I may have SLIGHTLY over inflated my inner tube
Quoted: 1002 Post(s)
Liked 237 Times
So I'm sitting here in my office in my bike in front of my desk....everything is nice and quiet
Then BANG!!!!
Sounded like a gun went off...followed by a slow 'pffpffffftftftftftfff' as I watched my bike drop an inch and a half
My rear inner tube exploded
It's possible I may have SLIGHTLY over inflated it.
Scared the snot out of me! hahaha
Oh well good thing I keep a spare with me. Guess I know what I'm doing at lunch time.
Then BANG!!!!
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
One time long ago the gauge on my cheap floor pump (now replaced) rotated somehow so that it was reading low, and I pumped my tyre up to what I thought was 100psi... and it was probably more like 200psi... and wow did it scare the hell out of me when it went BANG.
Liked 237 Times
This happened in a store once. I was there with my then 2 year old. We were next to a rack of bikes when BANG!!!! A random tube on one of the bikes gave out.
My 2 year old looked up at me, saw I wasn't scared, and just smiled and ignored it.
The store manager gave me a 10% off coupon because it DIDN'T scare the kid and make him cry.
Ironically...I was there to buy a spare inner tube that day. The same spare inner tube I will be putting on my bike in about an hour.
Not getting the inner tube fully in between the tire beads , does it too
tube pressure pushed tire off rim where you left it poking under the tire bead..
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
Yep. This is what happened. I am sure you did not overinflate your tube to the point where it exploded. You have to make sure that the tire bead is not pinching the tube or else BAM!
Liked 237 Times
The bot poster above you (literally a computer makes those posts from that account, not a real person) did not correctly diagnose this. It was not pinched in the bead. It was overinflation combined with a failed seem.
I put a lot of air in it this morning in a rush. Wasn't paying attention. It was cold when I did it. Then I got it inside my office...heat went up....pressure went up...seem failed...bang.
The failed seem is right along the outside, as far from the bead as you can get, and very close to the valve stem so the tube couldn't have been twisted around inside the tire enough that the outside of the tube was down by the bead.
Likes For Skipjacks:
Story of having a Slime filled Tube blow out , worst part was trying to catch the cat to wash the green stuff off..
Likes For fietsbob:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Quoted: 5224 Post(s)
Liked 3,582 Times
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
fiets is a bot? huh?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Technically, it is a Hybrid, or T-H, a human who has been transformed into a cybernetic organism. It is the main focus of the Project Angel, which was initiated by Cyberdyne Systems Genetics Division, and reborn by Skynet as Project Theta. It quickly reads the forum topic, and responds to what it calculates to be the OP content.
Likes For Cyclist0108:
Liked 237 Times
Liked 237 Times
Someone told me that a few months ago. I didn't believe it.
Then I started watching the posts.
And they don't pass the Turing test. (The name for the test to determine if a computer can trick a human into believing it is alive)
Maybe I'm wrong. Its not my theory. Several other people have told me this. I thought they were all nuts at first. But the more I watched, the more I believe it could be true.
Liked 237 Times
Nervous to the point where I went downstairs to let some air out of the tires
Seriously I did that a few times after the first time I heard a tube explode
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Damaged sidewall or bead, even without overinflation, will cause a blowout. It is unlikely that the difference in ambient temperature between the time you inflated it and the time it blew was a factor... the ideal gas law uses absolute temperatures, so even if you inflated it below freezing and it went up to 30 degrees C (from 273 - 303 Kelvin), it won't make a big enough difference in pressure to cause a blowout on a non-damaged tire.
Quoted: 943 Post(s)
Liked 172 Times
...And they don't pass the Turing test. (The name for the test to determine if a computer can trick a human into believing it is alive)
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Likes For ksryder:
Several days later when I when to inflate the tires on my bike, The stem was gone on my back tire. I thought WTH! Then it dawned on me that BANG I heard was the stem blowing off.
Liked 237 Times
In this thread I am the only one who has seen or touched this tube. Yet multiple people are telling me what happened without seeing the tire or the tube or having any idea how inflated it was...what size tire or tube it was...how long ago it was mounted...etc...but people act like they know more about it that I do when I mounted it, inflated it, rode, it, dismounted it, and inspected it.
I find this hysterical.
Liked 237 Times
I had just moved into my townhome when in the middle of the night I heard that BANG! I had no idea where it came from. I checked the basement, everything seemed fine.
The tires are becoming sentient! They are soon taking over the world!
I, for one, welcome our new rubber overlords.
Bikes: yes
Liked 643 Times
The tire is fine. The tube was overinflated. Best guess is there was a weak point in the rubber.
THEREFORE BASED ON THAT SINGLE DATA POINT EVERY TUBE THAT BLOWS MUST BE BECAUSE OF THE RIM STRIP PLACEMENT!!!121221!!!
Likes For ksryder:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
If there was no pinching then you might have had a tube too narrow for the tire. The right sized tube doesn't stretch that much to begin with and stops stretching as soon as it reaches the tire, after that all the hoop pressure load is taken by the tire cords and the tube is only being smashed against the tire by the pressure, not stretched any further. If the tube is too small it's under more strain by the time it reaches the tire.
On the other hand if the tube is too large, it can fold and chafe.
If you have your tire label lined up with the valve stem it's easier to find problems in the tire and rim by the location of the hole in the tube.
Genesis 49:16-17
Genesis 49:16-17
Liked 237 Times
One time I had a tube blow while I was sitting in my apartment on the couch and the bike was not being touched -- turns out there was a problem with the rim strip so the tube was touching the spoke nipple.
Seriously it just amazes me that some people can't read a "The tire exploded!" story and enjoy it for the fun quip it is. Some people just have to expound so they can impress people with their knowledge.
Just read the story. Laugh at how the air bomb going off in my office scared me awake this morning. Make a joke about the bikes attacking us. And move on. That's all this needed.
