Sturmey Archer circlip installation?
Don't be a "Drew"
Ok is there a trick to install the circlip on a S/A hub. I've found that swearing at it doesn't help at all.
Mutt
Mutt
Quoted: 764 Post(s)
Liked 656 Times
There may well be a better way, but I tend to start with the back of the clip--the side away from the split--and work toward the split. Seems counterintuitive, but it seems to work for me. But you still have to swear at it. It seems to work best if you swear in a low, agitated tone.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 3804 Post(s)
Liked 6,643 Times
My technique is to put the opposite end of the axle in a vice, and then I hold one end of the circlip down with a thumb while I use a very small screwdriver to pry the opposite side into place. It usually takes a couple of tries, but I haven't had to swear much.
Neal
Neal
Don't be a "Drew"
Thanks guys, I used your technique Neal. I put the hub in the vise with my thumb at the 6 o'clock the gap on the circlip at 9 o'clock and used the screwdriver at 12 o'clock to pry the circlip on. Got it on the second attempt thanks, I knew you guys would know.
thanks,
Mutt
thanks,
Mutt
I always swear I'm going to buy the special tool. But I never have it. Instead, I scream. I cry. My fingers bleed. Then it snaps into place.
Palmer
Quoted: 1660 Post(s)
Liked 1,808 Times
For the uninitiated, it's not that big a deal, and it's not something that needs to be done very often. Still, I would not have you frustrated by this.
Bikes: 2010 Torker T-300, with drop bars. A vintage lugged Mercier 12 speed. A repainted, rebuilt 1986 Raleigh Pursuit road bike. 1988 Panasonic DX3000 is my fave new ride
I use a screwdriver to hold one end in place and pull on the other side of the circlip with vice grips. I find that if a circlip has already been installed and removed once, then subsequent remountings seem easier.
Also, you should double check that the thing is seated properly in it's groove. I've had them work loose before if not seated all the way.
Quoted: 11 Post(s)
Old thread I know but I just had the joy of this clip over the weekend. When I was done it was mostly OK, but a little loose (still seemed to be in the groove). Curious about the operation once the hub is fully assembled -- should I bother going back in to replace the clip for peace of mind, or is the clip more for the assembly process? Plus the clips seem scarce and hard to find.
Thanks much!
Graham
Thanks much!
Graham
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Graham, maybe you left out a spacer? Is the cog loose, or is it really the actual clip that is loose?
The circlip is the same as on many other hubs, including coaster brake hubs. Any bike shop that deals with one-speed coaster brake hubs should have a drawer full of those clips.
www.rhmsaddles.com.
www.rhmsaddles.com.
I place the circlip so that the opening is exactly opposite to one of the splines. Then i press it down with to fingers left and right of the opening. Then i stick a small screwdriver in between the spline (that is at 180° from the opening) and the circlip. Then i tilt the screwdriver to pull the circlip into position.
Likes For Kovkov:
Liked 6,643 Times
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
A little looseness is the norm AFAIK. Allows for imperfect chainlines to some extent.
Quoted: 11 Post(s)
Graham
multimodal commuter
Liked 574 Times
Thanks RHM -- my fault for referring to a different circlip. The one for the cog is no problem -- the challenging one for me is the small circlip on the axle that acts as a stop for the planet cage. The hub I'm working on is a 1989 AWC 3-speed with coaster brake. I can find some of these for sale in the UK but the shipping is $42 for a 39 cent part!
Graham
Graham
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 11 Post(s)
Quick response to my own post -- found a replacement circlip for the axle at the local ACE hardware store. One of those situations in which I was overthinking and assumed the part was a specialty item!
Graham
Graham
Quoted: 11 Post(s)
Just a follow up on this one -- did an end-to-end overhaul of the hub one more time and it is fantastic. Very smooth and solid as a commuter bike. The overall project looks like this:
Graham
- Old Raleigh Robin Hood Frame
- Rebuilt 700c wheels with alloy rims
- Single brake in the front
- 1989 SA 3-speed coaster brake hub in the back
Graham
