Name that part ...
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
Name that part ...
I should know what this caps off, but ... I'm coming up empty.
Quoted: 2323 Post(s)
Liked 4,988 Times
I'd say a quill stem
Steel is real...and comfy.
Likes For jamesdak:
PM me your cotters
Liked 590 Times
I think it may be too small for that. I should've provided some size reference... Let me edit and re-add a pic with a reference up above.
It's barely bigger than a QR spring.
Quoted: 964 Post(s)
Liked 1,451 Times
They REALLY look like quill stem caps for those cheap adjustable-angle aluminum quill stems common back in the early 2000s. Those stems had a sloping surface where the bolt was recessed into. Even the size seems right. I remember back when I worked at a bike shop, prying those out with screwdrivers to do adjustments on new bikes. They almost never got put back in.
Likes For scarlson:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Name that part!
Quoted: 3810 Post(s)
Liked 6,690 Times
I think I have one of those stems on my relatively new acquired Jamis Exile MTB:
Untitled
It takes a fairly long 5.5mm hex wrench to get at that stem bolt; weird design.
Untitled
Liked 4,988 Times
Yeah I've have a few like that. Right now the Deda on the Serotta has a larger one of these as do the Icon Stems on my one Lemond and Y-Foil. One of the bikes I moved on this year had a little one like that, I just don't remember which.
PM me your cotters
Liked 590 Times
When I first saw it, I thought of the annoying caps Huret has on their Eco and Duopar rear mechs. The rounded shape and rubberiness with the smaller size was throwing me off - not even as big around as a Corn Nut, and why would you want pliable rubber covering a derailleur fixing bolt or pivot?
Anyway, I think you guys nailed it. Thanks everyone for chiming in.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Here is my bomb around town bike with a riser stem. It has a stem cover like show above.
Likes For bwilli88:
Quoted: 1324 Post(s)
Liked 927 Times
