A knee friendly gearing solution for drop bar bikes
Bikes: Niner RLT 9 4 Star, Kona Splice, Nashbar Carbon road bike
Quoted: 49 Post(s)
Here is a amazing new product from Wolf Tooth components called the Tanpan that allows you to use 10 and 11 speed Shimano mountain bike rear derailleurs with Shimano 10 and 11 speed road shifters. Up to 11-42 cassettes with a double and 11-46 if running 1x.
Tanpan ? wolftoothcomponents.com
Even if you run a smaller 11-32 or 11-36 cassette plus a XTR derailleur you still get the extra benefit of chain retention of the clutch mechanism.
What do you guys think are you going to get one of these on your gravel bike? Opinions?
BTW, I've got nothing to do with Wolf Tooth components, just a interested customer!
Quoted: 1216 Post(s)
Liked 185 Times
To be honest any lower than 36x34 and I'm faster walking.
I think the technology is neat but the cost is pretty intense for the 1-bys and 40t+ cogs. Especially since I'm still running 9 speed Sora.
Quoted: 49 Post(s)
I'm a relatively fit rider and have trouble keeping a sustained reasonable cadence with my low of 34-32 on my carbon road bike on several of my local mountain climbs. Add a heavier steel or alloy gravel bike+bike packing gear for a over night trip and yes I damn sure need a gear lower than you can accomplish with current Shimano road components. I know I can't be alone here either.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
this would work nicely with a 49-46 or 46-43 front chainrings and a 11-42 11 speed rear
HTML5 Gear Calculator
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Bikes: quite a few
Heard about this one - it's cool but another moving piece to worry about maintaining (albeit a simple one). Using an old-fashioned double/triple without needing a clutch gives you tons of options.
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
You are a fast walker while pushing your bike.
Sora currently is 9 speed, so you are 'still running' the most up to date Sora group. Hardly ancient.
Quoted: 49 Post(s)
In my area of California I have mountain climbs with sustained 10, 15 and even 20+ percent gradients. Unless your a pro rider, gearing lower than a 34T small ring and 32T cassette would be welcomed by anyone.
Sunshine
Liked 7,484 Times
My point in the earlier post was that the gearing ratio listed nets a faster pace than walking. Spoon mentioned its faster to just walk if gearing were any lower and I responsed due to doubting that.
I have a 27.5gi at lowest based on 28x28and would for sure benefit if it were down to 24.2gi using 28x32.
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Seems like a great product! The DynaSys Shadow+ (clutched) derailleurs seem good for gravel bikes: large chain capacity and less chain slap.
Personally, I use a 9-speed RD-M772 SGS to run a large cassette on my 10-speed touring bike.
And, I use SRAM 10-speed gear on my carbon gravel/'cross bike -- SRAM 10-speed is cross-compatible and allows you to use a MTB RD with road shifters. Unfortunately, their 11-speed stuff is no longer cross-compatible.
Liked 185 Times
I'm currently running 26x1.9 so 90 rpm is 7.32mph and 60rpm 4.88mph. I generally get off and walk at between 30-40rpm after going from sitting->standing to try to drop my heart rate. Speed at 30-40rpm is between 2.44-3.26mph. It is very easy to walk faster than this, especially at race pace when I'm very warmed up and trying to be slightly competitive.
Previously I'd been riding a full MTB triple, but found using the small 22t ring caused my heart rate to go to high for too long and really hurt me later on in the ride. Easier to get off and walk for a few minutes than spin at a very low speed.
The reference wasn't to the age of Sora, but to the number of gears and overall placement of the groupset in Shimano's hierarchy. I'm still running 9 speed Sora, despite the fact that there are a lot of different, better options available on the market. Heck, full 105 is like $350!
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
This looks like a good product, and it gives you a much needed barrel adjuster for a shadow derailleur. Based on my experience with Travel Agents, I'd say threading the cable through there just right is likely to be a minor pain but once you get it set up right it should work well. The design is very simple mechanically, which is nice.
For those not wanting an extra part to maintain, Gevenalle makes shift+brake levers that work with Shimano 10- or 11-speed MTB derailleurs directly.
My Bikes
My Bikes
Sunshine
Liked 7,484 Times
If you are going to be pedantic to the point of using a decimal you should have requested my tire size first.
If I were to spin in the discussed gearing at 30rpm as you mention, I would probably fall over. 30rpm is a turn every 2 seconds...thats seriously slow when going up a hill. I would walk too if I were turning at 30rpm. I walked up a hill just last week actually, since I had to stop on the incline and couldnt get started!
I see what you meant about Sora. Its perfectly good stuff, but with how cheap the Euro retailers are right now, its not much of a jump to Tiagra and 105. I have thought about this a few times since my wife got a Cannondale Synapse last year with Sora.
Quoted: 18883 Post(s)
Liked 10,646 Times
I have a 50/34 and 11-28; so far this has been plenty for everything I've tried to ride up. But I bookmarked this in case that changes. I have a few challenging rides coming up.
These gravel bikes are hugely versatile, but the downside to this "one bike to rule them all" notion is that gearing is pretty light on the pavement.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Their Road Link would seem to allow the same result (brifter plus big cassette) so I guess which you pick depends on which parts you already have.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 49 Post(s)
How a gravel type bike that is going to be ridden off road and on light single track, I don't see how having a clutch RD would be a bad thing. You can find XTRs on sale for well below $200. Even if your only running a 11-28 or 11-32 cassette this would still be a benefit.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Good option for gravel riders wanting to run a clutched rear derailleur on a Shimano setup. I use SRAM 10 speed shift/brake levers on my gravel bike with a 12-36 cassette and 46/30 chainrings and a GX MTB clutched rear derailleur. Until now, there was no way to do this with Shimano levers.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Bikes: Yes
Liked 3,868 Times
You get used to it. Plus they work well enough that you don't mind.
My Bikes
My Bikes
Randomhead
Liked 3,696 Times
I couldn't figure out if Jtek made this particular combo or not. Seems like they do, but they have a lot of products
Bikes: Yes
Liked 3,868 Times
They do have a new design. The CX variety still works with road derailleurs, but there is a GX that works with Dyna-Sys mountain bike derailleurs (10- and 11-speed available). They also recently introduced a UX shifter which works with 8-speed Alfine.
My Bikes
My Bikes
I see that now. Interesting. That wasn't available 3 months ago when I was in the market.
