V-brake rubs on one side, then the other
Quoted: 19 Post(s)
I adjust my v-brake so that neither side rubs. The next day it starts rubbing on one side, so I adjust it so that it stops rubbing. Then the day after that it starts rubbing on the other side. So I adjust it again and then a day later it starts rubbing again on the side it rubbed on two days before. And so it goes on in an endless loop. How do I fix this?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,010 Times
Maybe take the brake arms off the posts, clean the bearing surfaces up, regrease, and reassemble. It's fairly easy.
Likes For tyrion:
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I like V-brakes but they can change their mind quickly. It seems that whenever I undo them to remove a wheel, they never center the same and I have to mess with the springs.
SE Wis
Quoted: 2716 Post(s)
Liked 3,332 Times
Any time I adjust them I squeeze the brakes a bunch of times before I call it good.
Quoted: 19 Post(s)
Really Old Senior Member
Petroleum jelly.
It probably won't last as long as a "dedicated grease", but it's not like an axle constantly rotating.
It's good enough to see if lubrication is the problem.
Quoted: 7251 Post(s)
Liked 2,322 Times
You might try disconnecting the springs from the arms, bending them out so they push out harder, then putting them back. You'll need some trial and error to get the spring tensions approximately equal. I've done this, and it works. But yeah, V-brakes are annoying in this way.
Likes For noglider:
Does it "switch sides" depending on how quickly you release the lever?
Bikes: Bike Friday NWT, Rans Stratus, Cannondale R500, trek 720 multitrack, Rockhopper
Quoted: 35 Post(s)
Liked 36 Times
A problem I had with v brakes once was that, as they wear they are moving in an arc, this makes them move slowly downward on the rim as the wear progresses, after a while a portion of the pad is no longer in contact with the rim and develops a lip. This lip can catch on the rim causing them not to release properly. This and has been mentioned brake posts with no lube and cabling have caused most of my v brake issues.
Droid on a mission
Quoted: 315 Post(s)
Liked 273 Times
I use fine steel wool on the bosses and a .38 caliber brass gun barrel brush inside. Once all nice and shiny, lube and reassemble, work's like new
Steel is real
Usually if i need to tighten an adjust screw - i'll loosen the other side. (depends)
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Are you sure that the locknut and cone on your wheel hub has not worked loose? Make sure there is no play in the hub when the wheel is affixed in the dropout, as this can make it seem like the brakes are coming out of adjustment when the wheel 'wobbles' back and forth due to the play in the hub bearings.
Quoted: 417 Post(s)
Liked 685 Times
The bending of the spring is one way to increase tension, and if that doesn't do it, assuming your frame has different holes on the brake mounting post, change the hole position to increase tension.
