Racer Tech Thread
Old 08-16-19, 02:34 PM
  #5851
redlude97
Quoted: 1821 Post(s)
Liked 104 Times in 76 Posts
Originally Posted by Flatballer View Post
So I think Garmin uses average speed over some recent duration to give you your turn directions at the appropriate time. However, it's very easy to get situations that break this.
Last ride I came over the top of a long climb and hit a very fast descent, and was even with my turn before it gave me the notification. Had to turn around and climb back up to get back on route.
Then the opposite, it consistently gives me the notification too early when I'm climbing. Like, 45 seconds before I need to turn.
I do wish it would take into account road size. Sometimes it only tells me 200 feet at 20 mph before a turn, but I'm in the far right of two lanes with traffic, so it's really hard to get across to turn left in that space.
I'm guessing this is just the way it is, but it's annoying.
yea its annoying, i just keep it on the map page when I know I have a lot of turns coming up so I can watch the route
redlude97 is offline
Old 08-18-19, 03:13 PM
  #5852
furiousferret
furiousferret's Avatar
Quoted: 662 Post(s)
Liked 87 Times in 48 Posts
Its new bike time and I was conflicted about Rim v Disc. On one hand rim is lighter and I can swap the parts, on the other it'll all be worthless in 3 years (my assumption is no one will sell rim bikes by then) and buying a $2200 wheelset that will only last 2 years and won't go on my next bike is a hard pill to swallow.
Anyway, I guess I'm going Disc cus I locked in some used eTap HRD shifters and brakes for pretty cheap! Once I found out that you can get a disc bike under 16.5 lbs / 7.25 kg that was my demarcation. Leaning towards a SuperSix 105 and swapping my eTap. The high end stuff for C'dales is way overpriced.
furiousferret is offline
Likes For furiousferret:
Old 08-19-19, 06:38 AM
  #5853
topflightpro
topflightpro's Avatar
Quoted: 1327 Post(s)
Liked 62 Times in 44 Posts
My wife kind of needs a new bike. I've told her it will be disc. No point in not going disc now - I'm not saying it's needed, but it's clear that is where the industry is going.
Of course, if we found an awesome deal on a lightly used rim brake bike, I might reconsider.
topflightpro is offline
Likes For topflightpro:
Old 08-24-19, 09:55 AM
  #5854
Flatballer
No matches
Flatballer's Avatar
Bikes: two wheeled ones
Quoted: 1093 Post(s)
Liked 43 Times in 29 Posts
Garmin is replacing my Edge 530 due to continued issues with phone connectivity. I get drops on basically every single ride I do.
We'll see if it helps, but I'm not holding my breath.
Flatballer is offline
Likes For Flatballer:
Old 08-26-19, 05:59 PM
  #5855
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 517 Post(s)
Liked 171 Times in 116 Posts
Is there a smart trainer that doesn’t eat bearings or drive shafts? Had a Snap for two rides, recently refurbished ubit, and it’s toast. Guy is taking it back and giving me my money back.
That item in such a relatively low load should last longer than bottom brackets!
Maybe a Flux?
DC Rainmaker gushes over the Kickr products but I read a ton of problems.
Any production years finally “cleaned up” of issues? Like not buying a first model year car?
burnthesheep is offline
Old 08-26-19, 06:50 PM
  #5856
Ttoc6
Cat 3
Ttoc6's Avatar
Bikes: CAAD 10 / CAAD X / Scalpel
Quoted: 577 Post(s)
Liked 89 Times in 38 Posts
Flux had a lot of issues at release. I had a snap, didn't care for how it held erg mode. Moved up to a kickr (2016) and love it. Just works. I wouldn't buy a wheel on trainer anymore.
Ttoc6 is offline
Old 08-26-19, 07:02 PM
  #5857
Flatballer
No matches
Flatballer's Avatar
Apparently I'm on the hook for return shipping. They neglected to mention that was part of the deal. Considering how unlikely this is to fix it, and how likely that I'll end up with a refurb with some other issue I'm considering refusing delivery.
Old 08-26-19, 07:28 PM
  #5858
burnthesheep
Newbie racer
Quoted: 517 Post(s)
Stac Zero? No bearings! Just magnetic. Seems interesting. Ahhh, but 4iiii just bought them.
Old 08-27-19, 06:38 AM
  #5859
Flatballer
No matches
Flatballer's Avatar
So I got the 1 month Strava trial a couple days ago to try out the Analysis pack mostly, to get live segments, and see if I liked them.
So far I hate them. They're not actually working on my Edge 530, even though I can see the segment on the map, it isn't prompting. I think I have it all turned on and enabled and everything, so not sure what the issue is there.
The one segment that I did see and try for today, it ends on a downhill about 10 feet short of a stop sign that almost always has a ton of gravel and sand washed into it from a slope nearby. Should have stopped it at the top of the hill 50 feet back before the descent, because I'm not hammering down that hill and going sliding into a car, that's ridiculously stupid.
Old 10-02-19, 08:54 AM
  #5860
burnthesheep
Newbie racer
Quoted: 517 Post(s)
I'm tossing the ghetto modified HED basebar. I can't adjust it whatsoever and the integral brake levers on it aren't in good shape.
The last straw is that I have the extensions mounted to the stem cylinder piece and they constantly rotate. So I'm going to go with something that has the two bolts to secure risers/pads and stuff. It's not because I'm death gripping it or something, just that the clamping isn't working out.
I also increasingly feel sketched to ride it given I had to drill it for the pad mounts anyway.
We'll see what I wind up with. I'm cruising the UK TT forums for ideas.
Probably will be some open mold thing that isn't the fastest, but will allow me to ride without worrying about hurting myself. Likely the PDQ bar setup. The guy still makes/sells the tilt riser also for it.
And, the added adjust-ability will be welcome.
They keep quoting some UCI "angle". I thought it was height from pad to tip of extensions, not angle. Some of these TT positions I'm seeing have a LOT of extension rise from pad to the tip. Maybe I'm confused.
I'm too slow for anyone to care about that level of the rules anyway in our class.
Old 10-09-19, 10:20 AM
  #5861
caloso
caloso's Avatar
Quoted: 1944 Post(s)
Liked 342 Times in 189 Posts
Are the holes for toe spikes in MTB/CX shoes the same as football/soccer cleats? I would assume so, but thought I would ask.
caloso is offline
Old 10-09-19, 11:16 AM
  #5862
burnthesheep
Newbie racer
Quoted: 517 Post(s)
In the toes in most cross shoes. I've seen some MTB and "commuter" spd shoes without spike provisions.
The stuff like Giro Privateers and VR90's have toe spike provisions. As do your usual suspects from Lake and others.
I got a pair of VR90's on sale at like 60% off and absolutely love them. Freaking amazing shoe. I got the lace up version also. I just tuck the bow into the laces and good to roll.
They don't really flex to run, but then again, there ain't much running for obstacles in cross around here. Just a barrier setup for a few seconds per lap.
Old 10-09-19, 12:03 PM
  #5863
caloso
caloso's Avatar
Yes, I have the Privateers with the holes but no spikes. I was wondering if I could just go to Dicks or Big 5 and get some football cleats rather than specific Giro (and probably more expensive ones) from the bike shop.
caloso is offline
Old 10-09-19, 12:17 PM
  #5864
burnthesheep
Newbie racer
Quoted: 517 Post(s)
Oh, sorry. I misunderstood the question.
Mine came with the shoes in the shoe storage bag with the tool to install them. Did you lose them or wear them out, or bought used without? I'm not sure if the threads are the same. Maybe a LBS has some sitting around somewhere.
I'd assume most soccer/football stuff now is permanently molded to the shoes. Baseball spikes are often square shaped for what digs in and aren't integral to the thread. Those are screw and spike. CX/mtb are spike and screw all together.
Soccer one may work, but maybe amazon prime some CX spikes?
Old 10-09-19, 12:57 PM
  #5865
caloso
caloso's Avatar
I've had these shoes for years, don't have the box anymore, but don't remember ever seeing any spikes or tool. I used to have screw in cleats when I played football back before the introduction of the forward pass. I guess I thought they still had screw in cleats. Maybe I'll just order the Giro ones from Amazon.
caloso is offline
Old 10-12-19, 12:32 PM
  #5866
burnthesheep
Newbie racer
Quoted: 517 Post(s)
Raaawwwwrrr! Pdq bars came. Forgot the Felt stem diameter was wrong. Now waiting for that for at least a week.
Old 10-12-19, 05:56 PM
  #5867
Voodoo76
Blast from the Past
Voodoo76's Avatar
Bikes: Ridley Excal, CAAD10, CAAD12, Felt DA, Dolan
Quoted: 173 Post(s)
Liked 12 Times in 11 Posts
Maybe a Flux?
Huh, I have around 600 hrs on an old Kickr w/o a single issue. By far the best trainer I've ever used.
Voodoo76 is offline
jambon
Bicycle Mechanics
14
09-06-18 09:58 PM
Hoopdriver
General Cycling Discussion
8
05-01-18 03:37 AM
Machin
Bicycle Mechanics
31
11-22-13 04:15 PM
JeffOYB
Bicycle Mechanics
22
10-17-13 09:53 PM
cpk0
Road Cycling
14
08-07-10 07:05 PM
