Indoor Trainer and Sweat
Quoted: 4227 Post(s)
Liked 2,488 Times
did you look at the link i posted? Or just google sweat corrosion on trainers, people have damaged bars, stems, even BB areas on aluminum frames from sweat
the damage is most common under bar tape where it can't be wiped off and is allowed to sit and not evaporate as quickly
Quoted: 550 Post(s)
Liked 325 Times
From reading, the Climbing Blocks are higher than Leveling Blocks, correct? So if my intent is to just level the bike and maybe secure the front tire (was using two pieces of wood, but then the tire turns), I should just go with the Leveling Block, sound about right?
I've read sweat is a big problem so suggestions are: Go shirtless, have a fan or two blowing on you... after that I've seen a few suggestions for protecting the bike.
Use the most powerful fans possible. Think industrial air circulators, not plastic box fans.
Put a training mat beneath your bike. That will protect your flooring from sweat and mean less noise transfers to the rest of your home.
Sounds like buy a bunch of huck towels and drape one over each handle bar, over the headset, over the top tube and someone suggested sticking one in the back of your shorts to catch any back sweat that drips down. Then I've also read about saran wrapping stuff. What is that all about?
Your bar tape would get gross, but you're probably going to ride on your rubber hoods that are conveniently water proof.
Don't over think it.
I've also read to not ride out of the saddle as it puts odd torques on the bike when mounted to the trainer. Sound about right?
Bike Noob
If only it were that simple lol I open my basement window to get into the mid to low 50's and I still run 3 fans (2 lasko pros, the defacto gold standard for indoor training, and a lasko cyclone which isn't as good) and I'm still sweating from the effort. Don't get me wrong, the fans help big time for my core and the sweat evaporates pretty well there, but my head sure gets sweaty. Just for context, and interval where I'm doing 260w is giving off 3 times as much in heat (780w)
I keep a towel handy and during rest intervals wipe the bike as I go along. If I'm dripping a bit more than usual I just drape my hand towel over the stem but I'm usually not and can just wipe my brow.
That's indoor basement temp in my finished basement, we've had a few mornings in the teens here in the Boston area. My basement can get into the upper 40's during the winter, at least that's as low as I can remember. It's definitely a lot more bearable than when my indoor temp goes over 65
Quoted: 1975 Post(s)
Liked 232 Times
likely your bike has paint, whereas bars and stems are anodized which is usually a pretty thin layer. The shifters can nick the alumimum near the drops which exposes bare aluminum that makes them susceptible to corrosion, and bar tape holds moisture and salt against those parts for extended periods of time often likely not ever drying off if someone is doing trainer sessions daily. Finally galvanic corrosion between dissimilar metals(and carbon) in contact speeds up the process exponentially.
Likes For redlude97:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
I've read sweat is a big problem so suggestions are: Go shirtless, have a fan or two blowing on you... after that I've seen a few suggestions for protecting the bike. Sounds like buy a bunch of huck towels and drape one over each handle bar, over the headset, over the top tube and someone suggested sticking one in the back of your shorts to catch any back sweat that drips down. Then I've also read about saran wrapping stuff. What is that all about?
YMMV, but I've found that a very thin summer jersey or gillet is cooler than riding with no shirt at all. It helps wick moisture away from the skin and has a cooling effect. FWIW, I grew up and live on a farm in the delta/swamp, and old timers have always known that a ventilated hat and a thin shirt are cooler than running around shirtless.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
- Graphite
- Palladium
- Platinum
- Gold
- Silver
- Titanium
- Stainless steel 316 (passive)
- Stainless Steel 304 (passive)
- Silicon bronze
- Stainless Steel 316 (active)
- Monel 400
- Phosphor bronze
- Admiralty brass
- Cupronickel
- Molybdenum
- Red brass
- Brass plating
- Yellow brass
- Naval brass 464
- Uranium 8% Mo
- Niobium 1% Zr
- Tungsten
- Tin
- Lead
- Stainless Steel 304 (active)
- Tantalum
- Chromium plating
- Nickel (passive)
- Copper
- Nickel (active)
- Cast iron
- Steel
- Indium
- Aluminum
- Uranium (pure)
- Cadmium
- Beryllium
- Zinc plating (see galvanization)
- Magnesium
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 2952 Post(s)
Liked 3,106 Times
I had to destroy a Al seatpost that got galvanically welded into a carbon frame. I don't know if it was exacerbated by getting some sweat wicking into the interface, but that seems like a possibility.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Everyone says go outside, try that on an icy roads/trails at -10 to 20 degrees without the wind, you will find its better to be inside with a fan and a window cracked on Zwift.
Temperatures aside the danger of slipping and hurting yourself is a risk I prefer not to chance. I ride in the winter when the temps are decent and the roads are CLEAR, but not otherwise. Also cars slip too, slip into stuff, poles, cars, cyclists.
I cover the bike from my sweat on the indoor bike, sweat tears up stuff so bad on the trainer. Its gross too. Towels work fine, I buy them cheap from where ever and have my wife cut them 1/2 and hem them. Get more towels that way.
Likes For sdmc530:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4383 Post(s)
Liked 3,016 Times
[QUOTE=am0n;21217900]
Perks to using one of those thongs/guards versus just draping a towel over the TT and headset? ]/QUOTE]
I do both
I do both
Liked 1,938 Times
Oh, OK. In the PNW where I live (and I think not everyone lives in CA or the deep south), using my resistance rollers in winter, and in summer when it's raining, is much more productive if one counts all the time spent dressing, undressing, cleaning, lubing, etc. The single I use on my rollers never flats, never needs cleaning or lube. I put on a T-shirt, shorts, socks, gloves, and shoes and ride. When I'm done, I change into my civvies. So there's that.
Further, the actual time spent on the rollers is better training. There's no moment when I'm not fulfilling a very specific training goal. There are no stop signs, traffic lights, or indeed any reason not to pedal the entire time, especially since there is no coasting, only climbing or flats. Plus the rollers improve my spin, balance, and bike handling. Yesterday I warmed up for 15', then did 45' continuously in Z3, no breaks no letting off, just steady as possible at 144w. I know, not much, but it is what it is. Legs hurt like the very devil at the end. Not bad for a total of 1:15 spent messing with the bike and clothing. Today is another hour, but steady-state Z2, only 131w. Tomorrow I'll do my very first FTP test with my new PM using the CTS Field Test, right here in my 50° shop with a big fan blowing on my T-shirt. Then a day off, then out on the wet roads for a 40 mile group ride.
In good spring and summer weather, I get out for at least one midweek ride, but still do specific work indoors on the rollers, usually just an hour of steady VT1 work. So that's how I've been doing it here for over 20 years. Yes, I've gotten very good results from fulfilling specific training goals every time I get on the bike.
Results matter
Results matter
Quoted: 590 Post(s)
Liked 445 Times
I just use a stack of books to raise the front wheel to the desired height, typically with a little incline, or I add another book if I'm doing out of the saddle training. Pretty soon we'll all have Lazy Susan's under the front wheel to take advantage of the steering capabilities currently being rolled out by Zwift.
Yes but haven't broke or damaged any of my bikes. My first trainer was in 1988 and that caution was floating around then. My 2 cents, don't fall over and you'll be fine.
