DT Swiss Freehub Issues
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
Hi-I have been having issues with the stock rear wheel on my 2019 TCR Disc (SLR1 12mm TA wheel). After extensive research, I have determined they used DT Swiss 360 freehub body. The hub sometimes just rolls like butter but most the time there is this grinding noise coming out.
Should I just go ahead and get a new freehub since I neither have the tools nor the expertise to service the freehub? If yes, what model should I get? Can't seem to find the exact model online. Are there any compatible models? Thanks in advance.
Quoted: 4717 Post(s)
Liked 1,882 Times
Quoted: 6193 Post(s)
Liked 4,809 Times
Noise or grinding when? Coasting?
DT Swiss freehubs are notoriously noisy when coasting. The followers of DT Swiss look for that unique oscillating noise they make when coasting. Myself, I like the quiet Shimano stuff I got used to. Eventually the DT Swiss rear free hub on my new bike will have to go.
Don't overlook brake noise from either a rotor scrubbing a disc pad or even a rim brake pad scrubbing.
Since there isn't an issue other than noise, you might just wait till there is a real issue. Especially if you have to pay others to do it for you.
Quoted: 105 Post(s)
Liked 69 Times
Would this work for 360 hubs?
Interesting that some people here are saying that DT Swiss hubs are noisy when coasting. I find mine to be so quiet I wonder if something's wrong half the time.
Liked 1,882 Times
https://www.youtube.com/watch?v=e_XpRZCLTX4
In AZ it hasn’t been a problem, but YMMV.
As far as noise goes, 18t ring gears are very quiet when properly maintained, and 54t ring gears are pretty damn loud if you go very light on the grease.
I work at a shop, so I keep mine very lightly greased, and clean it frequently. It’s incredibly easy to maintain, so it’s no big deal to do it monthly.
from what I’m seeing, the conversion isn’t recommended for a 360 hub, because of a seal issue. I’ve done it, but DT says that the seal isn’t as tight as it should be.
Also how do you feel about the generic/OEM kits on ebay that sell for half as much? Normally I'd be wary of stuff like that but it is literally just two metal rings that for some reason DT Swiss decided to sell for $110.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
I'd take it apart and clean, relube it. Converting it to a 36/54t ratchet with 240 freehub will cost $350-$400, about $150 of which is the two special tools needed. No need to go there if you're happy with the hub otherwise, it's likely all it needs is a cleaning and perhaps a new seal.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Before you do that, take your wheel off and pull the cassette straight off. It'll pull the freehub off with it. See if anything looks wrong inside. Grinding noises arent common.
Quoted: 105 Post(s)
Liked 69 Times
if these are the 42mm deep wheels, they use the pawl style DT Swiss 370 driver. https://www.giantbikespares.com/Gian...detail/3-43290
I changed my ratchets from 18t to 54t. new ratchets sounded like a swarm of angry bees. I took it apart, regreased, and it was quiet for a few weeks. now the angry bees are back 😂.
btw, my revolt hub was defective, something popped during a casual ride. it made a ticking sound with every complete revolution. giant swapped my wheel for me. take it back to giant.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
noodle soup Good to know. I was wondering about that because the "soundchecks" online seem to have DT Swiss star ratchets screaming. I am thinking of doing a 36 or 52 upgrade in the future. What is your experience with them? Is it worthwhile? Noticeable improvement? Is there any pro/con to 36 vs 52? From my understanding, people opt for 36 over 52 mostly because it's easier to maintain and is harder wearing?
I have DT Swiss wheels and hub with the 240 hub and it is loud and I think designed to be. However the other day it seemed to be louder than usual so I just took it apart, cleaned it up the ratchets etc and reapplied grease. Much quieter.
Some people like a really loud freehub but if the noise gradually increases then it pretty obviously needs servicing. Note no special tools required and I didn't use the "special" DT Swiss red grease, just some teflon stuff and it works fine. It's a bicycle not an F1 car....
Quoted: 105 Post(s)
Liked 69 Times
Is it possible to convert a Shimano FH-RS-505 QR hub into 12x142mm thru axle? I have a rear wheel that I pruchased a while back to use as a trainer wheel but now I'm think using it as a spare wheel. any thoughts?
