Really Fast Tyre Idears
Hi All
I am looking to get a really really light tire for my voodoo hoodoo for the road with the ability for a bit of gentle of road. i currently have the stock Maxis Agents but saw the below and saw there a lot lighter. i just want to be super light and go fast. # on a diet as well
would the below tyre be the right tyre do you think and also are there any other better suggestions that are lighter than the argent's please ?
https://www.maxxis.co.uk/catalog/tyre-280-18-aspen
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Likes For stevel610:
You got to be kidding me. Seriously. Those Maxxis Aspen tires look like they belong on a farm tractor. No wonder you're going so slow. If you want something faster get a smoother rounder tire. These are pretty cheap & roll good at about 60psi:
https://www.thebikesmiths.com/produc...xoCGQgQAvD_BwE
Likes For ramzilla:
Thanks for the idears guys. The kenda tyre looks good but it's still to heavy. Is there any sub 600 gram tyres you would recommend please ?
Quoted: 1364 Post(s)
Liked 1,677 Times
This timely blog post from Jan Heine shares my disdain for "shoulder knobs" which the Maxxis Aspens you linked to have.
https://www.renehersecycles.com/why-...houlder-knobs/
Likes For BobbyG:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
You mean you want something for pavement and light trails?
Define “light trails”. You mean rails-to-trails, or single track?
Awesome article BobbyG. i wont be going with the Aspens now
Out of the 2 below guys whats faster? / better?
https://conti-tyres.co.uk/mtb/mountain-king-ii-2-2
Hi Kapusta
i am not sure how to describe it tbh so i will just say its like a dry semi tarmacked tractor lane. sorry to be poor at explaining.
To be fair tho its 99% road i ride on atm. if the tire can handle roads that are not perfect as they sometimes are then id be happy
Use the ardent when i get into doing trail parks.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
Hi All
and these tires in 27.5 x 2.25? https://www.maxxis.com/catalog/tire-465-140-ardent-race
Might try something like this? https://bicyclewarehouse.com/collect...m-folding-bead
Or if you really don't intend to do any serious offroading, this? https://bicyclewarehouse.com/collect...m-folding-bead
Liked 2,568 Times
Okay, in 26", Rat Trap Pass is 454g for the standard casing and 418g for the extralight casing. Light and fast, that ought to do it.
RUSA #7498
Originally Posted by noglider
Last edited by ThermionicScott; 05-13-20 at 11:04 AM. Reason: dammit, tyrion beat me by 2 min
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
It's really common on a mountain bike to run a tire in front that is very focused on traction and a tire in the rear that is compromised on traction to improve rolling resistance. The front does all the steering and braking and the rear carries most of the weight. This can be taken seemingly too far sometimes (like Specialized Butcher/Slaughter).
But that's only if you want to keep it a Mountain Bike.
If you want to mostly ride roads, go ahead and get slicks, they will go a lot faster. People have been turning mountain bikes into commuter bikes for 35 years. Lighter ones are faster and smoother, but that's because they don't have as much armor, so pick your poison. As long as the tire is more than about 50% wider than your rim, you are ok.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 185 Post(s)
Liked 36 Times
Since you were looking at 26" tires, I ran across these Maxxis tire last year when I was refreshing an older rigid mtb. These are 120 tpi, tubeless compatible, fast, and under 600 grams for a 2.1 width. https://www.maxxis.com/catalog/tire-490-143-tread-lite
That's what was worrying me a bit tbh I don't want a tyre that is road only due to the lack of armour. Im happy to sacrifice a bit of speed for a little armour. Or at least more than a slick puncture every 5 seconds tyre.
Disco Infiltrator
Liked 2,105 Times
You can buy road tires or MTB tires with any amount of armor you want. The road tire with the thickest armor is called Marathon Plus. The one with the hardest armor is called Gator Hardshell. There are also tires with almost no tread rubber and no armor at all, and everything in between.
Genesis 49:16-17
Genesis 49:16-17
If you want to try a supple slick but want something cheaper than the Rene Herse tires, the Panaracer Pasela is a good option. They're available in 26x1.75".
Gator Hardshell is a more lightly-constructed tire, but it's not available in 26". Marathon Plus is available in 26". If my goal was to achieve a fast and plush ride, I would avoid both of them, especially the Marathon Plus.
How chunky are the trails you're riding, and how often are you getting flats? On 2" tires, the sidewalls aren't very exposed to the riding surface unless it gets pretty rough... the casing on my Rat Trap Pass ELs is some of the thinnest out there on a 26er, and while they show signs of being roughed up a little, so far I've never had to stop on a gravel ride to fix a cut or puncture on them off pavement.
Out of curiousity what makes the Rene more expensive?
