Which type of aluminium is used for cast Derailleur hangers?
Hi there,
Could you please offer me some assistance, I'm doing a school project and would like to know the specific type of aluminium or at least the series of aluminium mostly used in the manufacture of cast replaceable derailleur hangers most sites just state it as aluminium without giving a specific type, unlike the CNC variants which are sometimes listed as 6061 aluminium.
Many thanks in advance
Quoted: 1438 Post(s)
Liked 1,092 Times
The most common aluminum alloys used for casting are the 300 series alloys, with A380 being the most commonly specified. The300 series are composed of aluminum, silicon and copper or magnesium primarily.
It is likely that a simple part such as a derailleur hanger will be cast of A380.
https://diecasting.com/blog/2018/02/...uminum-alloys/
https://www.dynacast.com/en/knowledg...casting-metals
Likes For dsbrantjr:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Okay, but... aren’t they made from stock?
Genesis 49:16-17
Genesis 49:16-17
I could also use your help with one more question. When looking at replaceable derailleur hangers manufactured by cold forging the material is given as 6061 aluminium. I know that for those made by CNC 6061-T651 is commonly used but which specific variant of 6061 is used for cold forging? I thought it would be 6061-O as it has good formability, however, it's a significantly weaker material than 6061-T651.
Really Old Senior Member
Quoted: 4199 Post(s)
Liked 3,852 Times
But stiffness is a nice aspect of hangers. Al has, unlike steel, a varying degree of stiffness due to alloys and treatments. And of course part geometry (cross sectional area being a biggie) can contribute to stiffer or stronger hangers. Or, more to the point, the same design choices can lead to a weak or flexy hanger. Andy
AndrewRStewart
AndrewRStewart
Disco Infiltrator
Liked 2,105 Times
So it turns out yes there are cast derailleur hangers. Huh. Seems like if you wanted to make something cheap it would be cheaper and just as good to stamp it out of steel
Genesis 49:16-17
Genesis 49:16-17
Liked 1,092 Times
https://www.engineersedge.com/aluminum_tempers.htm
Aluminum Alloy Heat Treatment Temper Designations
Liked 1,092 Times
Well, the hangers which are integral to steel dropouts ARE stamped (or cast) out of steel, but they lack the mechanical "fuse" action of a weaker aluminum.hanger
EK987h,
Aluminum is heat treated after forging, and cold does not mean room temperature. In general cold forged means below any recrystallization temperature. The recrystallization temperature is ~750 F or so depending on the exact alloy and composition. So, to answer your question the part of concern would be forged, most likely, stamped in a die, then subsequently solution heat treated and aged to the T6 or T61 condition. Hope this helps with your project.
I find it somewhat hard to believe these would be cast, when today you can water jet or laser cut a blank, clean it up, drill necessary holes, thread as necessary and ship the part.
Just my couple of cents worth of thought.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yeah, from a cost standpoint a stamped steel hanger would be cheaper but it would also be too strong. You want a relatively weak hanger so it breaks first rather like a shear pin.
EK987h,
