Muriatic Acid... and a theory on why it works to remove stuck bicycle parts
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
Muriatic Acid... and it's potential to remove stuck bicycle parts
I subscribed to "Project Farm", as I find a lot of the experimentation done by the gentleman to be either directly connected to something that might be of use to myself, and enjoy his scientific methods he's devised. Anyway, I think I skipped this video initially, because... because I didn't think molasses would dissolve rust (actually, I'd never heard of it being used that way). Anyway, again, I happened to watch this video today, and found the muriatic acid to be of great interest to the potential job of freeing stuck bicycle parts. Why rust removal is interesting, and rust can be a problem on old bicycles, the corrosion between steel bicycle frames and aluminum bicycle parts is often stated as the likely cause for stuck parts. The oxidized aluminum "swells" and tightly sticks the part to the steel surrounding it. The muriatic acid in the video actually dissolves the rust, steel and aluminum.... I wonder if it would dissolve aluminum oxide? Anyone have experience with it?
I have used muriatic acid to clean rust off of metal before but I wouldn't put it near anything with a paint or plated finish. If you use it please do so outside, the fumes can be quite severe. It is quite powerful in undiluted form and if not neutralized afterwards a film of rust can start to form immediately on the cleaned parts in the open air.
Quoted: 1106 Post(s)
Liked 1,326 Times
The main difficulty is loosening stuck parts is getting whatever agent you are using into the area that is stuck. Muriatic acid (HCl) removes rust, yes, but if you have a stuck cup in a shell it'll take so long to remove what matters that it might remove something (or a lot of something) else. I like heat + penetrating oil + time.
For bare steel parts HCl works good enough, but there are better ways; the best is electrolytic derusting. You can do a whole frame inside[1] and out with a windshield washer pump and a box lined with a sheet of 6-mil polyethylene. Set it up and come back whenever, when it's done the reaction stops. Moderately rusty car wheels take a day or two.
[1] well not inside of the the top tube (or any others) if it's closed at both ends.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Muriatic acid is just a common name for hydrochloric acid. Read an MSDS on it sometime and you won’t use it.
I’m a licensed professional chemical engineer with no inherent fear of chemicals but lots of respect. Home gamers tend to not use nearly enough personal protective equipment when dealing with the more serious stuff.
Lye is another one I see people toss around (sodium hydroxide) is another to be careful with. Worst accident at a plant in my career was with lye. 29 year old employee was blinded, father of two. Life altering. He took a shortcut without prescribed PPE.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I know enough chemistry to know that I wouldn't want to be messing around with HCl in my garage. I don't know enough chemistry to do it safely.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
I know enough to not get it near any bleach
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Better Living Through Chemistry, Rather Then Dying Of It
Isn't that ammonia?
I recently successfully used ammonia to free up a heavily oxidized stem and a seat post too, as ammonia dissolves aluminum corrosion, but leaves steel and aluminum well enough alone. Over a week and a half I first used penetrating oils and then ammonia, and judging from the corrosion on the aluminum posts, aluminum oxide was the sticking point. I used ten and twenty pound weights as impact hammers. After a few days of ammonia, both started to move and the game was won. There was evidence on the posts of dissolved corrosion, but not of penetrating oil. (Sure, the ammonia may have rinsed it away.)
I know Sheldon suggests this but I've not read of anyone having any success with this approach.
It worked for me?
(Both the seat pillar and the stem emerged in functional condition, which really didn't matter too much as they are not of any significant interest. The frame, however, is very interesting and unscathed and so far, enigmatic and unidentified.)
It worked for me?
Either ammonia or bleach, when mixed with HCl, can release chlorine gas.
Back in the old days, we had home economic class for the girls and shop class for the boys. All the girls learned to not mix ammonia with bleach, among other things that they wouldn't tell us about. In shop class, we learned not to goose anybody with an air hose. Both items of importance.
SE Wis
Liked 3,390 Times
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Breathe Deep
Ammonia mixed with bleach produces chloramine, which is irritating but not as deadly as chlorine gas?
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
Mixing ammonia and hydrogen chloride will only result in ammonium chloride which is a solid and not toxic. It’s used in baking and is used in salmiak licorice. It gives the licorice a slightly tart taste. (I wouldn’t know from personal experience as I detest licorice.)
Mixing bleach and hydrochloric acid will release chlorine.
I will agree with others that muriatic isn’t something that should be used lightly or by people who don’t know what it is. It’s a strong acid and the concentrations I’ve seen on SDSs from Home Depot say give concentrations of from 20-30%. Concentrated hydrochloric acid for laboratory use is about 35% and is considered extremely hazardous.
Stuart Black
Stuart Black
Half way there
Quoted: 986 Post(s)
Liked 880 Times
There was a research group in Italy that did some work on analyzing pool water for elemental phosphorus as a bio-indicator for urine load. They presented some remarkable numbers of the average user urine contribution. I'd advise keeping one's mouth closed when in a public pool.
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
Original poster... and, maybe I shouldn't have even brought up the potential use of muriatic acid as a bicycle part dislodging agent. I was just theorizing that the reason that aluminum parts get stuck in steel bicycle frames is that the two dissimilar metals are subject to galvanic corrosion. The corrosion, or oxidized forms of the steel and aluminum (ferrous oxide and aluminum oxide) end up squeezing the joint more tightly together, because the oxidized materials take up more physical space. So, assuming you have both of the oxidized materials present, which material is the easiest to eliminate (and thus free up the joint)?
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Rust Never Sleeps
I use ammonia to dissolve the aluminum oxide and a variety of penetrating oils for the ferrous oxide. Combined with vibration and then impact hammer type application of force, it has worked without fatally damaging a frame or a seat or stem.
(I've been lucky I suppose?)
Likes For machinist42:
Bikes: Specialized Epic Competition, Specialized Sequoia, Rocky Mountain Sherpa Touring, Rocky Mountain Fusion, Raleigh Challenger, Raleigh Cetury, Raleigh Rocky II.
Liked 7 Times
I have heard once before that ammonia will dissolve aluminum oxide and I am glad to see this report of success with it. I have a Vintage Norco road bike that I have been bringing back from the brink that has a very stuck alloy stem. I thought that I would cut the stem to pieces and save the nice fork as a last resort. Here's hoping ammonia will do the trick.
Likes For howie2wheels:
Liked 4,212 Times
You are correct that chloromines give pools that characteristic odor, but they are the byproduct of the disinfection process, not the agents. Having dealt with the long standing complaints of chlorine odors/irritation/and other claimed health effects from staff, patients, and other patrons at a therapeutic pool, I learned much more than I ever wanted to about chlorine odors around pools. A chlorine agent added to pool water reacts to form hypochlorous acid, a strong oxidizing agent, which then reacts to kill microbes, but also reacts with any other nitrogenous compounds present to form chloromines. The primary source of these other nitrogenous compounds is human sweat and urine. If you want to reduce the chlorine smell you have to be firm about hygiene with the pool users. The management folks for the pool that I consulted on resisted addressing this issue with their clients for fear of offending/embarrassing them. Many of these users were not agile enough to climb out of the pool to use the bathroom (and who really wants to leave a heated pool and be chilled by the room air). Many of them were incontinent to some degree. It was a tough problem to solve and I'm not sure they ever did.
Stuart Black
Stuart Black
SE Wis
Liked 3,390 Times
Most large drinking water systems have gone to chloramine as the secondary disinfectant due to it's longer lasting residuals and a lesser chance of forming disinfection byproducts like trihalomethanes. Usually by using chlorine as a primary disinfectant and injecting ammonia to create chloramine as it heads out into the distribution system.
Randomhead
Liked 3,692 Times
has anyone tried an ATF and acetone mix?
Thrifty Bill
Liked 964 Times
Yes.
Everything works sometimes. Nothing short of cutting out works all the time.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Likes For wrk101:
