Ponder this scenario: crank arm/pedal snaps off
Ponder the following scenario:
You are standing on the pedals on a climb. All of a sudden the crank arm or pedal snap off, separating completely from the bike.
Is there any recovery, or are you simply going down?
Bikes: Norco Valence 2014, Kona Kilauea 1994
Prepare for your heels to smash into a million pieces. I rode on metal platform pedals in the rain once and slipped, hitting the ground really hard. Your body should tense up and reduce injury by bracing against the handlebars. I don't run those pedals anymore, now I have those grippy mtb style ones.
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
I snapped a steel crank arm right in the middle on my Robin Hood climbing a 15% grade, and surprisingly it was a total non event. Just mashing on the pedals, and suddenly no resistance on the left, like WTF? Really?
I wasn't sanding so I don't know if it would have made a difference.
FWIW, I welded it back together, and it snapped again with the same non event result, except it wasn't a surprise.
Quoted: 18302 Post(s)
Liked 4,470 Times
I haven't broken a crank, but I've yanked cleats loose, had a chain skip, and spun the tires without traction. They don't have to be catastrophic failures.
Also missed a clip-in, and had the feet slip off of the pedal (standing). It gives a bit of a jolt, but one doesn't go down.
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 262 Times
Not all bike shops bother using torque wrenches, nor follow the specific directions to stagger the bolt-tightening sequence, but I do now. It might have been a fluke that nothing happened, that the crank popped off at just the right moment, but I can imagine 359 worse alternate outcomes.
Quoted: 5876 Post(s)
Liked 3,445 Times
There is a famous picture of Laurent Fignon who crashed when the bottom bracket axle on his bike broke; you can see the crank arm and pedal next to him after the crash:
inrng : fignon remembered
Super Moderator
Quoted: 1173 Post(s)
Liked 919 Times
Liked 3,445 Times
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1346 Post(s)
Liked 1,234 Times
During a full sprint, in traffic to get through a Red Light.
My Left Crank arm came OFF.
I was able to put it back on and slowly pedal home.
Fred "The Real Fred"
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
I've worried about this when climbing and out of the saddle. I know that I would go down hard and probably do some major damage to myself.
canis lupus familiaris
Bikes: En plus one
Something that makes this scenario even more daunting, is that if you snap a crank arm while climbing, the chain is likely on the small ring. This means that the big ring has exposed teeth (ie. not covered by the chain) and is posed to do more damage to your unsuspecting flesh.
Having said that, I did have a crank arm come off (on level terrain) and to coin the phrase, "it was a non event".
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
I had a pedal fall off while accelerating through an intersection. No injury, just very surprised. I'm still not sure how it happened: the threads were perfectly fine, and I just re-installed it a rode home. And it's been fine ever since.
Quoted: 659 Post(s)
Liked 594 Times
I dont want to think about this. OTOH, breaking a crankarm on a sprint puts you in the beast category.
Quoted: 378 Post(s)
Liked 1,407 Times
I don't think you can prepare for it, and it's going to hurt if you are not incredibly lucky.
A friend had that happen and had 17 staples in the back of his head.
Liked 3,445 Times
This is making me think I may just get a new crank for a bike I'm building on rather than relying on some old ones in my parts bin; geez thanks.
Super Moderator
Liked 919 Times
Bikes: 95 Cindercone
Quoted: 11 Post(s)
That Huffy Guy
Bikes: Old School Huffy Bikes
Quoted: 79 Post(s)
I had this happen one time in recent years. The right crank arm broke on a road bike I had and I went down but not hurt minus a few scrapes. All my bikes but one have a one piece (Ashtabula Crank) on them and I don't think I will ever have to worry about breaking one of them. However, when I was a kid I remember jumping my Huffy BMX and I did bend the one piece crank on that bike.
Quoted: 5681 Post(s)
Liked 2,386 Times
Over my 50+ year cycling career I've snapped a decent number of cranks and/or pedal spindles. Of course they always snap under peak load, but only once in the well over 10 incidents has it led to a crash or injury. The one exception was a cut over my ankle bone caused by the stub of a pedal spindle.
Broken cranks and pedals happen, but aren't a worry except for the inconvenience factor.
FB
Chain-L site
FB
Chain-L site
I think this video shows it pretty well. And, as my story below underscores, note how the helmet probably saved his life.
As for the famous photo of Fignon, that was the first generation Titanium Campy spindle that was hollow and they all broke. It was quickly replaced by a solid Ti version.
My own experience was quite recent. I was out for a nice ride on a lovely afternoon just pre-Xmas, and into a standing mash up a residential hill as I headed home when . . “BAM” My left leg suddenly cut loose from the bike and I went tumbling.
At first I thought I’d broken the crank arm, but discovered it was the left steel spindle of my pedal. I have never, ever, snapped a steel pedal spindle before. Call me shocked.
And I was lucky, as I did my inelegant cartwheeled in the middle of an otherwise empty residential street. Sadly, no video of the acrobatics. Bummer. But that video above feels very, very familiar. Surprisingly, there was almost zero bike damage, although I was a tad stiff and sore. The bike rotated right-round with me and stayed hoisted in the air due to my right foot remaining connected.
The most important lesson came as I rolled onto my back at a speed just a bit too fast to keep my neck muscles tight. As I heard/felt my helmet crunch as it performed the bounce off the pavement, “Thank you, dear helmet,” I whispered. Hence: Always wear your helmet!
For the record, going up hill when this happens is much better than flat out racing or mashing down a hill. Gravity kicks in and your forward motion is slowed. So it is mainly how your leg/foot comes down and how nicely you do that 1/2 cartwheel. At speed? Major road rash, just to begin. I shudder to think.
1959 Hilton Wrigley Connoisseur (my favorite!)
1963 Hetchins Mountain King
1971 Gitane Tour de France (original owner)
* 1971 Gitane Super Corsa (crashed)
* rebuilt as upright cruiser
1971 Gitane Super Corsa #2 (sweet replacement)
1980 Ritchey Road Touring (The Grail Bike)
1982 Tom Ritchey Everest
(replacing stolen 1981 TR Everest custom)
1982 Tom Ritchey McKinley (touring pickup truck)
1985 ALAN Record (Glued & Screwed. A gift.)
Bikes: 2015 Specialized Crosstrail Sport Disc; 2015 Trek Domane 4.3
The closest I've come was cracking a plastic pedal in half while climbing a hill. No drama, but I was much slower back then... Plus it gave me good reason to try clipless...
Liked 4,470 Times
I've been having troubles with cross-chaining under full power off of the big ring causing my chain to drop
But, fortunately I don't go down. I suppose one difference is one still has the feet in the pedals even with a dropped chain, whereas a broken crank, and one side is just hanging.
