Full Fenders with Minimal Tire Clearance
Updated 2/10/21
I went for it. Pictures below if you're interested!
I never really planned for fenders when I specced my bike originally but now I kinda like the idea of a clean drivetrain and dry feet. I would like to run full fenders. Can it be done? If so, how? Creative solutions welcome!
The pictures below are with my winter tires, 45NRTH xerxes 30c, Wabi special frame 55cm.
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
There is not a great deal of clearance, and the aggressive knobs on the tires will facilitate gravel pick-up that could jam between the tire and the mudguard. At a minimum, this will cause a lot of noise as the gravel is pulled through to the end of the mudguard. Worst case, the wheel locks up. On a rear wheel, this will cause a skid, which you may be able to control. On a front wheel, this can cause a face-plant.
Less aggressive tire tread, narrower profile tires, and/or smaller radius wheels will minimize this risk.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
^ Everything John said. You don’t want your username to apply to you, do you PeopleAreIdiots ?
Likes For ThermionicScott:
I mean obviously guys come on, I'm not that much of an idiot . I'm fishing for some crazy, out if the box, jury-rigged work-arounds here fellas! I'm sure this isn't an uncommon dilemma around here since most of us ride bikes with relatively limited clearance.
I can handle the boring solutions on my own : N+1 winter bike that i don't really need.
Old fart
Liked 3,396 Times
Anything else, you pays yer money and you takes yer chances.
Likes For JohnDThompson:
Good point. I find it fun to scheme about these things though at least. I wonder if somebody has made some kind of bracket that can bypass the brake bridge so you can mount the fender a bit further from the tire. That's more the type of thing I'm envisioning.
Quoted: 1332 Post(s)
Liked 398 Times
Maybe something like this? https://www.universalcycles.com/shop...65&category=79
Likes For seau grateau:
Quoted: 1324 Post(s)
Liked 927 Times
Where do you plan to ride the bike? On the road?
You sure don't have much room between that rear tire and the seatube. I think that between the seatube and brake bridge you might like a clip on fender that clips to the seatube. However that would not be a full fender going all the way to the chainstays. With those tires i think full fenders, knobs on the tire and a piece of strong road debris will equal tire lockup. If in snow or mud then you might get it so packed that the wheel won't turn. that happened to me once when i road through a park here and went off the paved trail. I didn't get far before the wheels wouldn't turn. And that was with less aggressive knobs on my Schwalbe 30mm CX Pro tires.
If your brake bride was straight I'd suggest maybe putting your rear fender over your brake bridge. I did that with one bike I had years ago. On the front fender I drilled a large hole in the top of the fender, removed the front fork and then took of the crown race, put the fender onto the fork and put the crown race back on over the fender and then put the fork back onto the bike. Lots of clearance then.
Cheers
Cheers
Quoted: 212 Post(s)
Liked 83 Times
I don't think there's any hope with that frame, those tires, and a traditional full fender like the SKS Longboards or the PDW Full Metals. I have SKS, and although they're not bulky they would probably not work with that little clearance.
Something crazy, thinking out of the box... how about putting those tires on an inexpensive winter frame with adequate clearance? Nothing wrong with N+1 if it's to fill a need not met with your current assortment.
I really love riding my Synapse, but added the Quick for that reason; to meet some needs that weren't handled by the Synapse alone. The Quick is the bike I put mudgards on, for example.
I've jammed 28's and fenders into 90's race bikes by using split fender brackets, which will solve your problem at the brake bridge and fork crown. I made my own by bending rear rack stays in a vice, but if i had to do it again I'd just order some from River City Bicycles.
You may have issues at the seat tube, I've solved this either by cutting the fender short so that it ends just above the closest point between the seat tube and tire, or by cutting a little window for the tire at this point, and keeping the normal attachment points. The first solution reduces coverage, subjecting your drivetrain and shoes to more tire spray, the second weakens the fender, which may or may not lead to it cracking, depending on fender material, how big a window you cut, and how har on the bike you are. If you get creative with zap straps and tubes you can make a very low-profile shield for the area where you lost coverage.
If you want to get funky with fenders, I suggest purchasing a Dremmel and developing buddhist monk level patience. Based on your pics, I see no reason why full fenders wouldn't fit that bike. It's just going to take some doing. I'd source some bolts with very low-profile heads, similar to a carriage bolt, to improve clearance inside the fender.
Smaller, less knobby tires, and less time on trails or snowpack will improve your chances of success. That being said, here's my setup, which never jammed in the snow:
Likes For tashi:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I ride this bike everywhere. But yeah, mostly paved surfaces. I live in Chicago so during the winter I'm frequently riding through snow banks and unshoveled, icy paths, hence the knobby tires.
Yeah that's my reasonable option. Despite the fact that I'm constantly fantasizing over new parts and builds, I kinda like having only one bike actually
Now thats what Im talking about!
Liked 927 Times
Cheers
Quoted: 6945 Post(s)
Liked 10,945 Times
You could run Race Blades, but those are only slightly better than running no fenders at all.
Best bet is to buy a frame with more clearance, or keep your frame and buy 25mm tires.
Likes For Koyote:
Quoted: 1062 Post(s)
Liked 665 Times
While not a perfect solution, on one bike I mounted a rear fender above the brake bridge. There is also a front fender that starts behind the fork and doesn't actually go under it. You don't have any brakes to keep clean anyway.
https://www.amazon.com/SKS-S-Board-Front-Bicycle-Fender
Oops, noticed that Meile Man had the same idea.
I've never used fenders before, especially not in snow, so I don't really have a good frame of reference here. It sounds like fenders in snow isn't the best idea in general(?) Or is it more about making sure clearance is maximized?
The other thing I'm curious about is if went for this and retrofitted fenders to this bike, would I actually be able to tell a huge difference in rain and snow? Or would the costs (I'm speaking more in terms of ride quality/inefficiencies rather than monitarily) potentially outweigh the benefits compared to a seat tube mounted splashboard type fender (which is what I use now)?
For clarification, here are a couple more complicating factors of my build that I haven't mentioned:
1. The tires pictured I use only in winter. I'm ordinarily running 'non-knobby' 28c GP4Ks.
2. I have a front disc brake which may complicate front fender setup(?)
3. They way I have my gearing set up, I can switch between 17 and 19 tooth cogs using the same chain, however this obviously means shifting the wheel about 1cm or so back and forth in the dropouts.
Thanks for indulging me fellas!
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I run tight fender clearance on my winter bike (with studded tires) and have had it load up with snow and bog the bike down. Never locked up a wheel though.
Liked 665 Times
There's a tradeoff between clearance and protection. I think you generally want enough clearance so a "typical" piece of gravel stuck in your treads won't hit the fender. On the other hand, more coverage will keep your bike cleaner. I don't think it affects ride quality, especially given all of the other encumbrances such as bulky clothing, boots, and studded tires.
I'm afraid that my winter bike is no longer single speed. I just strung up an old Sturmey Archer 3 speed coaster hub for it. There's a hill where, if I stand up to pedal, I lose my traction, so having a lower gear helps me push through that stuff.
I definitely prefer to have fenders on my winter bike. In my locale, they spread a mixture of salt and sand on the streets, so it gets mixed with the slush and all gets slung up onto the bike. I rode my summer bike one day because I thought the streets were clear, and it was covered in sticky grit when I got home.
Cool. Not a bad choice of hub for bad weather if you ask me. When I rode in Pittsburgh I would always have issues with traction on hills in the snow. I find riding fixed really helpful for that though since you get more immediate road feedback. I just gear down in the winter in general for that reason.
I'm approaching tire clearance limit on my Cannondale Topstone with the stock WTB Nano 700 x 40 tires. I am currently running the linked SKS Speedrocker fenders. There is not much clearance, but they are rock solid thus far. The rear is more of a challenge due to having to run the fender under my rack seat stay mounts, but it works.
Quoted: 5223 Post(s)
Liked 3,579 Times
fenders don't always have to be jammed between frame parts & tires. I have cut fenders (front & rear) & mounted them (w/ extra hardware) further away from the tires than a regular installation. the rears requiring additional customization. Your front fender mount (out-of-the-box) would save a ton of time & trouble! very nice !
at the seat tube I have used cut plastic
not elegant solutions, I know
Likes For rumrunn6:
Liked 3,579 Times
Liked 3,579 Times
[Update]
Been meaning to update this thread for anybody in the future who wants to do something similar. I ended up retrofitting some fenders onto the Wabi right as winter got underway. Its been serving me surprisingly well! Can't believe I didn't try it earlier.
Likes For PeopleAreIdiots:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
On a singlespeed, rear wheel removal can be a chore with fenders. When I mount fenders on mine, I switch from GravelKing SK 38s to GravelKing 32s ( the slick version) to eke out a little more sliding space.
Likes For Rolla:
