What's the longest you have gotten out of a rear tire?
I keep on reading people get 1000 miles out of a rear tire sometimes less.
But I regularly get 2-3k+ I think its due to the smooth CA roads?
Can anyone top that?
To be clear I mean from a performance tire not a commuter tire like gator skins
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,568 Times
I put a new GP4000SII on the rear of my Fuji this spring. I now have 2900 miles on it. Most every road around here is chip sealed.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4369 Post(s)
Liked 3,001 Times
I can get nearly 5000 miles on Conti 4 Seasons tires, in the rear. And even then, they are probably still rideable and safe - but they have a pronounced flattening to their profile. Front tires can go for even further unless there's some horrendous puncture, like a big nail.
The same with Gatorskins, though I don't use them so much anymore.
GP4000s - maybe not quite as much, but if I'm lucky, pretty close.
I don't have enough miles on my GP5000s to know - I just started running them earlier this summer, and that bike has maybe 2500 miles - they look fine so far.
Lots of chip seal here and of course, tons of pot holes.
Non omnino gravis
Likes For DrIsotope:
Quoted: 18354 Post(s)
Liked 4,502 Times
For "road" tires, the Continental Gator Hardshells do pretty well. I don't keep track of exact mileage, but I think up to about 5K.
"Touring", and the Schwalbe Marathon Plus (as small as 25mm), and Michelin Protek Cross Max (32mm and larger?) do pretty well. They have a LOT of rubber, but a softer rubber than the Gator Hardshells, and thus wear through the rubber quicker, but have better traction too.
Oh, and quite a few FLAT-FREE miles with the Tannus tires.
Quoted: 645 Post(s)
Liked 797 Times
My last couple of Rubino Pro G+ rear tires, I got ~2500 from one and ~3500 from the next. The short-lived tire was used over winter, so wetter roads etc. In comparison, the corresponding front tire outlasted both (6000 miles plus), but when the 3500 mi rear tire started showing threads, I replaced the set
Liked 3,001 Times
I do this too. Sometimes. Sometimes I just replace the rear - particularly if I'm staying with the same tire type. But if I'm changing to a different tire type, for some reason I'm moved to replace both.
Later I look through my pile of old tires and I wonder why a perfectly good one is in the scrap heap.
Likes For MinnMan:
Non omnino gravis
But it's not what the OP asked. The very same goes for Marathons, and <shudder> Tannus solids.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I got a set of 700x30C tires to 5600 miles a few years ago, weighing between 155-165 lbs (sorry for the grainy picture):
Since then, most of my miles have been on 38+ mm tires so they either succumb to catastrophic injuries or the final results aren't in yet.
Registered User
Quoted: 188 Post(s)
Liked 276 Times
5,000 miles.
Old school Armadillo. 700 x 25 while training for a timed event with 10,000 ft of gain. Heavy stiff wheel used most of the year, many rides through the mountains, local roads, trails, and lot of pathlete miles as well as 30,000 ft climbing every month.
Did 7300 miles that year. Heavy tire but I wore that sucker out till the red strip was showing through but never flatted. Great because I needed something tough to get me through lonely roads.
Wore the heck out of it, then on event day, slapped on a Conti. Big difference but training is training and that tire was tough, heavy but tough!
Usually, a Conti 4000 I will get 2 grand.
Expired Member
Quoted: 3657 Post(s)
Liked 5,394 Times
I get 4000+ from GP4000s. I may replace them prematurely but they seem to flat easier as they wear down. Variety of road surfaces. Tire life rivals chain life in user variability
Administrator
Quoted: 11955 Post(s)
Liked 6,611 Times
Minor tweak of title, hope OP doesn't mind.
I think a lot of folks discount rider weight a bit. I used to get 5k out of GP4000's regularly. This was riding them down to where the cords started showing through and I never road on dirt roads. I weigh 135-140.
I've switched to the GP5000's and am getting less mileage. Under 3.5k which is a huge decrease, but I have been riding dirt roads a bit. I wasn't able to run them to the cords due to an abundance of little cuts in the tread that got me a bit worried.
Liked 3,001 Times
Of course, this is an apt place to add "YMMV"
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
I use GP4000/5000 tires and the limiting factor in tire life is almost never actual wear down to the cords, it's getting little nicks or gashes that I can't fix with superglue and I no longer trust. Usually it's after 2k miles or so, but there is plenty of tread life left based on the little wear indicators.
Likes For Dan333SP:
Quoted: 4559 Post(s)
Liked 2,802 Times
Probably depends on rider weight too. I'm down to 150 and tires seem to last a long time now.
We have the usual Southern/Midwestern mix of some smooth asphalt, lots of chipseal, gravel, and busted up neglected urban infrastructure. Despite it all, I've had relatively few puncture flats without resorting to Gatorskins or comparable lead filled garden hose, and no tire failures.
For the past couple of years I've mostly used cheap Continental Ultra Sport II, 700x23 and x25, on my road bikes. Going on 4,000 miles with the 700x25 set, including lots of hours on the trainer. Only the first wear dimple is nearly worn down, remarkably little wear for the use. I'm more concerned about a few nicks and cuts, but only one or two of those resulted in punctures. So far no signs of avulsion, so I'll keep watching and riding 'em.
And around 2,000 on the 700x23. Very little wear, no nicks. Very few hours on the trainer with this set, mostly outdoor miles.
I got less than 1,000 miles on a set of Vittoria's cheapie Zaffiros before the rear showed significant wear and cuts. Lousy riding tires anyway. For the same price the Conti Ultra Sport II are far better.
And I had to retire a Schwalbe One V-Guard after around 1,500 miles. The tire wasn't worn out but it was cut to pieces. Fragile tires. But sweet riding while they lasted -- grippy, quick, light, good even at lower pressure. It performed exactly as the rolling resistance site tests indicated. Too bad Schwalbe discontinued that particular model. It was great for chasing PRs/KOMs, or faster group rides. Probably the closest thing I've ridden to a racing clincher. I kept the front tire as a spare lashed to the saddle bag on longer solo rides in rural areas. It was still in good shape.
And on one hybrid, around 5,000 miles on Continental SpeedRides. The shallow file tread pattern finally wore down on the rear tire contact patch but it's still good to ride. That hybrid also doubles as an errand bike and occasionally hauls up to 50 lbs on the rear rack. I'll replace it with the same tire. The SpeedRide is an outstanding all around tire.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Non omnino gravis
Advocatus Diaboli
Liked 1,531 Times
Non omnino gravis
Well, I'm not using superglue to fill holes so much as I am to glue cuts back together, so they don't get any bigger. I've glued them this way both internally and externally. The particular type of superglue doesn't seem to matter. I've been using the Gorilla Super Glue for a couple of years now. Primarily because it's readily available locally.
Non omnino gravis
Incorrect, as has been shown empirically over tens of thousands of miles. I've saved several 700c tires from an early demise by gluing cuts shut. It's not hard. For frame of reference: R/C tires are glued to the rims with superglue, and those wheels can spin at several thousand RPM. I've made "hybrid" R/C tires by cutting two tires in half and gluing a left half and a right half together. Maybe you haven't used a decent cyanoacrylate in a long time, but with the proper adhesive (like MXBon 105) you could cut a bike tire in half and glue the ends back together.
But lots of people have ...
I have several tubes I have super glued tubes with pin pricks that gave lasted 2+ weeks. This clearly proves your statement wrong.
Likes For UsedToBeFaster:
