Dual coaster brake sprocket fit?
Old 12-01-19, 07:12 AM
Philphine
Quoted: 90 Post(s)
Liked 18 Times in 16 Posts
https://www.ebay.com/vod/FetchOrderDetails?itemId=264523065359&transactionId=2503554382016
I picked up this dual coaster brake sprocket 'cause i thought it was interesting (and fairly cheap), but it turns out it's too thick to put on the hub and get the retaining clip back on.
I just tried it on a random hub I had handy until I dig the bike I want to use it on out of its spot, so maybe I'll luck out and something about it will be different enough to make it fit. But if not, has anyone seen one of these and/or have any idea what might be needed to use it? Thanks.
Philphine is offline
Old 12-01-19, 08:11 AM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
I can't make it through the link due to being a completed transaction?
Got another link?
FiftySix is offline
Old 12-01-19, 09:57 AM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
Just googling the terms, all I pull up is hubs intended for tricycle use. A picture or better description would help.
It sounds like you have two sprockets next to each other on the same side of a hub, and I've never read of that before. And even looking at "Completed Transactions" on ebay doesn't pull anything like that, at least on the first page or two.
StephenH is offline
Old 12-01-19, 10:44 AM
Philphine
Quoted: 90 Post(s)
https://m.facebook.com/story.php?story_fbid=2519208608115155&id=100000781212963
another try from my phone. I don't have a home computer right now and have given up on photobucket anyway.
Old 12-02-19, 09:29 AM
Philphine
Quoted: 90 Post(s)
https://www.ebay.com/vod/FetchOrderD...fmPRcuzy_QUcGg
feeling dumber by the day. trying again
edit: ok, i think it worked this time.
Old 12-02-19, 10:35 AM
ceelint
^that guy^
ceelint's Avatar
Bikes: '17 Wabi Classic, '17 Trek DS3, '12 S-Works Tarmac SL
Quoted: 91 Post(s)
Liked 137 Times in 51 Posts
Nope^
ceelint is offline
Old 12-02-19, 11:21 AM
Philphine
Quoted: 90 Post(s)
Then I don't know. I was at the library and thought I fixed it. I could click on it there, and can now back on my phone.
but essentially, it's like a two sprocket cluster, a 16 and 19, but the center has the three nibs(?) that would slide onto a coaster brake hub. But its a little thicker than a normal single sprocket, just enough that i can't get the retaining ring back on.
but I guess I'll take it by the bike shop. Maybe I'm missing something.
Old 12-02-19, 12:39 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Log onto Ebay, do a search for 264523065359 and set search terms to include "completed listings" and that finally pulled it up.
Not that it helps me any, though. I can see how such a thing might be used, but it would be a major hassle to switch from one speed to the other on older bikes.
I would guess that it was made to work with a specific hub and/or frame.
Not so sure it even went on a coaster brake hub, could have been on some other type of hub.
Possibly ask in the "Vintage" bike subforum.
"Vintage 2 speed Bicycle coaster brake cog set ..I have no idea what or where this came from..says made in England on the back side the gear ratio is..16/19...We are currently going through a large inventory of old bicycle parts and accessories..please check back and see our other items, most of these items are NOS with normal 50 year shop wear etc"
StephenH is offline
Old 12-02-19, 01:54 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Does it say "Cyclo" on the back? Might have been for adding gears to a Sturmey-Archer hub.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 12-03-19, 09:29 AM
Philphine
Quoted: 90 Post(s)
i don't know. in this little personal comedy of errors i've misplaced the sprocket. i got the bike i'm thinking to use it on out and took the wheel off. i'm kind of optimistic because the normal single sprocket had some play behind the retaining ring. but now i can't remember where i set the sprocket.
but it's not a bike i ride regularly, so as long as i don't misplace the wheel (entirely possible if you haven't guessed that by now), i'll just set it aside until i can find the sprocket to try it.
no, not a drinker or illegal drug user. i'm just that absentminded.
Old 12-03-19, 04:11 PM
ThermionicScott
@StephenH found the auction pictures. I suspect that it's not a coaster-brake sprocket at all. (British) Cyclo was a very early manufacturer of derailleurs and freewheels: https://www.velobase.com/ViewBrand.as...a-86c769997c21
BTW, what do you have against drinkers and users of other substances?
RUSA #7498
Old 12-04-19, 09:38 AM
Philphine
Quoted: 90 Post(s)
[MENTION=101467
i've seen the bottle and the damage done, to paraphrase the neil young song.
still can't find the sprocket. when (if?) i ever get my hands on it again i'll let y'all know how it goes. thanks.
Old 12-09-19, 10:35 AM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
How about going with a Dingle Hub from Surly? Does your bike's hub have threads?
TugaDude is offline
Old 12-10-19, 09:46 AM
Philphine
Quoted: 90 Post(s)
no, it has the three detents (?, don't know what they might actually be called) like a normal coaster brake hub. sprocket still in hiding, so the idea is in limbo.
Old 12-10-19, 09:47 AM
Philphine
Quoted: 90 Post(s)
Old 12-20-19, 03:47 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
If you are attempting to install that on a Shimano coaster brake hub, it aint gonna happen. Even a semi thick powder coating on a Shimano sprocket will prevent the ring from seating.
SquidPuppet is offline
