What exactly is a "level saddle?"
Quoted: 15 Post(s)
Liked 42 Times
I just angle my seat based on what's comfortable...but holy crap, the amount of "OMG, level your saddle!" posts in every bike forum picture thread just get tiring after awhile (tied with "tighten up your chain!").
I'm just curious what this specifically means.
I was recently reading a book by Chris Hoy/Chris Boardman about bike fit and it mentioned how UCI requires a level saddle. It's one of those rules set in stone and they only give you like an 1/8" of leeway.
So what exactly is considered a level saddle?
Is it making the longest section of the saddle (the main area where you sit on) level and ignoring the raised rear section?
Or is it making a ruler level while resting on each ends of the saddle?
Now what about a sloping top tube?
Level the saddle based on the top tube angle.....
Disregard top tube angle....
Quoted: 1332 Post(s)
Liked 398 Times
Leveling based on top tube angle would be about the dumbest thing. It's the second one you describe. Those saddles above don't have raised sections, they have contoured dips that you're supposed to sit in.
The angle at which the longest straight cross section of the saddle is parallel to the imaginary line drawn from one dropout to the other (aka the wheelbase line)
Quoted: 15 Post(s)
Liked 42 Times
Even on mild angled top tubes like CDale tracks or GT GTB/Pulse, it's like a 50/50 split...people either angle the seat based on the top tube or they ignore it.
I understand the contoured dips...but that's my question, a saddle like a Flight has that center valley that extends flat to the nose. Only the rear angles upward. Do you measure both ends or just the flatter valley section where you sit?
A more extreme example would be a Concor Supercorsa Sprint saddle. Do you go off the main flat area or include the upward rear section? If you include the rear section, the nose is going to angle upwards.
Quoted: 686 Post(s)
Liked 5 Times
I've heard a lot of people say that if you're riding a pursuit frame, you angle the saddle downward.
For normal everyday riding tho, you're not in an aero tuck the entire ride, nor are you really needing a special sprint saddle.
Quoted: 15 Post(s)
Liked 42 Times
Yeah, I currently have my Flite leveled like that with the upturned nose.
With my Sakae seatpost, it's actually maxxed on the adjustment and it's still not perfect.
Liked 398 Times
Quoted: 15 Post(s)
Liked 42 Times
I could understand angling your seat down a bit for a pursuit frame on the track, just like many TT bikes have a saddle with the a short nose...this is because you're bent over more. Same with the sprint saddle, it's designed for sprinting, so the back part is supposed to keep you on your saddle when you're pushing a harder effort.
So if you tried to use that saddle sprint saddle in a UCI even, would they require the nose to be pointing upwards to compensate for the high raised rear section?
Quoted: 15 Post(s)
Liked 42 Times
The thing about pursuit frames is dumb. Might have had some relevance when pursuit frames with downward sloping top tubes and dropped front ends were still manufactured and used, but it's completely moot now. The Flite you posted doesn't have a flat section. That Supercorsa Sprint was designed in the era of crazy aero experimentation and is now race illegal and irrelevant.
canis lupus familiaris
Bikes: En plus one
I "level" my bike saddle so the main part I am sitting on is level. On a Brooks, this often means that the nose is pointed up.
One consideration is that if the saddle is installed nose down, you will have the tendency to slide forward. This requires you to push yourself back with your arms, which will become tiring in a relatively short time.
Quoted: 16 Post(s)
I level my saddle to the ground/axles, like others said, if you have a forward angle you are going to slide forward and you'll have numb hands in no time.
Fresh Garbage
IME people riding with extreme saddle angles typically have a bad saddle height, usually too high.
Quoted: 4802 Post(s)
Liked 3,923 Times
Wow! My take on seat tilt? The right tilt is based on my seat, my butt and my riding position. Your thoughts about it never enter into the picture. The idea of changing my seat tilt from the most comfortable to please you or other riders never crosses my mind. All my bikes have nose down seats to varying degrees. Yes, I ride with weight on my hands (except when I am riding hard). It requires a little strength and a little conditioning. Is that bad? Since no work is done, energy is not burned by the weight on my hands and since I can ride a more aero position, less energy is burned by my legs. That sounds and feels like a net gain. (When I hear that weight on the hands is bad and tiring, I think "Man up! Grow some muscle!")
Ben
Ben
Liked 398 Times
Yeah because that bike definitely looks like it was built for riding 100 miles at a fast pace.
Basically, you eventually realize that no one actually cares that much about your bike, and then you learn to not care about what no one thinks about your bike.
Ride On!
Bikes: Allez DSW SL Sprint | Fuji Cross
Quoted: 227 Post(s)
To me, only the first two look "level" to me. You have to ignore the back part...and if the nose swoops down, you have to ignore that too. There's going to be some level of rise in the back of just about every saddle to differing extents.
My pants used to fit me
Why would you ignore a full third of your saddle? Seems silly to me.
Your cog is slipping.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
If it's UCI's rule you're wondering about, here's what they say (Article 1.3.014):
“checks on the horizontality of saddles will be conducted at WorldTour events, World Cup events and World Championships for the road, the track and the cyclo-cross by measuring the angle of incline of the saddle, considering the plane passing through the highest points at the front and rear of the saddle. This angle must be less than 2.5 degrees with an error tolerance of 0.5 degree.”
https://www.uci.ch/mm/Document/News/R...NG_English.PDF
But as noted above, only people competing in UCI sanctioned events should feel bound by this rule. For the rest of us, a level saddle is a starting point only, and can be adjusted as needed for rider comfort or preference.
