Replaced axle on rear wheel. Once I ride it, it tightens and wheel doesn't spin
Old 08-05-20, 10:00 AM
Zen1307
Yesterday, the axle on my rear wheel snapped. I spent today trying to replace it with a new axle of same length. Before doing so, I checked bearings, and they seemed ok. When I put the hardware on the new axle, the axle spins (although feels a bit gritty), but as soon as I ride it, something tightens and the axle no longer spins, and I need to push the bike, dragging the wheel.
What have I done wrong? ?
1? Is it likely there is damage to the bearings/hub that I haven't spotted? ?
2? Perhaps I have put in too many/too few ball bearings? (I didn't count them so have replaced with what looks right). Should they sit snug, some slightly above the others, or all on same level with slight gaps? ?
3? Have I not used the lock nuts appropriately? Perhaps the cones are still spinning?
Zen1307 is offline
Old 08-05-20, 10:08 AM
pdlamb
Quoted: 2599 Post(s)
Liked 1,924 Times in 1,208 Posts
I'm guessing 3 from the armchair on the other side of the internet.
You probably don't have the lock nut sufficiently snug against the bearing/bearing nut. This is what cone wrenches are for. You can hold the bearing in place with one cone wrench and crank down really hard on the locknut with a second without tightening the bearing.
pdlamb is offline
Old 08-05-20, 10:11 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Hint: a QR Skewer compresses the axle, so bearing adjustments are done in anticipation of that fact.
fietsbob is offline
Likes For fietsbob:
Old 08-05-20, 10:16 AM
Zen1307
Thank you ! So even if the lock nuts are on the bearing nuts really tight, it shouldn't affect the ability of the axle to turn? Is that determined by the cones distance from one another/fit to bearings? Or is it important to get lock nuts tight but not too tight?
Is any wear on the inside of the hub a reason to replace the wheel? I can feel faint scratches but nothing that feels significant or deep.
Zen1307 is offline
Old 08-05-20, 11:18 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1787 Post(s)
Liked 1,260 Times in 869 Posts
You have to have the lock nut tight enough so that it LOCKS the cone in place and prevents it turning on the axle and tightening up.
Why do you think they call it a lock nut?
Bill Kapaun is offline
Old 08-05-20, 11:51 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2741 Post(s)
Liked 3,388 Times in 2,051 Posts
https://www.parktool.com/blog/repair...and-adjustment
dedhed is offline
Old 08-05-20, 12:00 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Since we are all guessing I am guessing it is a combination of 2 and 3. Fill the race with bearings and remove one, they should not be crowding together so that some are being pushed up. Too-tight adjustment will cause a gritty feel.
If the cone and locknut are not locked together sufficiently tightly the cone can tighten itself during riding. You can use the locking process to fine-tune the bearing adjustment, turning the locknut against the cone tightens the adjustment, turning the cone against the locknut loosens it. Tightening a quick release will compress the axle slightly, tightening the adjustment, so this must be allowed for. The use of an axle vise is very helpful, here is a good one: https://www.steintool.com/portfolio-...ub-axle-vises/
Here are a couple of articles which may be helpful.
https://www.sheldonbrown.com/tooltips/hubs.html
dsbrantjr is offline
Old 08-05-20, 01:45 PM
madpogue
Quoted: 2362 Post(s)
Liked 1,746 Times in 1,190 Posts
FIRST - what kind of bike / wheel?
madpogue is offline
Old 08-05-20, 01:59 PM
aggiegrads
Quoted: 336 Post(s)
Liked 309 Times in 180 Posts
I’m going for the long game. Shimano hub, loose free hub body.
what do I get if I win?
aggiegrads is offline
