Fixed gear with vertical dropouts, has anyone tried this solution?
I've got a bike that's set up fixed which doesn't have track dropouts. I can't get the right chain tension with my desired gearing and the gearing that gets good tension just bugs me... So, while pondering how make a chain tensioner for a fixed gear bike, I come across this video... Everything appears to work. There would be a bit more stress on the chain, but I can't see anything going catastrophically long. Has anyone run this solution?
I’ve seen this exact video! Tried it one time just for sh*ts and giggles and it worked.... for a short period of time. Personally no matter how much tension I had on the chain with the sprocket, the second I started hitting bumps and rough road the whole sprocket would dislodge itself and go flying down the road ahead of me. You’d be better of making one of those stripped down Derailer chain tensioning things!
Quoted: 4806 Post(s)
Liked 3,928 Times
My question: does it allow you to keep proper slack in the chain? The chain going tight is a bearing killer for hubs and BBs. i"m guessing that with a high quality crankset and hub (ie velodrome worthy hardware) this could work really well, but with adopted mediocre road equipment, this could be excessively exciting on a fast downhill.
Casualcoolguy, no, on a fix gear,you cannot use any sort of derailleur style tensioner because you will simply fold it up and destroy it the first time you forget you are on a fix gear and try to coast.
I"d rather go with an eccentric BB or hub to do vertical dropout and fix gear. (I do not know if there is an eccentric BB that will work in a standard BB shelll. White Industries makes a hub that works well.) But I"d search out an old 1980s Japanese sport bike or equivalent with horizontal dropouts and just live life the easy way. My winter/rain;city fix gear is just that. Started life as a Peugeot UO-8. Frame was replaced by a Japanese built Schwinn sport frame, then a Sekine, then a Miyata 610 and now a Trek 400 (?). All with sport geometry and horizontal dropouts. (Early-mid '80s were the golden years for bikes. The Japanese had standardized the thin tubed steel frame and threads that everyone around the world had to copy if they wanted sales. You could pull the parts off one bike and put (almost all) of them onto your replacement frame. Might need seatpost and headset. Everything else just dropped on.
Ben
Ben
Quoted: 2952 Post(s)
Liked 3,106 Times
That looks hella sketchy.
The other thing you can try is a "magic gear combination." Basically a chainring x cog combination that allows for a chain length that perfectly fits the BB--dropout distance.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
As is often the case, Sheldon Brown documented the idea long ago: https://www.sheldonbrown.com/tandem-build2.html#okeefe
Ben
Ben
oh good point I totally blanked on the fixed part hahah I assumed it was a single speed thing
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I once fixed a V-dropout bike with a half link. Worked well with my preferred chainring and sprocket. I also wouldn't be afraid to file the lead or trail edge of the dropout a tiny bit if it was close.
Ben
Ben
How did I not know that a half link was a thing? That will do it, even if it doesn't look as cool.
Another Option
Something I've done a few times is use a quick release axle and just cut the axle so it doesn't protrude beyond the lock nuts. This gives you a little wiggle room for chain tension. Note: I wouldn't attempt this unless you're using a good quality, closed cam skewer and it's done up tight. Sheldon Brown offered it up as an option, and I've had good success with it. YMMV, and I'm not responsible if you die a painful death. You can also get a similar result by filing a solid axle on two sides so you can rotate it to give you a little more tension. I've tried the ghost ring option and frankly, I'm just not a fan.
I was going to suggest the half link. I've never had to use them, but they seem to be a good way to fine tune the chain length. Good to see that they do work.
Quoted: 99 Post(s)
Liked 115 Times
This idea with the floating chain ring: we used to use that in the Tandem Club as a way of taking the slack out of the chain that connects the two bottom brackets, rather than the final drive chain. It worked.
Liked 3,928 Times
Half links work very well. I clean the threads (on half links with threaded pins) and use Loctite red. From then on, I break the chain away from the half link. Other half links use a cotter pin like a sailboat shackle. You have to treat them like a sailboat shackle but they are very secure if you do so. (I've trusted my life to those cotter pins many times as an ex-sailor.)
Ben
Ben
Well, the floating ring didn't end up working for my bikes geometry. Too bad. With the dingle cog in there, the outer gearing combo meant that even a tiny 24T ring would rub the inside of the chainstay and at the same time not give enough help to make the chain tension work.
It's now sitting pretty with a half link and the axle is still far enough back to clear full fenders so it's my ultimate dirt road bike for wet days.
Quoted: 49 Post(s)
Liked 11 Times
You think you've seen everything until something like this pops up.
It looks like it would work for general straight line a to b commuting, but throw any kind of variation in there, or stick it in an urban environment and I would suddenly feel very sketched out.
Some people suggest half-link links, but I'm surprised that a half-link chain is rarely mentioned.
Try a half-link chain.
Liked 2,568 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
rookie
Bikes: bridgestone, ave maldea custom fixed gear
rookie
Old fart
Liked 3,400 Times
Likes For TejanoTrackie:
Here's a somewhat automated way to see what might work. I wrote the function in matlab, but it should work in octave as well (haven't tested there). Enter distance in inches between crank axis and rear hub axis and the number of chainring teeth. Function returns chain length for given chainring with a range of rear cogs (12 - 22 teeth). For example, P = chain_length(15.5, 45) returns: P =
45.6960
45.9193
46.1435
46.3684
46.5942
46.8209
47.0483
47.2766
47.5057
47.7356
47.9664
Possible "working" combinations would be those close (<0.06" maybe) to an integer value. In the above example, 47.0483 (18 tooth cog) and 47.9664 (22 tooth cog) look promising.
___________________________________________________________________________________________
function [P] = chain_length(L, Tf);
% Returns chain length based on L (distance between crank axis and hub axis, inches)
% front sprocket size (Tf, # of teeth), and an array of rear sprocket sizes
% (12 - 22 teeth). A vector of 11 chain lengths is returned, each element corresponding
% to a rear sprocket size.
Tr = [12 13 14 15 16 17 18 19 20 21 22]'; % # teeth on rear sprocket
r1 = 0.25/sin(pi/Tf); % (PD = pitch/sin(pi/Nt)), pitch = 0.5"
r1 = r1*ones(length(Tr), 1);
L_t2 = length(Tr);
r2 = zeros(L_t2, 1);
for i = 1:L_t2;
r2(i) = 0.25/sin(pi/Tr(i));
end
theta = asin((r1 - r2)/L);
x = L*cos(theta);
% P = 2*x + (pi + 2*theta)*r1 + (pi - 2*theta)*r2 % "continuous" length,
% scalar
P1 = 2*x;
P2 = (Tf*0.5)*((pi*ones(L_t2, 1) + 2*theta)/(2*pi));
P3 = (0.5*Tr).*((pi*ones(L_t2, 1) - 2*theta)/(2*pi));
P = P1 + P2 + P3;
45.6960
45.9193
46.1435
46.3684
46.5942
46.8209
47.0483
47.2766
47.5057
47.7356
47.9664
L_t2 = length(Tr);
for i = 1:L_t2;
end
x = L*cos(theta);
% scalar
P1 = 2*x;
P = P1 + P2 + P3;
If you want to be able to lock up the rear wheel reliably for a skid stop, you need an eccentric rear hub. With vertical drop outs, I'd either get an eccentric rear hub, or I'd just ride single speed.
rookie
yeah I guess eccentric hub for the rear must be real solution if you wont resort to the other proposed solution i.e ghost ring, rear derailleur, or filing the dropouts..
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Ben
Ben
Mind you, I’m just running SS, not fixed, but the semi-horizontal dropout makes it a cinch either way. I have two spots on the dropout where my 42/16 could work, depending on chain length.
Otto
