28mm tire to replace 23mm
Hello All,
I wanted to replace the tires on my 1999 Bianchi Alfana. I am Currently running 700x22 tires and tubes( @ 95-100psi) which was the stock size. I bought the bike new back in 1999 and rode it for thousands of miles years ago, but I am now 62 years old and find the ride a bit harsh after not riding for the last many years.
I am looking for a better ride without inviting problems. I have measured the rim width at 13mm. Will the wider tire mount up ok and be reliable? I don't think I will have a problem fitting on the bike I have clearance on the bike and should be able to clear the rim brakes as well.
My tubes state 18-23mm on the box I guess I need to change them as well. I noticed that all the larger tubes 28-32 seem to have longer Presta valves, mine are 32 and threaded and work fine. The bigger tubes seem to run a smooth valve with no threads as well not sure why no threads on the valve stem
I have been riding for many years but am a novice when it comes to swapping out parts and sizing.
Thanks
Thanks
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Looks like a fun bike. Why not use 25s and call it good? Your current tubes should be fine. Smooth stem versus threaded stem makes little difference. Although threaded allows you to use the locknut as a brace when filling a new/flat tire. I've had both...
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
If a 28 will clear your frame and brakes you will be fine. You can use your same tubes.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
see how much clearance there is from the 23mm to the brake bridge, I have seen this be a problem on a bike when a friend's bike when he went to 25mm. you may also have a problem with brake clearance when removing and replacing the front wheel when fully inflated.
Hello All,
Thanks
Thanks
OK thanks to All,
I think I will go with 25's as has been suggested and call it good. I had remeasured and believe the 25 will not be a problem at all.
I will post results when the parts arrive and the swap is complete.
The D comes in a tan side wall that would be bonkers on that bike, especially if yours is Celeste.
Quoted: 2338 Post(s)
Liked 2,824 Times
my tire suggestion is Continental gp5000k for tires not cheap but really good ride and so far (700 miles) not flat problems
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
If 28s will clear your frame and fork, I’d go for it.
28mm is fine on a rim with 13mm ID. I’m running 35s on 14.5mm rims.
Likes For Kapusta:
aka Phil Jungels
My Crosstrail came stock with 45MM titres, and 18mm rims. 2.5 times the width.... You should be fine with that 28 if it will fit the frame.
Quoted: 1182 Post(s)
Liked 833 Times
The specs shows 700x25c tires as original equipment for the Bianchi Alfana. If that is the case a 28 mm tire would only be a 3 mm incrase in tires size. Twenty-eight mm tires should not be an issue.
https://www.bikepedia.com/Quickbike/...spx?item=83976
The prior two posts are proof positive you should take internet advice with a grain of salt.
There is no way in hell you can or should run 28 tires on wheels of that era and width.
They will not seat properly even if they can be mounted at all.
The fact it is a 3 mm difference is totally irrelevant. A 28 mm tire will likely size 29 or 30 nowadays.
I am a mechanical engineer I should know.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
"Those who say it can't be done should stay out of the way of the people who are doing it."
But a 28mm on 13mm-internal really isn't getting all that deep into "crazy" territory. Tons of people have done it extensively without incident. I've ridden such a setup for a couple thousand miles so far, the beads seat evenly around the rim no problem and it mostly feels alright.
Likes For HTupolev:
Liked 833 Times
In my experience Continental's road tires actually size smaller than their stated size. And that comes from riding a lot of Continental tires.
The Mavic Open Pro rims that Bianchi used on some of their bikes in 1999 would take tires sizes from 19-28 mm. I'm not sure why one of their less expensive bikes would have a narrower rim. Mavic CPX 21 rims used on their more expensive bikes also are capable of using 19-28 mm tires.
Scroll to the chart at the bottom of the page, and you might see some data from someone who actually knows about bikes.
https://www.sheldonbrown.com/tire-sizing.html
This is a good site if you want the specs on older bikes:
https://www.bikepedia.com/Quickbike/Bikes.aspx
Likes For Doug64:
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Liked 2,824 Times
only fitment issues is if brakes and frame will fit 28mm (tight fists have had to let air out to get through the pads, but once there need to ensure clearance)
and tire vary widely in exactly how they measure once inflated...some are under, some are over and a very few are exact
and clearly you don't know
Expired Member
Liked 5,433 Times
Likes For shelbyfv:
Actually although the specs say the bike came with 25mm tires the bike indeed came with 22's Vittoria's. I bought the bike new and confirmed the size before I ordered replacement 22's.
Quoted: 2952 Post(s)
Liked 3,106 Times
Hoo boy. Yes, you can put 28mm tires on that rim. But will 28s fit your frame/fork? Probably not.
Likes For caloso:
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Liked 833 Times
What rims are on the bike? If you had the time, it would be interesting to measure the inside width of you rims. How about doing that when you change your tirees, and let us know the size. That could settle some of the questions raised in the discussion. It might be good to do before you order the tires.
I've done a lot of touring on 25 mm tires, and they are not bad. I have also done a lot of touring on 28 mm tires, including a trip across the U.S., but the rim was probably a little wider than your rim.
Liked 833 Times
Sheldon's note at the bottom about many people exceeding those recommendations is quite the understatement. Before rim widths caught up, mountain bikers were blowing the doors off those recs with no issues. Heck, at one point I was using 2.3s with 17mm (ID) rims. That's like 6 boxes into the red on that chart. Heck, I'm STILL two boxes into the red on my MTB and my old Salsa Casseroll that my wife now rides. Zero issues in 23 years. None. Nada. Zip. Would wider rims be better? Sure, for handling. But there is nothing unsafe about it.
"The Mavic XM 117 rim brake rim is wide enough to allow the use of a large volume tire, but reasonably light for epic mountain bike rides. 6160 Alloy, non-eyeleted tube-type rim. Black with machined UB Control braking surface. Valve hole diameter: 8.5 mm, supplied with valve adapter. br>
Weight: 440 grams
Internal/External Dimension:17/22mm
ETRTO recommended tire sizes: 1.1" to 2.3"
Rim Depth: 17mm
Drilling: 32 or 36 hole
Rim Brake"
This is essentially the same setup you were using That is one heck of a range.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
The resulting inflated tire width and height will depend on the rim internal width. More than likely a modern 28mm tire will measure 28 on your narrow rims. I bought new wheels going from 14mm to 19.5mm inside width. Basically increasing the circumference the circle. Now I cannot run 25mm tires. They fit but are too close and rub. My suggestion is first take some Allen wrenches and measure how much clearance you have to the sides and top. If you think a 28mm tires will fit then buy one 28mm of the flavor you want and try it on the front and rear. I so wish I could run 28mm tires. 25mm tires would even help smooth the road. I’m looking at gravel bikes for an all around bike. I could have two sets of wheels with one all road and one dual sport tires.
