Go Back  Bike Forums > Bike Forums > Framebuilders
Changing Head Angle
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Changing Head Angle
Old 05-03-20, 04:59 PM
TiHabanero
Quoted: 1744 Post(s)
Liked 1,370 Times in 719 Posts
Changing Head Angle
Just rode a new frame and have found that I pushed the envelope too far with the head tube angle. Thinking about how to change the head angle I came up with removing the down tube, bending the head tube/top tube to get to the desired head angle (needs to move about 3 degrees) to steepen the angle. Any thoughts or is it replacement of the top tube/head tube/down tube and rebuild the front triangle?
TiHabanero is offline
Old 05-03-20, 06:28 PM
Canaboo
Quoted: 49 Post(s)
Liked 13 Times in 12 Posts
How is it joined?
Canaboo is offline
Old 05-03-20, 08:54 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4201 Post(s)
Liked 3,857 Times in 2,305 Posts
3 degrees of bending? That's a lot IMO. Better to remove the HT and see if the existing TT and DT can be remitered for the new head angle. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-04-20, 04:09 AM
guy153
Quoted: 321 Post(s)
Liked 263 Times in 212 Posts
I agree with Andy Stewart better to remove the HT altogether. But why not instead make a new fork for it? Give the fork enough offset to get your trail back where you want it. Then the existing fork can be re-used on another project.
guy153 is offline
Old 05-04-20, 04:37 AM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
What kind of frame and what is the current head angle? I doubt you could have gotten it that wrong.
dsaul is offline
Old 05-04-20, 04:52 AM
TiHabanero
Here is what happened. I designed the frame around a 60mm fork rake, then changed my mind on the fork as I wanted the bike to look more modern, but the frame was already built by that time. Decided to install a 45mm rake fork and try it anyway. It is ridable, but rides like a chopper, lots of rise and fall with the front end, and it is a handful in high winds. The frame is lugged and figured redoing the whole front end of the bike would be best, but figured if there was a short cut, someone here will know.
Old 05-04-20, 06:58 AM
dsaul
Quoted: 714 Post(s)
What is the purpose of the bike? Road, gravel, touring? My bikes vary in trail from about 60mm on the road bike to 75mm on the gravel bike and 90mm on the MTB. The longer trail bikes are not so easy to ride with no hands, but winds don't seem to be a problem. The only time I have problems with cross winds is with a deep section front wheel.
It just seems like a radical approach to re-build the front triangle, when riding the bike a few more times might allow you to become accustomed to the way it rides.
dsaul is offline
Old 05-04-20, 07:15 AM
Trakhak
Trakhak's Avatar
Quoted: 2482 Post(s)
Liked 2,952 Times in 1,677 Posts
That's a sensible suggestion. I bent the (steel) fork on a 1986 Cannondale in 1990, left it unused for 20 years with a vague plan of replacing the fork, and then started commuting on it. Took a few rides to get used to the handling, but I've since ridden it for a good proportion of my annual mileage.
Trakhak is offline
Old 05-04-20, 07:58 AM
mikeread
Quoted: 45 Post(s)
Liked 44 Times in 23 Posts
Would a straight blade fork with 60mm rake look modern?
mikeread is offline
Old 05-04-20, 08:22 AM
unterhausen
Randomhead
Liked 3,696 Times in 2,517 Posts
have you put your proposed numbers into a trail/flop calculator? 45mm rake fork is going to need a steep hta to get it to reasonable flop. What is the current HTA and proposed HTA?
Seems like it's time for a new frame, chalk this one up to experience. But if you really want to do this, replace the TT/HT/DT.
unterhausen is offline
Old 05-06-20, 05:12 PM
TiHabanero
I find my trail preference is between 71-73 mm. I have considered a straight blade fork with 60mm taken but need to draw it to get an idea of how it will look. As it is, I will give the thing another ride and see how it goes.
Old 05-06-20, 05:24 PM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times in 104 Posts
A 7 degree fork crown with a 390-400 ac would get you really close to 60 mm.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Old 05-06-20, 09:14 PM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times in 337 Posts
I agree with Andy too. Shouldn't be too hard. Don't think I'd work too hard saving the lugs though, although that's possible.
Nessism is offline
Old 05-06-20, 09:53 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
Rodriguez had someone contract build them bunches of 55mm rake forks (1&⅛) for their disc braked bikes. You might give them a call. Maybe they have one on the shelf.
Rodbikes.com
55mm is not 60mm, but it'd get you closer than you are. They are aluminum, smooth, disc. Nothing retro or lugged about 'em.
They also do custom to whatever your specs are.
Mine is 55mm rake for a 26 inch (559) wheel for a 69 degree head tube angle. ~55 to 62mm of trail depending on tire.
base2 is offline
Old 05-06-20, 10:10 PM
TiHabanero
I believe I will try to save the head tube as it is special to me. Last of the 531 tubes my brother gave me, and replace the lugs and TT/DT. Winter project.
Likes For TiHabanero:
Old 05-21-20, 06:58 PM
TiHabanero
dsaul, I have been riding the bike with the inappropriate fork and am becoming accustomed to the low speed weirdness. I will say once I am up around 17+ mph, the thing settles down and is very comfortable to ride. Does not like to deviate from a straight line so a little extra effort on the bars is required for cornering. Oddly, this does not bother me at all. Only the low speed instability is bothersome, but I bet that can be overcome in time.
The OS down tube seems to make a difference in the responsiveness to heavy input such as climbing and sprinting. At 40mph on a downhill the bike was very stable, but as mentioned before, it did not like to deviate from a straight line without some heavy handedness. Again, I can deal with that. Thinking that using the wrong fork is livable. Thanks, dsaul!
