Patch tube, Yes/No?
Quoted: 18320 Post(s)
Liked 15,297 Times
Likes For indyfabz:
Always leave the cellophane on patch repairs at the time of installation. It won't hurt/abrade anything inside your tire. You can mess up your patch job trying to remove it, however.
You can remove it the next time you pull your tube/tire.
Likes For Jasper Storm:
Quoted: 551 Post(s)
Liked 276 Times
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
For me, yes. Some of my tubes have 4 or 5 patches and they still work perfectly.
I live and ride in the land of thorns, so I flat all too regularly. I collect the tubes and patch them in a batch when I have about 10. After patching, I fill them up with air, and if they are still holding air in the morning, they get stashed for later use -- the ones that fail (maybe 5-10%) get binned. I've never had a good patch fail -- and it's pretty easy to tell if you got a good bond.
Plus it's pretty satisfying work.
After installation, and usually well after the glue had cured. I.e., after leaving it inflated overnight and when I check in the morning. Too often peeling the celophane tends to pull up the edges of the patch.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
The cellophane is there to help you apply the patch without touching the contact surface of the patch itself.
Kit doesn't match
I too buy boxs of 100 Rema patches as that's the only way I've found to get the smaller 16 mm patches that work well on the typical tubes for road bikes. The 15 mm jobs are too big.
Recreational Road Cyclist
Quoted: 254 Post(s)
Liked 252 Times
My dad did the patch flambé as well! My recollection is he lit the fluid on the tube rather than the patch. I too have since wondered if it made any difference, but as a kid I didn't care, just wanted my bike back.
Quoted: 18883 Post(s)
Liked 10,645 Times
I stopped using tubes ... and getting flats.
Likes For Seattle Forrest:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
No thanks...
Was on a group ride and a guy put a 1" gash in his tire. Sealant flew everywhere and was a mess. I offered my spare tube and tire boot so he could ride home, but it was such a mess that he decided to call his wife.
If it was a tube, he would of rode the last 20 miles home.
BTW, I just purchased REMA TT 02 kit to give them a try.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
BIDT, my dad had patches you'd clamp down with the tool above, then light the orange part of the back of the patch with a match. It would flame away like a road flare for a minute or so, and produced some really toxic-smelling smoke. After it cooled off, you peeled the metal part off, leaving a really durable patch.
I used to patch all my tubes like that, didn't know there was any other way. I can't remember one of those patches ever failing, they were pretty much permanently bonded to the tube.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 135 Times
Buying the Rema patches in bulk is a good idea. An even better idea is to buy a large container of rubber cement. The Rema cement in those tiny tubes doesn't seem to last long, and I usually end up with more patches than cement from the little kit. Also, I use Slime brand cement, it's much cheaper than the Rema stuff, and works just as well. The applicator brush is much easier than squeezing the tube and rubbing it in with the tube itself...
Regarding the cellophane, I used to try and peel it up, but the edges of the patch are so fragile, I end up sometimes messing up the edge. So now I just leave it, it's no bother to me or the tube/tire, so I just leave it alone. As someone else stated, some of them have a slit in the middle, but sometimes I find that the cellophane just ends up tearing anyway. I just don't bother with it anymore.
Farmer tan
I remove it. If you look closely, the cellophane is cut or sliced in the center, so if you flex the tube there you can get a fingernail under the cellophane and remove it from center to edge with little to no risk of pulling off the patch.
Farmer tan
The heat really vulcanized them well.
Wouldn't it be fun if someone made tiny bicycle patches you could light up to vulcanize?
Quoted: 6882 Post(s)
Liked 10,873 Times
Patch them. How else are you going to earn $10 (the price of a new tube) for two minutes' time?
Likes For Koyote:
well hello there
Quoted: 503 Post(s)
Liked 334 Times
When my kids were younger I'd throw patch parties in the garage. But I don't have good luck with patches. Maybe about 50%.
So I just go with new tubes.
Your ability to patch a tube is unknown.. I can do it ,( & have for decades,) can you?
Like a good paint job, the surface prep is the most important part , of a good job ..
Quoted: 878 Post(s)
Liked 2,019 Times
I always put in a new tube, after finding/fixing the cause first, of course.
If I've got a long way to go, I'll patch the hole on the spot, and stow it. My rationale for patching immediately but not using immediately is that n+1 flats are always possible, and patches adhere better over time. A simple way to observe the latter is to apply a patch then immediately rip it off. Now apply a patch, wait a day, then try to rip it off. Much harder.
A key to patches staying on, even if you have to use them before fully cured, is to use tubes on the bigger size for you tires. Smaller tubes have to stretch to fill the void, and patches are more likely to separate from the stretching tube.
Quoted: 4559 Post(s)
Liked 2,798 Times
Yup, I patch tubes. Usually Lezyne or similar glueless patches on the road bikes (the Lezyne kits are so small they'll fit any saddle bag, or even in a jersey pocket or sock), regular glued patches on the hybrids. I'll usually patch 3 or so times on the road bike tubes before replacing 'em. I think my record for the hybrid was 6 patches.
The glueless Lezyne and similar patches are so thin they don't interfere with the snug fit on my road bike wheels. And they work fine long term. I've had only one fail, which was operator error -- at night I didn't notice I'd left a bit of a seam or bubble in the patch and it developed a slow leak a week or so later. But I've done the same thing with glued patches.
When I've retired tubes I repurpose them, either as big rubber bands, or bar wrap for extra padding. Really tames vibration under cosmetic bar wrap.
Quoted: 4717 Post(s)
Liked 1,882 Times
No thanks...
Booting a 1" gash, and riding home. Nope
Quoted: 811 Post(s)
Liked 1,946 Times
Reading this thread I realize I need to be more of a conservationist and repair punctured tubes.
From a safety standpoint, I never felt secure knowing I am riding on a patched tube. I only kept a patch kit for the rare occurrence I used my two spare tubes on any one ride. I have only double flatted once in the past five years.
well hello there
Quoted: 503 Post(s)
Liked 334 Times
Likes For Nachoman:
Likes For f4rrest:
