Tubeless PSI?
Quoted: 1743 Post(s)
Liked 1,281 Times
Tubeless PSI?
I've been experimenting with my 25 mm Mavic USTs. I weigh 185 lbs and have been running 80 psi (rear) and 70 psi (front). Just wondering what others are doing and if there's some "scientific" way of finding your optimal psi. Talking about road bike for recreational rides.
Quoted: 6193 Post(s)
Liked 4,809 Times
Science involves experimentation. So experiment and see what works best for you. Noting your perceived effort for rides you do and what tire pressures you used is one simple scientific way to go.
Just keep the same tire pressure for six rides and record how you felt both energy wise and comfort wise. Then change the tire pressure and do six more, and repeat till you have an answer tailored to you.
Quoted: 20810 Post(s)
Liked 9,456 Times
Sure, there's a scientific way of finding it, but very few of us (with the exception of guys like RChung) are equipped to do so and it's going to change depending upon the conditions. There are various calculators online now, like the new one from Zipp (https://axs.sram.com/tirepressureguide), but those just get you in the right area, it's still up to you to tweak based on conditions and preferences.
If you really want more info, there's a good Cycling Tips Podcast about tire width and pressure (https://cyclingtips.com/2016/08/cycl...and-pressures/) from a few years back. It's about an hour, though, so those with ADHD need not apply.
Likes For WhyFi:
Liked 1,281 Times
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
I can see taking their suggestion, rounding it up to the next 5 or 10, and then let some air out on the first ride until it feels right.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Liked 1,281 Times
Oops. I rechecked and there was an error in one of the values used. It's a lot closer to what I'm currently using.
Liked 4,809 Times
Don't be so caught up in charts and formulas that you don't try higher or lower pressures yourself. They don't know what your riding conditions are like. Nor do that know exactly what you consider comfort.
Liked 1,281 Times
As I have said, that's exactly what I have been doing. I just thought there might be other ways to calculate an approximate value.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
SILCA TIRE PRESSURE CALCULATOR
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Ultimately, though, if its just for pleasure (i.e., you aren't trying to squeeze every single watt out of your bike), then ride what's comfortable! No need for more qualification than that.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Goes without saying though, you need to make sure your pump gauge is accurate. Most aren't in my experience.
https://info.silca.cc/silca-professi...ure-calculator
Quoted: 4717 Post(s)
Liked 1,882 Times
Liked 1,281 Times
https://blog.silca.cc/road-to-roubai...lete-story-1-0
FWIW, I have a ridiculous number of pumps (don't ask) and when I checked them against each other, there was nothing resembling consistency although most pumps generally seem to be repeatable even if their gauge is wildly off. What that means, of course, is if you take your favorite setting and borrow a friend's pump at the start of the ride, there is no guarantee that you're even close to the pressure you read off your pump.
J.
