Good shift/brake lever combo replacement
Quoted: 20 Post(s)
I am starting a new thread to my original post because this is sort of a new topic now. To sum up, I need to replace the brakes on my old Trek 820 and decided to switch to v-brakes. Since I need new levers for that, and I have never been thrilled with the grip shifters, I think I will just get a new shift/lever combo. My bike has 21 speeds and doing a little research, I have come across these Shimano ST-EF500 or these Shimano ST-EF65 and can't really tell the difference. Are either of these good choices or is there something else I am missing? Someone provided a link to ST-EF51 in the first post but it looks like the EF500 is a newer version. I already purchased the Shimano universal brake cable set so I have that to use and it looks like these both come with shift cables.
Really Old Senior Member
SE Wis
Quoted: 2747 Post(s)
Liked 3,403 Times
I personally prefer separate brakes and shifters for more adjustability.
Quoted: 20 Post(s)
That's a good point, but I don't know if that will be too much of an issue for me. I won't be riding that much, or off roading or anything so I probably won't need to mess around with them too much or be that particular. Hopefully these combos are pretty decent. I imagine they are better than the grip shifts I have!
Quoted: 20 Post(s)
I appreciate the comparison. I notice the 51's look different than the 65's (51's have a round display) but both the 65 and 500 look similar. Actually reading some of the reviews and questions, it looks like the 65's come with both brake and shift cables AND hosuings.
On the same bike, it seems it's just a click or 2 when the seasonal temperatures change.
Something that obscure could even bee the cable housing and not the shifter.
I have the EF-65's on BOTH bikes in the 9 speed version. The 4 finger version for my canti braked Rockhopper.
I have no complaints with either. They do what they should very well for the money.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Quoted: 20 Post(s)
the separate trigger shifters would have the index finger lever under the bar instead of over as in the EF series. Under the bar is closer to the resting position of my index fingers. Less reaching and less fatigue. And if you use four finger levers, separate is more flexible. Do consider.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
Combos are nice because the there's so many flavors of brake levers on old bikes and not all separate brake/shift combos match up nicely. The Shimano combo package includes cables/housing and works on both v-brake and canti brakes (with a little adjustment cam in the lever). They use a single band clamp instead of two so no position issues. It's esp an problem with narrow, curvy bars that many of those old MTBs had. Well worth the slight premium because everything will fit with good positioning and you'll have new cables
Other is V Brake only.
I certainly wouldn't call it a "cam". it's just a plug you install in 1 of 2 positions. Nothing converting rotary to reciprocating motion involved.
Quoted: 20 Post(s)
I admittedly don't know much about these, but I did read somewhere in the descriptions of both of these that the EF-500 is for V brakes only and the EF-65 is compatible with both.
Quoted: 20 Post(s)
The more I read, I am thinking a combo may be a better solution for me because my bike is not high end, older, and I won't be riding it all the time like a lot of people might. This sounds like a simpler, easier upgrade that will still be a big improvement over what I have.
Only the 4 finger version will also handle Canti.
The part# will have either a 2 or 4 in the suffix. You need the 4 version for canti.
Quoted: 20 Post(s)
I think I am just going to get the EF-65 I mentioned in the first post above because they come with everything (both sets of cables, housings, etc.) for $31. I don't see much difference between this and the EF-500 and this comes with all the cables. As far as the brakes, I was just going to get this BR-T4000 set for $14 per wheel, but then saw these BR-M422 for $35 for both sets. What do you think between those or anything else?
Quoted: 20 Post(s)
I just picked up the EF 65 and just looking at them out of the box, I am wondering about the index finger shifter. There seems to be no room to squeeze your finger between that and the brake lever. Maybe it is just because it is not mounted yet and will feel right when it is ,but I want to make sure before I mount them while I can still return them if necessary. Or do you just hit the top of the lever to shift without having to squeeze your finger between it and the brake lever. I hope I am making sense! Maybe the separate ones are easier, but hopefully I am just looking at this wrong.
I am glad I ran across this thread, as I am sort of in the same boat. I actually need to replace my grip shifters because something is not right but I never liked them too much anyways so I am not going to look too much into them. I was going to upgrade the brakes as well because they seem to drag a bit so I was also looking at the combo shifter/brake lever but this opened my eyes. Doing the pricing, it looks like going separate will only run about $10 more. What did you end up doing? I am curious if the separate ones are much more comfortable.
Quoted: 20 Post(s)
ljsense
Bicycle Mechanics
4
09-28-15 02:58 PM
bboy314
Bicycle Mechanics
12
07-08-11 11:54 AM
