Problem with front tire and brake caliper clearance
Old 09-07-20, 04:21 PM
robertj298
robertj298's Avatar
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times in 182 Posts
Took my Team Fuji out for a short ride today and noticed an intermittent
scraping sound coming from the front end. After inspecting it it seems with a wet
road my tire was picking up tiny prices of grit that were rubbing against the
bottom of the brake caliper .The tires are Serfas Seca 700X25 tires. The rear tire
seems to have plenty of clearance. Do I meed a smaller tire? Different tire?
Here's a photo.
robertj298 is offline
Old 09-07-20, 05:06 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
It would seem obvious that you need a smaller tire if you want to keep riding in the wet. Or you could take the other obvious option...don't ride when it's wet.
cxwrench is offline
Old 09-07-20, 05:13 PM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 264 Post(s)
Liked 122 Times in 101 Posts
Here's a photo.
That's pretty tight. On wet roads it will pick up grit and rub. Dry days it will likely be fine. But I would prefer a bit more clearance than that.
I have run them.that tight before but I was never happy with it and didn't do it for long.
blamester is offline
Likes For blamester:
Old 09-07-20, 05:28 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
LOL I would think a bike that comes equipt with 700X25 tires would ride ok with any 700X25 tire under any condition.
I guess thats not how it works with bicycles
Old 09-07-20, 05:33 PM
cxwrench
cxwrench's Avatar
Bikes: lots
That bike definitely did not come equipped with 25mm tires.
cxwrench is offline
Old 09-07-20, 05:43 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
Old 09-07-20, 05:44 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,392 Times in 1,927 Posts
Yes, a narrower tire would prevent that.
N.B. I notice that your caliper release lever is in the "open" position:
That's only supposed to be open to increase clearance when you need to remove the wheel. It looks like you used the barrel adjuster to take up the excess cable to compensate for this. Screw the barrel adjuster all the way down and then close the caliper release lever to bring the pads closer to the rim.
JohnDThompson is offline
Likes For JohnDThompson:
Old 09-07-20, 05:48 PM
cxwrench
cxwrench's Avatar
Bikes: lots
I don't care what it says on the spec sheet those OEM tires were not actually 25mm wide. It was very common to label a tire 25 or whatever when it was only 20-21mm wide and then claim you had the lightest '25'mm tire available. The front tire on that 35 year old bike is brand new, obviously not the OEM tire that came on it.
cxwrench is offline
Likes For cxwrench:
Old 09-07-20, 05:53 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
I had just loosened those to find out what was making the grinding noise thinking it may have been the brake pads hitting before I realized it was grit on top of the tire doing it
Old 09-07-20, 05:56 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Maybe check the true on the front wheel.. looks off center to me. Maybe you could get another mm of clearance
trailangel is offline
Old 09-07-20, 05:57 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
If that is the case, how are you supposed to know what size tire to put on a 36 year old bike that
doesn't have the original tires?
Old 09-07-20, 06:00 PM
cxwrench
cxwrench's Avatar
Bikes: lots
By doing what you're doing. Now you know that particular 25mm tire barely fits. Conti is most likely the same. I would probably stick w/ a 23mm tire, maybe a Conti or maybe the Specialized tires that are labled '23-25'mm. Cycling is a learning experience isn't it?
cxwrench is offline
Likes For cxwrench:
Old 09-07-20, 06:21 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
I guess I'm learning lol. Here I just assumed if a tire said it was 25 mm it would be 25mm. My next question would be is there any guarantee that a 23mm tire
won't have the same circumference as a 25mm wide tire?
Old 09-07-20, 06:26 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Nope. The cycling industry is famous for it's lack of 'standards'. Old bikes like yours had very tight clearances because people refused to acknowledge physics until about 5 years ago and firmly believed that small tires at rock hard pressures were 'fast'. Now we know better and bikes have much more room for big tires.
cxwrench is offline
Likes For cxwrench:
Old 09-07-20, 06:31 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
Read Sheldon. Pursue his other articles too-
https://sheldonbrown.com/tire-sizing.html
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 09-07-20, 06:51 PM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 459 Times in 361 Posts
700x25 tires from 35 years ago are probably a lot different than what we have now. It really just comes down to what will fit. My bike barely fits 700x25 Conti 5000 in the rear but has plenty of room for 700x28 in front. Put a 23 on if you're concerned. it won't feel much different. And your wheel doesn't look centered either, so maybe that is part of the problem too.
zacster is offline
Likes For zacster:
Old 09-07-20, 08:14 PM
Charliekeet
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times in 142 Posts
Another cure (if OP finds that running smaller tires doesn’t work out) might be running a different brake. Not all single-pivot side caliper brakes had the same profile and since the issue with the tire is height, not width per se...
Charliekeet is offline
Old 09-07-20, 08:24 PM
Russ Roth
Quoted: 1079 Post(s)
Liked 1,015 Times in 718 Posts
I just ran into one with a friend where he complained that he bought a 28mm tire for a more comfortable ride and it was worse then the tires he had one. Got out the calipers and despite being in a wider rim (sun rhino lite) the 28 measured 24mm wide and only 23mm tall. He'd actually been better off with the previous 25mm tire.
cxwrench nailed it, back when your bike was made narrow high pressure tires were the thing to run and sizes were even less accurate then today.
Russ Roth is offline
Old 09-07-20, 08:55 PM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,779 Times in 3,297 Posts
Tire width is usually the tire casing width. Or at least that is what I thought I read a long time ago. That doesn't include tread material which can be significantly different from one model to another.
You might find some 25mm tires that give you more clearance. Are you certain the noise wasn't the wheel out of true scraping the brake pads occasionally? And the brake blocks look badly lined up. So maybe one is hitting the tire.
Iride01 is offline
Old 09-07-20, 09:10 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2761 Post(s)
Liked 2,534 Times in 1,433 Posts
I’d would be fine with that clearance. I mean, more would be nice, but with tires that small, I’d want to eek out every mm I could.
Kapusta is offline
Old 09-07-20, 09:23 PM
Bill Kapaun
You could put on a super wide rim.
You'd probably have to shave the brake pads.
Easier to swap in different 622mm rims/tires from other bikes if available. That could give you some baseline knowledge.
Old 09-07-20, 09:34 PM
robertj298
robertj298's Avatar
Quoted: 677 Post(s)
Nope it wasn't the wheel out of true .I actually lifted the front end and spun the wheel slowly to where the grit would stop the wheel
Old 09-08-20, 08:42 AM
Mr. 66
Mr. 66's Avatar
Quoted: 1134 Post(s)
Liked 1,726 Times in 950 Posts
Did try flipping the wheel around? That will tell you if the wheel has dish, and or if the fork needs alignment.
Mr. 66 is offline
Old 09-08-20, 09:19 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
He is worried about clearance above the tire, not on the sides.
EDIT: Never mind, I see the logic in ruling that out.
Kapusta is offline
