The two hour barrier
Old 05-08-19, 02:26 PM
tourisme
Quoted: 18 Post(s)
Liked 3 Times in 2 Posts
Caloso nailed this early in the thread. Saddle pain is more often about bike fit than about the brand of saddle. If you're sitting n the nose of the saddle because your reach is too long, that's going to hurt.
Get some advice about whether your bike fits you properly. Then tinker with saddles.
tourisme is offline
Old 05-08-19, 03:05 PM
gobicycling
Made it to 84 WHOOPIE
Quoted: 181 Post(s)
Liked 493 Times in 153 Posts
Originally Posted by zarbog
I replaced the very comfy for short rides Serfas saddle with the stock one yesterday, it is narrow and has very little padding and I was better off after the ride, 2 hours and 15 minutes at a leisurely pace. Looking forward to trying out the B17 when it gets here.
Berner had the same sort of issue that I am experiencing I think.
I am mostly a skinny guy with a big gut. Have always worn low rise pants, have a skinny butt and my belly will hang over my belt. I weighed 130 pounds when I was in my early 20's, ate like a horse and never really gained any weight until I was pushing 40. I would like to get down to 180 this year. Those shorts that canklecat mentioned look intersting but the waist might be too high on them for me. I will think about it a bit before I order them.
I've read many claims of leather saddle owners that they no longer need to wear padded shorts, that would be incredibly nice if it prooved true for me one day.
You are an excellent candidate for bibs. Shorts fit best those with flat bellies.
gobicycling is offline
Old 05-08-19, 03:07 PM
55murray
55murray's Avatar
Quoted: 207 Post(s)
Liked 108 Times in 58 Posts
Looks like you are on the right track. For hours of comfort you will need to let go of soft wide saddles. Just wide enough to fit, and minimal to no padding. Then you have to remember to do the thing where you get out of the saddle for a minute or so at a time to let the blood flow back, to allow your rear to condition up. Every 15 minutes or so at first. Really helps a lot, after a few long rides doing this you can really tell you are dialing in. One of the best tips I got from this entire forum.
55murray is offline
Old 05-08-19, 03:35 PM
tclune
Quoted: 45 Post(s)
Liked 12 Times in 10 Posts
I'm a clyde and for me discomfort in the seat is a matter of core conditioning more than anything else. When I start getting tired, I slump in the saddle a bit. It would be easy to mistake this for a bad fit, because the net effect is that I move forward on the seat. But the real culprit is that I am slouching because my core is tired. FWIW
tclune is offline
Old 05-08-19, 04:18 PM
Biker395
Seat Sniffer
Biker395's Avatar
Quoted: 945 Post(s)
Liked 1,986 Times in 569 Posts
Originally Posted by rumrunn6
what I don't get, are the guys who can do double centuries. talk about hours in the saddle ...!
That's legit. I think it is possible, because there are rest stops every 40-50 miles or so and you get a chance to get off the seat. We've also pretty much dialed in the saddle/fit and stand up when necessary.
Originally Posted by base2
And that is exactly it. Evenly distributed between hands, feet, sit-bones.
On newer bikes from the shop, the tendency is to have the bars too high. There's a dozen reasons, but none of those are relavent. The point is that if your sit bones hurt, they are taking too much of the weight.
The solution is either to move some of that weight to your hands and getting proper core engagement by lowering the bar (assuming it is a reasonably proper distance.) Too high bars also often cause hand/wrist issues because the core is not properly engaged to support the body.
The other option is getting the feet to support some of that weight by adjusting the seat height or pressing harder on the pedals. Usually (counter-intuitively) that often means raising the seat to properly engage the leg muscles for good stroke. The result is less pressure at the sit-bones.
Good luck.
That is exactly what I think. There are three contact points. Try to equalize the level of comfort/discomfort in each. Pressing harder on the pedals, in particular.
Other than those things, experiment with saddles until you find one you like. Just about everyone eventually finds one they can work with. I have different saddles on my bikes, and I find all of them reasonably comfortable, but I think I'm the exception.
Biker395 is offline
Old 05-09-19, 06:36 AM
dennis336
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times in 68 Posts
Nothing new to add ... my first reaction to the OP was a good bike fit and a saddle that works for you - I'm another big fan of the Brooks B17. After experimenting with a few other saddles, settled on that and never looked back. Also ... going back several years now, I had been finding with my first 'serious' road bike, as I got older and did longer rides, my shoulders and lower back would get very sore. The ride was feeling harsh. I sprung for a carbon bike and also got more conscious about not over-inflating my tires. Something like tire inflation can affect the harshness of your ride and be wearing on your body, too.
dennis336 is offline
Old 05-09-19, 07:58 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
Originally Posted by Flip Flop Rider
more time in the saddle
slowly increase, maybe 10-15 extra minutes at a time..gradually increase, be in it for the long haul
This is the best answer IMO. No matter what saddle, or any of the other suggestions (which may still be good suggestions), it's getting your body used to the time in the saddle. The only way to do that is to train it.
wphamilton is offline
Old 05-09-19, 04:04 PM
trad
Professional bike fitting before starting your saddle investment journey is spot on. Here are some things that work for me and that you might try before sinking lots of $s. Adjust saddle height (lowering a mm or two makes a big difference in reducing rocking), adjust saddle fore/aft (moving forward a bit helps sit bones stay in wider part of saddle), adjust saddle tilt (I like mine level). On cushioning (from chamois and/or saddle), I find less is better on long rides (less "squishing" and related rubbing). Bibs pulled up and that are fairly tight around sit bones help (less movement). I also stand up every 15 mins or so (for blood flow) and also pull the chamois slightly away from sit bone area skin every hr or so (chamois gets "stuck" a bit for me and occasional readjustment helps). When riding multiple days in hot/humid weather, I use a small bit of vaseline in sit bone area - keeps chamois from sticking in place).
trad is offline
Old 05-09-19, 04:31 PM
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times in 1,865 Posts
If you are able, it helps to get out of the saddle now and again. You don't have to do it for long, though the more you do it, the longer you can sustain it. You also don't have to do it with any impressive show of power. Getting out of the saddle for a short time at least every couple of miles gives your sit bones a break.
MinnMan is offline
Old 05-12-19, 08:34 AM
zarbog
zarbog's Avatar
Bikes: Giant SLR GX1 Toughroad
Quoted: 65 Post(s)
Liked 22 Times in 16 Posts
Second ride on the Brooks, getting off the saddle more often, usually coasting and got off the bike twice for a few minutes to walk around. Two hours and 45 minutes, 47km, 390 metres elevation. Truefully, the Brooks felt good from the get go, slippery but that helped with setting up the tilt and the height and for/aft position until I more or less stayed where I wanted to on the saddle.
Tried keeping the back staight, but by the end I know I was hunching my shoulders from fatigue. Legs and shoulders were more tired at end of the ride then my rear end. I could of gone a bit longer with no problem as I was still comfortable on my sit bones. Guess I will have to break down and do some core muscle strength exercise's.
I was using the liner shorts with the thinner pads this time, first ride I used the thicker ones. The thin pad ones always got hot and I sweated a lot down there, but they were fine for this ride, wonder if its the leather vs synthetic seats.
I wore a cycling jersy under a jacket and when I got home I noticed the jersy had rode up over my waist so some bare belly was showing. Bibs might just be the answer until I get skinny again.
Thanks for all the advice. I feel great having gone just that much further on my ride. If I stayed up on the escarpment I could of rode longer, but going down the escarpment then climbing back up is energy draining at this point, but it lets me ride all that way on a rail trail.
zarbog is offline
Old 05-12-19, 08:44 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,057 Times in 631 Posts
Congrats! Yeah, just mix it up and you'll be fine. On a long ride I have an endlessly repeating list of things that bother me for a few minutes, then pass. Feet hurt for a while, then my hands, then my neck for a while, then my back, then a one knee. All you can do is stand up for a a while, shake it off, and try to ignore it. As long as it's not just one thing that hurts, it's normal, and will pass.
Lemond1985 is offline
Old 05-12-19, 09:31 AM
gobicycling
Quoted: 181 Post(s)
Bibs might be the answer, period. Many wear bibs as a first choice, not as a second choice to shorts.
Old 05-12-19, 11:00 AM
bluezurich
Team Concussed/AARP
bluezurich's Avatar
Bikes: Pinarello Stelvio, Ritchey Logic, Trek Roscoe 8
Quoted: 5 Post(s)
Liked 5 Times in 2 Posts
In my 33 years of road cycling, I think I only used shorts for the first two years, after that, weight high or low, it's been bibs and I cannot imagine riding in shorts except for mtb ever again.
bluezurich is offline
Old 05-16-19, 03:29 PM
Kotts
Recreational Commuter
Bikes: One brand-less build-up, and a Connondale Synapse Carbon Ultegra Disc. A nicer bike than I need, but it was a good deal, so... ;-)
Quoted: 7 Post(s)
Liked 5 Times in 3 Posts
Saddle height is all about muscle engagement. For weight distribution, you need to look at saddle fore/aft adjustment. Too far forward, and too much of the weight is on your hands. Too far back, too much is on your sit bones. Somewhere in between is the "Goldilocks Zone".
KOPS (Knee Over Pedal Spindle) is a reasonable starting point, but not the be-all-and-end-all. A better test is to get on a trainer and ride, then see if you can pick up your hands without straining, shifting your hips forward a lot, or increasing cadence significantly.
Kotts is offline
Old 05-16-19, 04:23 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
Good point on fore/aft adjustment as well. Additionally fore/aft relates to pressure behind the knee cap & which leg muscles are engaged or favored. Good stuff.
base2 is offline
Old 05-16-19, 08:34 PM
zarbog
zarbog's Avatar
Quoted: 65 Post(s)
Spent just over 4 hours in the saddle today, 5 km to the rail trail on pavement, and 5 more at the return ride. Managed 69.5 km. It is all cinder and forest trail, no hard gravel.Their is a 20 km section that is a steady 1 to 3 % grade climb. I stop at the top of the climb and get off the bike for a few minutes. Probably stopped to stand over the bike for a drink a dozen times. Shoulders and hands were pretty fatigued, and reading Kotts post, think I will slide the seat back a fraction or so. I have it a bit forward to make sure I was sitting on the wide part.
My goal is to make it from my town, Hamilton, to the town of Brantford and back via this old rail trail. Todays ride was about 3/4 of the way, but that is my current limit. Black flies are out and they keep you moving ha ha. Very pleased with the B17. No problems from that area. I do think I can go a bit higher in the seat , knee pain is at the right leg front lower part of the knee cap.
I still can not ride with no hands.
zarbog is offline
Old 05-29-19, 10:47 AM
xroadcharlie
Bikes: 2018 Giant Sedona
Quoted: 183 Post(s)
Liked 116 Times in 95 Posts
I don't know how you guys do it! I usually don't go more then 2 hours in my car. And as a recreational bike rider I like walking sometimes after an hour anyway. I feel so refreshed after that, even though my bike is still comfortable.
xroadcharlie is offline
Old 05-29-19, 02:54 PM
zarbog
zarbog's Avatar
Quoted: 65 Post(s)
I was baffled as too how some folks managed to ride such long distances. There are so many areas of interest surrounding most communities that are accessible by bike, but are just too far away for most riders to get there. Number one limiting factor, for myself, was discomfort and then actual pain that prevented me from staying in the saddle and thus being able to explore where I wanted to go.
Once the issues that cause discomfort are corrected, then the only limiting factor is physical condition. At my ripe old age I have started doing Planks and push-ups, who would have thought. All in the quest for riding distance. Perseverence is paying off, I can now stand up when required to climb short steep hills, impossible last year. I have raised the seat about a half inch, titled the bars down, then back up a bit, slid the seat back a smidge, all since my last post. Knee pain seems to have gone, I rode no hands for half a block the other day. It is all coming together. I can see being able to ride in the drops more, as my fat belly starts to shrink.
xroad, it sounds like you get bored by the ride more than anything else ?
zarbog is offline
Old 06-22-19, 12:19 PM
zarbog
zarbog's Avatar
Quoted: 65 Post(s)
This is my last update, thought I would share it
Just over 5 hours to complete this 55 mile loop from my driveway to the next city. It is 90% rail trail and was a personal challenge to myself that I hoped to accomplish by summers end. Can't believe I managed it already. I was pretty beat at the end but still managed to do the final climb home.
zarbog is offline
Likes For zarbog:
Old 06-23-19, 07:23 PM
OldTryGuy
Quoted: 1069 Post(s)
Liked 787 Times in 505 Posts
KUDOS to you !!!
OldTryGuy is offline
Brooke1687
9
11-28-17 07:17 AM
jazzgeek79
Fitting Your Bike
9
01-18-17 10:38 AM
FastJake
Fitting Your Bike
5
05-20-16 01:00 PM
teresamichele
21
05-26-12 04:35 PM
Big Pete 1982
20
04-28-12 12:08 PM
