Bike assembly aesthetics
Sr Member on Sr bikes
As I prepare to restore/refurbish another one of my old steel frames, I've been wondering about conventional aesthetic practices and standards for bikes...written and unwritten. I agree that some things just come down to personal preferences. Maybe there are some aesthetics that impact safety (strength). At any rate, there are things like 'seat post, stem, and cranks should match,' and on wheels 'hub logo should align with the valve hole,' etc. I searched and read through a few old BF threads (this one from the Classic & Vintage forum for example https://www.bikeforums.net/classic-v...ide-bikes.html). I found answers to some of my questions, but there are still others I'm wondering about. Things like: Should components (brake calipers, levers, derailleurs, shifters) all have the same finish? Should they match wheel finish? Should brake cable housing match handlebar wrap, frame decals/highlight? Should brake hood material match seat material? Any insight/discussion would be appreciated.
Dan
Dan
Quoted: 942 Post(s)
Liked 527 Times
A lot of that is in the eye of the beholder. Only thing I don't like is headset conversions on vintage frames, but that is solely my own aesthetic taste.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Dan
Dan
Untitled by Stuart Black, on Flickr
Has a silver Paul Components RHub in the rear and a black Paul FHub in the front. The important thing isn't the color of the hub but the hub. The rear wheel uses a Velocity rim while the front is a Mavic. They both work well and I don't really care that much about how it looks.
You might also notice that it has a Moots stem but the stem is upside down. I might change that in the future but right now it serves its function. It does have a Moots post, stem and handlebar but those really aren't necessary. The rear wheel is has rim brake and the front is a disc. I could...at some expense...have a disc tab put on the back but it's not all that necessary. The brakes work well enough to stop me on loaded rocky road bikepacking tours.
This bike
_IMG4971 by Stuart Black, on Flickr
is a riot of color but, again, it's not necessarily a match of components. The Race Face crank is there because it takes a 20 tooth inner. The Phil Wood hubs I used are there because they a excellent hubs. I use a SRAM drivetrain because I like the way it works and, well, it's not Shimano. Nothing wrong with Shimano but there just too much of it out in the world. This one has some matching components...Dean handlebar/stem and seat post...but it has had other stems and handlebars in the past. It doesn't really change it's function to have nonDean on the bike.
All of my bikes are like these two. I mix and match components based on their performance, not because they "look good" together.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Dan
Dan
But otherwise... having the brake hoods match the saddle, for example, to me is a bit OTT; however, any "bike illuminati" rules are just suggestions. Some things look better than others to most people, but that's always - ALWAYS - overridden by what YOU like.
I'm currently considering a build for my brother in law (if he decides he wants a vintage bike) and many of these things come into consideration - but ultimately it comes down to what the rider wants from the bike, and likes to look at.
No rules here, just my personal taste
Components look good all having the same finish. This is also because they should all be from the same grouppo.
But, brakes and wheels could alternatively match the frame or a highlight color. Also because I don't think brakes were always part of a grouppo depending on the era.
I really don't see brown housing working on many bikes even if they have brown bar wrap. Matching both to black is a default but maybe a bit plain. I have matched housings to the frame color, to a decal color, but also on a fairly solid color frame the cable housing can be used to make a highlight color.
Brake hood should match seat or bar wrap. Default to black here of course.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
If it hasn't been mentioned, the hubs should be laced to the rims so that the rim decal can be read right side up from the drive side, and the hub logo should be upright and readable while straddling the top tube.
Tire largest logo should be drive side (when feasible, given the tread pattern) and located opposite to the valve stem. Alternatively, the embossed tire pressure range can be located directly at the valve stem.
I've always believed that classic fashion rules apply. Keep the number of colors to a minimum to suit the frame. Use the color wheel to determine and use proper opposites. The degree of color saturation should be consistent with the style/era of the frame. Keep cable housings to basic black or grey, unless original for that frame would have been some alternate (like white or braided gold). Cable crimp ends are silver/grey, never colored. Pedals are not a decorator item, so should blend into the crankset (much as socks and shoes to a suit). That's my thinking, at least.
As the iconic Michael Kors once said, "fashion isn't for sissies."
Registered User
Quoted: 188 Post(s)
Liked 276 Times
I've read the tire logo should be placed at the valve stem to help locate puncture causing culprits when needed. Helped me out several times locate glass, thorns etc. Plus it is pleasing to the eye.
Another thing that is pleasing to the eye in my opinion is that the trailing spokes of the rear wheel drive side are installed so that they follow the wheel rather than lead. IMO, it just seems to make sense looking at it and not going against the grain. Also, I when I started building wheels, I read that the Sheldon Brown site saying it helps support drive side spokes. I have used it and never had a problem with wheels. Though some wheel builders say it does not matter, I think it only makes sense and is pleasing to the eye. In any case, why not do your best to get the best out of a wheel?
I've seen a few pro wheel builders who don't do it and if I mention it, they don't know what I'm talking about. Oh well, never had a problem with my wheels.
Notice the trailing spokes drive side are laced inside the hub flange for extra support as these are the spokes that take the most abuse and most stress.
Plus I think it just looks neater and going with the grain.
Jedi Master
If you care about C&V aesthetics get the stem and handlebars right. Level stem, drops parallel to the ground, tips of the levers even with the bottom of the drops.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
For example, Schwinn's shop guide said the drop ends should point to the rear hub.
Sunshine
Liked 7,490 Times
Likes For mstateglfr:
Quoted: 1819 Post(s)
Liked 1,693 Times
There is nothing sacred about the vast majority of bicycles. What is important is making them useful.
Jedi Master
Sure. Depends on the bike. I see a lot of old race bikes with the stem, handlebars and brakes adjusted to make them more comfortable to ride on the hoods, which doesn't look as pleasing to my eye as a more traditional race setup.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
All of those kind of rules are definitely made to be broken. I really try not to be concerned with what others think of what I have, or have not, done to my bikes. They are mine. I welcome suggestions and criticisms. Just understand that what I do with them is my decision, and if someone is offended by that, that is their problem.
Quoted: 643 Post(s)
Liked 1,526 Times
If you are trying to do a 100% original restoration, by all means research the details of whatever bike you're working on. Otherwise, do what you like and dare to be different.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Build it. Post a pic of it. I'll let you know if I like it.
Actually, I'm kinda into a classic frame with modern components and style. Picture a classic late 80's, early 90's Ferrari red Specialized Allez with a blacked out modern groupset and deep section rims. Black stem, bars, etc. It's been on my To Do list for awhile. One of these days...
-Kedosto
-Kedosto
Quoted: 1857 Post(s)
Liked 664 Times
If it were a period-correct grail bike that was somehow really valuable or rare or whatever (Pantani actually rode it, for example), then yeah those things would matter, a lot.
It's also, what "vintage" are you trying to imitate? There are grail bikes all over the timeline. From the '60s and '70s, chains could mostly not match pedals. Pedals were usually silver because the steel parts were chromed and nearly all aluminum was not anodized, at least in the early days. Chains were steel sometimes with anti-corrosive coatings, but I certainly don't recall any nickel-plated side plates. Quality stems in most of the 1970s were Cinelli, Ambrosio (aka TTT), GB, or one of several French brands - very little colored anodizing. Saddles were what you liked, but you could get Brooks, Brooks, Ideale, Brooks, Unicanitor (and similar), and Brooks. Brooks and Ideale brought out brown and natural finishes, eventually.
In the USA if you had a Masi it usually came (if not bought as a frameset) with Martano rims. If you crunched one while out on a tour, it was not likely the LBS had Martano in stock, if ANY tubular rims. If you found a dark anodized rim you took it, because otherwise you wait for the importer to send out a rim or for Poppa to come with the car. And if you bought the Masi by saving up your money from your local drugstore job, the price of the Martano could have been beat by ... most likely any other rim, so depending on your wallet, you would take the cheaper option. Some part upgrades were based on performance, such as replacing Campy Gran Sport with Record, or buying a Brooks Professional versus a B17 'cuz the TDF riders like the bigger rivet or some such bike salesman patter. Or the new Cinelli Cork Ribbon - it's squishy, versus Velox. As high schoolers our tastes were not yet refined, and the pocketbook was limited.
Some improvements were more valid than others, like the micro-adjusting feature of the Campagnolo Record seat posts versus the Brooks steel clamp.
There was still aesthetics, but function was a key part of it, kind of Bauhaus in spirit. Functional bikes were valid bikes. They could be enhanced with "matchy matchy" but such enhancements could also have been seen as prissy or too finicky.
But a lot of period-correctness was based on the practicalities of use. If you're commuting on sew-ups and you need a tire, you don't necessarily hold out for Seta, when you can get a pair of cheap but heavy Elvezias, and ride on to your job. If you needed a new rim 5 years after the bike was new, the LBS might not have the Martano in stock any more so you buy the new-fangled anodized Wolber or Mafac, because it's available. Same for broken spokes, derailleurs, broken chains, worn freewheels, et cetera. Worn chainwheels and the LBS never heard of Campagnolo? Buy the ones that are available.
Just a recollection of my opinions from back in the day.
Quoted: 645 Post(s)
Liked 797 Times
As I prepare to restore/refurbish another one of my old steel frames, I've been wondering about conventional aesthetic practices and standards for bikes...written and unwritten. I agree that some things just come down to personal preferences. Maybe there are some aesthetics that impact safety (strength). At any rate, there are things like 'seat post, stem, and cranks should match,' and on wheels 'hub logo should align with the valve hole,' etc. I searched and read through a few old BF threads (this one from the Classic & Vintage forum for example https://www.bikeforums.net/classic-v...ide-bikes.html). I found answers to some of my questions, but there are still others I'm wondering about. Things like: Should components (brake calipers, levers, derailleurs, shifters) all have the same finish? Should they match wheel finish? Should brake cable housing match handlebar wrap, frame decals/highlight? Should brake hood material match seat material? Any insight/discussion would be appreciated.Dan
Thanks for all the input, friends. Although the bike I'm referring to in my OP is from the 1980s (maybe even late 1970s), my intent isn't to restore it to it's exact (or even close necessarily) original look. Just a good, usable bike. And, it's a bike that most aficionados probably would not even consider owning. It's a TUNTURI. I actually rescued the bike from someone's trash heap (probably where you're thinking it should have stayed), cleaned and tune it up, and have ridden it lots and lots of miles for more than 30 years. I love the bike. Over the decades all of the components have been replaced...it's sort of a "Frankenbike"...but never the paint. But now it's time for that, and I plan on having it powder coated to the original white, and have already obtained replica green decals for it. Current (non-matching) components are fine...but I may replace them to all match. As indicated by many of you...much of the aesthetics are a personal choice. I concur. As I said, it's not going to be anywhere close to the original. But I just want to make sure I'm not breaking some of the major guidelines.
Dan
Dan
LOL. Finnish "tyres." The only liberties I'm taking with the decals is an idea from my old Motobecane that has a "Made in France" decal on the top tube. I had this decal made, with the flag of Finland, and "Valmistettu Suomessa" (Finnish for Made in Finland). Although I know, through a bit of research, that technically the bike probably wasn't actually constructed there.
Dan
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I peel the rim decals OFF of my bikes. I think they look trashy.
Quoted: 4227 Post(s)
Liked 2,488 Times
I choose function over fashion.
