Lezyne - Lights confusion
Lezyne Lights - Confusion
I am planing to get new lights and I am especially looking at Lezynes product range. My usage is road bike training and some commuting. I would like lights that are relatively bright, sleek/elegant and easy to use.
Lezynes full product range:
https://ride.lezyne.com/collections/led-lights
Lezynes new Smart Connect series looks very interesting.
https://ride.lezyne.com/collections/smart-connect-led
Especially this Connect Smart Pair:
https://ride.lezyne.com/collections/...ect-smart-pair
Or is Lite Drive 1000XL / Strip Pro Pair (Remote switch compatible) a better choice?
https://ride.lezyne.com/collections/...1-led-16p-v504
Or is 1000 lumen a bit much in urban areas? Then this pair might do:
Micro Drive Pro 800XL / Strip Pair (Remote switch compatible)
https://ride.lezyne.com/collections/...1-led-25p-v204
Or get a Zecto Drive Max Rear. Handy to attach to a saddle bag.
https://ride.lezyne.com/collections/...ed-8r-max-v104
Or Micro Drive 600xl / Zecto Auto Pair might be enough:
https://ride.lezyne.com/collections/...1-led-2p-v1104
And then it's this pair:
Connect Drive Pro 1000xl / Strip Connect Pair
https://ride.lezyne.com/collections/...p-connect-pair
So many combinations. Total confusion.
Quoted: 1324 Post(s)
Liked 927 Times
I recently bought a Lezyne 1000 light. It's pretty bright and has a good range on a dark road. I bought the 1000 for two main reasons, #1 was that I wanted a beam that shone a fair distance down a dark country road (I like to see skunks well before I get to them so I don't startle them) and #2 I can run the light a lot longer on a lower setting. I find the middle setting very good for urban lighting and lighting urban road surfaces. The lowest setting is still excellent for a " Be seen" light.
Cheers
Cheers
if you want to do a lot of commuting and you do not drive on empty roads at night, get a light with a cutoff. None of those you mentioned do have a cutoff. Lezyne has the "StVZO" Category, the Power 115 is a solid light, albeit a tad narrow for my liking. The Power HB500 has integrated high beam. You could consider as well the cateye GVolt 70 or the B&M Ixon Space (order it in europe...) for your purposes. There is also a pretty solid chinese light with cutoff: Lumintop B01 (Aliexpress of banggood). If you want to spend a bit more, take a look at outbound lighting. If the sky is the limit (moneywise) --> Lupine SL/SLF/SLX or Supernova M99 Mini series, e.g. Mini Pro B54
Likes For polyphrast:
Quoted: 6934 Post(s)
Liked 10,938 Times
The "smart" lights seem kind of nifty -- but really, they address an almost non-existent need. That might be a case where simpler is better.
Quoted: 7342 Post(s)
Liked 2,441 Times
Agreed. A lot of "smart" gadgets are nice, and the enhancements help. But somethings don't need to be smarter. Imagine a bluetooth chef's knife. I can't, either.
Liked 10,938 Times
Liked 2,441 Times
No, I made up the bluetooth knife as an example of the kinds of things coming out these days.
Liked 10,938 Times
But if you mock my bluetooth-equipped Di2 bike, we're gonna have to disagree. It actually is pretty cool, and not very expensive.
Likes For Koyote:
Liked 2,441 Times
I borrowed my sister-in-law's Di2 bike. I liked it. It is definitely an improvement. I just can't afford that stuff yet. Maybe one day it will be the norm.
Likes For noglider:
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
Can you remove the strap from the newer Lezyne Drive lights? I want to add their GoPro mount to it, but it's not clear to me if that mount is only for their older lights.
I think that your conclusion has some weight to it, but that your argument is missing the mark. The problem is that a lot of tech is short lived today. Most smart devices relies on an eco-system and when one link breaks the whole chain goes. In the old non-connected/analog days that was not the case. So when Lezyne's app no longer is updated and later removed from the app store, the lights will be regarded as obsolete.
Likes For 1987:
Liked 10,938 Times
Likes For Koyote:
