1995 era. It's a flexible date range. Probably 7-speed downtube shifters, or maybe Ergo/STI 8 or 9-speed.
For reference, here are a few of my recent bikes, each ~54cm
2014 Cannondale SuperSix Evo. Proficient, with convenient 11-speed shifting, but doesn’t feel as nice as my steel rides. Stiff, easy to ride fast, slightly nervous but in-control. It has been relatively expensive, with some recent carbon upgrades.
97.5cm wheelbase, 73/73.5 angles front/rear, 45mm fork offset, 40.5cm chainstays
~2010 Mercier Kilo TT. This one cost me one-tenth the price of that carbon bike but is one of the best handling bikes I’ve ridden. If you suddenly want to turn, it follows you, sure and smooth. But, it is only fixed gear or single speed. Since all my rides involve climbing, I sold it last year. That was probably a mistake.
97.4cm wheelbase, 73/74 angles front/rear, 28mm fork offset (unverified), 40.1cm chainstays.
1984 Gitane TdF. I love this bike, very comfortable for any distance, and stable at speed. I set almost as many personal records on it as on the Cannondale. But sometimes a little too stable. I’ll never sell it, but I’d like a bike with quicker handling.
99.7cm wheelbase, 74/74 angles, 40mm fork offset, 41.2cm chainstays.
Lately, as you can see, I tend to opt for frames that are a bit on the small side.
Thanks for your time,
Eric
Eric
I start by picking the groupset I want then build the rest around it, finding a frame of the same period etc. Sometimes I've been lucky and found a whole 'survivor' bike other times I've built up from bare frame.
I currently have an early 90s 8 speed 6400 STI groupset that needs a frame. Previous builds have been Campy Super Record, Campy C Record with Deltas, Shimano 6400 7 speed 1st release, Shimano 7403 8 speed STI.
I'm thinking 7200 Dura Ace next...
Likes For AUPedla:
Quoted: 4513 Post(s)
Liked 6,391 Times
IMO
(A) Yes, you should have kept the Mercier and I am decidedly non-fixie, single speed, etc.
(B) Expand your date range to include most of the 70's, say 72 and on.
(C) Paramount, Cinelli or Bianchi SC, Raleigh Pro, Motobecane TC/CT, Peugeot PX-10, Gitane TDF or any bike boom era custom
builder, any of these can be retrofitted to later drivetrains, etc. although here many would not do so.
Likes For merziac:
Quoted: 113 Post(s)
Liked 137 Times
Quoted: 113 Post(s)
Liked 137 Times
IMO
(C) Paramount, Cinelli or Bianchi SC, Raleigh Pro, Motobecane TC/CT, Peugeot PX-10, Gitane TDF or any bike boom era custom builder, any of these can be retrofitted to later drivetrains, etc. although here many would not do so.
(B) Didn't older frames come with even longer wheelbases? Didn't brazing / lug making abilities improve as the bike boom went along? Yes, if a bike came originally with 5-speed, I'd want to upgrade to 10/11 speed and keep the original parts.
(C) The thing is, which ones had the best/quick handling?
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times
My regular riders range from the late 60s to 2010+ and focus on English & USA road bikes. Some racing, but mainly sport touring. Personally, I’d look at US builders that produced some reasonable volumes like Ritchey, Eisentraut, etc.
Cheers,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Likes For Senior Ryder 00:
Liked 6,391 Times
(A) Sad, but true
Mass production technology improved in leaps and bounds that led to 10's of 1000's of very well made steel frames and then much of the cookie cutter crap.
Some of the best builders went to Japan to get them sorted out, after that the sheer volume and quality was amazing, many of those frames will be around forever.
The hand made frames were some of best frames ever made, many were very well made, the process has not changed much while the tools and tech has improved, the process is still basically the same as it has always been. Many builders did their best work with the support of the factories and produced in fairly large numbers.
Some of the bikes had longish chainstays but many still had good quick handling from angles, fork rake and other tube length.
Also, plenty of custom builders specialized in racing frames so there are many of them with very quick handling.
Quoted: 113 Post(s)
Liked 137 Times
Thanks merziac. Of the bikes you recommended, the Bianchi SC looks like it may be a quick handler.
Though I'm judging by the distance from the rear wheel to the seat tube, and the fork rake, which I don't know are the best way to look at things.
Quoted: 5888 Post(s)
Liked 3,472 Times
I raced and rode a 1991 team miyata. That is a top end bike and it handles superbly. That would be on my short list of bikes to track down.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
A mid- to late-90s Italian steel frame, with Campy 9-speed or newer. Your Cannondale might struggle to get out of the shed.
Liked 3,472 Times
Steel. It will be easier to find. I was told by the rep that the frame was the same as used by the professionals in Europe. Who knows if that was true but it is a lovely frame. It wont be the lightest bike you own, but it is very stiff and responsive with splined tubing and investment cast lugs, fork crown (it's aerodynamic), and lugs. The bike is a rocket that handles well.
Likes For bikemig:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
If you want a quick handler, look for frames that have the rear wheel tucked in close to the seat tube, they generally have a steep-ish front end as well. Such as:
3 Rensho
Davidson Impulse
Cannondale SR (not steel, but still)
Tesch 101
I’d also strongly recommend a late 80’s Ironman, as they had a little quicker geo than the 85-87 series.
Any lf the above framesets can be made to accept modern components.
3 Rensho
Davidson Impulse
Tesch 101
Likes For rccardr:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
You asked, so here are a couple you might want to consider:
Best, Ben
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 113 Post(s)
Liked 137 Times
That blue Cinelli is gorgeous!
And very practical too, I could put a rack on the back and use it to shop for groceries...
A Tesch 101 sounds excellent. Though not too many have ridden one - any of you?
All the bikes suggested are pretty darn rare. It is cool to be able to run a modern gear train. Perhaps Athena...
Liked 2,182 Times
Blasphemy pure blasphemy., if I could afford one of those someone would be getting my groceries.....
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 113 Post(s)
Liked 137 Times
An Ironman from the late 80's does look tempting - I like the traditional paint scheme compared to others of theirs. While searching for examples, I came across these bikes in other threads...
Though James Dak appears to know the topic, here's his Schwinn Circuit:
Here is a more representative photo. I think maybe I'll move the 100mm Cinelli stem and (26.4) bar from the Circuit to the Ironman and then put an 80mm stem on the Circuit.
I'll measure it, but does anyone know what diameter the Ironman's Nitto B115 bar should be? Recommendations for an 80mm stem for it? What about recommendations for a 27.0mm seatpost upgrade per RobbieTunes' advice?
Maybe I spoke too soon when I said I found one ride "notably superior" to the other.
Quoted: 113 Post(s)
Liked 137 Times
Likes For cyclic_eric:
Likes For zmensing:
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,846 Times
The best handling drop handlebar bikes I own on the racy side of the spectrum
'86 DeRosa
'80 Mondia Super
'89 Falcon
'86 DeRosa
'80 Mondia Super
'89 Falcon
Likes For Wildwood:
Quoted: 2326 Post(s)
Liked 5,012 Times
Like mentioned above, look for a Davidson. They seem more common out there on the west coast where he built them. My impulse is easily in the top 3 of all my bikes, it's a rocket yet comfortable. The Italian built pre-Trek Lemonds rock too.
Of course there's always the chance of finding a hidden gem in the local classifieds. My David Kirk built Fishlips came that way, as well as the Martelly built rocket I have, and even a Serotta Nova Special built up with NOS 10 speed Chorus.
David Kirk built this frame, found locally for under $300
Found locally for under a couple of hundred.
Over the years turned into this.
Languished on local ads priced at $500. Only used part was the headset. Saddle still had the $252 price tag on it. Look deep for deals like this that others pass up. This was a new build by a bike mechanic with a bad back that couldn't ride it.
If your, catching anything from the thread it should be that there are a ton of quality bikes in the range you're considering. Shop for the best value deal and build up from there.
Too bad you're so far away as I am downsizing and have about 1/2 dozen bikes listed locally. Just not up for the whole shipping thing and prefer to have the buyer see my bikes and know for sure totally what they are getting. Sometimes my pictures make a bike looked better than they really are.
The one I'm finishing up right now is a prime example of what you should be able to find locally. This one came to me late last year and was an impulse buy. Saw it listed locally and could tell it was a quality frame. Some quick research indicated it was probably Columbus SL tubing. It had been recently serviced but also still a bit of a mess. Owner's grandkids had been using it. For now I've sorted out the wobbly wheels, replaced old housings and cables, better tires and tubes, new stem, seatpost, saddle, modern handlebars, better looking brake levers and rewrapped the bars. In the pics the paint looks good but it had a lot of chips and wear in it. I mixed up some red paints trying to get a match for the sparkling red original paint. Looks good from a few feet but up close you can easily see where it was touched up. So right now I have a quality built (likely Italian contracted) Columbus SL tubed bike with mostly Dura Ace and Shimano 600 parts, Campagnolo rims, and a slew of new cockpit bits ready to roll for not a whole lot of money. If after a few test rides it is a quality handler it would be super easy to properly spread the rear to 130 (seems to be spaced about 128), throw on some modern STI shifters with a matching 130 wheel and cassette and Bob's your uncle. A lot of the old RD's can cover a modern cassette.
This kind of picture makes the bike look good but up close you can see the paint issues.
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 767 Post(s)
Liked 1,898 Times
So many great suggestions here, truly amazing builds. Just want to throw out there that if you find something that has potential, but maybe isn't finished to your liking, there's always the option to refinish.
I had this 1986 Miyata 912 frameset powder coated by Groody Bros., and am very pleased with the results. Built up with a Campy 3x9 group sourced from a member here, Fulcrum wheelset from Merlin, and it is a fantastic bike. Link:
https://www.bikeforums.net/21834316-post7878.html
Check out the Retro Roadies thread for tons of inspiration.
Quoted: 113 Post(s)
Liked 137 Times
An orange bike is always worth re-sharing: Unfortunately, (fortunately) BFisher's and jamesdak's bikes are a little too large for me
