Chain length for new ring?
Hey all. I sized down my cog from a 18 to a 16 and am about to size up the ring from a 46T to a 48T. The rear axle has about 1.25-1.5 inches of travel available. Does anyone know the calculation to figure out if I need a longer chain to accomodate?
Thanks!
Thanks!
Quoted: 1332 Post(s)
Liked 398 Times
You come out to the same number of teeth in the end, so you shouldn't have to change anything in theory.
sounds good to me, I didn't know if the difference in diameter of ring v cog would have a greater change with addition/removal of teeth...
Quoted: 99 Post(s)
Liked 115 Times
The circumference can conveniently be measured in terms of teeth rather than inches or centimetres.
So you've added 2 teeth at one end and taken away 2 at the other, so the chain remains the same length — with a very slight adjustment to the position of the wheel because the top and bottom lengths of the chain are not parallel, and the angles have changed slightly.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
The fact that adding X teeth at one end and subtracting X teeth at the other end results in no change to the chain length can be really useful. Every winter, I change to a lower gear to cope with snow and studded tires, and just keep running the same chain.
