1st gen Deore derailleur?
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Has anyone made this work with 7 speed indexed? It was made for 6 speed but I have the 7 speed thumbies and a wheel to go with it. Thanks.
Quoted: 500 Post(s)
Liked 466 Times
Doubt there will be a problem, assuming sufficient lateral travel.
Quoted: 4559 Post(s)
Liked 2,802 Times
I have Deore LX (M550) and nearly identical Exage CX500 nominally 7-speed derailleurs. Both will index shift reliably over 7-speed cogs, but to cover 8 speeds I need to switch the shifters to friction mode.
I examined both derailleurs closely and there's a tiny nub inside each that limits the pivot or swing. It's just enough to cause the derailleurs to nudge out of the 8th largest cog into the 7th with any serious pressure on the pedals in index mode; but it'll hold in friction mode.
One of my bucket list projects is to use a moto tool or jeweler's file to grind down the little nub that limits RD cage swing. If I screw it up on one RD, no biggie, the two models are nearly identical with only minor cosmetic differences and a hyphenated model number distinguishing the two.
I have used that derailleur with a 7 speed freewheel and downtube shifters. I don’t see why it wouldn’t work with thumbies?
Phyllo-buster
Liked 2,054 Times
OK, jury says most likely, excellent.
Quoted: 634 Post(s)
Liked 444 Times
I've run one indexed with 10 speed with bar end shifters and it worked surprisingly well. It's now paired with 8 speed on my GF's bike and that's somehow working too. Maybe mine has enough slop in it to be universal.
Go ahead & hook it all up & try it out. If it doesn't work, then get one of these. It will work just fine. (M591's have been a real problem solver on many bikes for me). These work perfect w/7 speed shifters.
Sale on Shimano Deore RD-M591 SGS 9-Speed Rear Derailleur For All type of Bicycles, Mountain Bikes, Mountain Bicycles, Enduro, Gravel and Cross Bikes even eBikes
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
First generation Deore was the so-called "Deer Head" group in 1981, and wasn't designed for indexed shifting.
Likes For JohnDThompson:
Phyllo-buster
Liked 2,054 Times
Thanks, I meant the post-Deerhead version from '87/88. '89 got the pseudo carbon screen background under 'Deore' and was 7 speed.
Phyllo-buster
Liked 2,054 Times
Thanks, I meant the post-Deerhead MT-60 version from '87/88. '89 got the MT-62 pseudo carbon screen background under 'Deore' and was 7 speed.
Quoted: 7348 Post(s)
Liked 2,465 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
The OP's Deore should work well as a 7s SIS derailer.
It looks like the spring from inside of the cable adjuster detent barrel has been placed outside of the plastic detent barrel, instead of inside of it where it is supposed to be. The barrel won't offer retention detents the way it sits now.
Likes For dddd:
Quoted: 500 Post(s)
Liked 466 Times
The cassette is a different story.
Yes absolutely. My go to chain for the last few years is the KMC X8.93. It works great on 5, 6, 7, & 8 speed drivetrains. (Also, I've recently noticed that KMC is changing their numbering system on their chains and, it's getting harder to find X8.93's). The most important thing to know about these KMC chains is the X designation. It describes the "double X bridge shape" and, helps make indexed drivetrains work perfectly.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Yes, KMC's new designation for the X8.__ chains is simply X8. I think the X8 Silver/Grey is the old X8.93 and the X8 Silver is the old X8.99.
8 Speed Archives - KMC Chain
The X8 series is also my go-to chain for nearly everything. You can often find them for $10-12 online, which is a solid value for a good chain.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
The one with the cranks with the big pedal holes...
Commence to jigglin’ huh?!?!
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 334 Times
