Road Bike Tire question (possiblly stupid!)
Road Bike Tire Question (Buyer Beware)
Hi, unbelievably, I bought my first bicycle tire in over 30 years as I have been riding on the originals after the bike sat for 30 years, prior to my getting back on the bike last year. I noticed wear on the rear tire, so ordered a Vittoria Zaffiro 700x25c tire. I am trying to mount the tire on the wheel a Wolber T410 Alpine (on a 1987 Cannondale SR500). The tire seems way too large, and has a much larger beads than the old Performance tire it is replacing which is marked 700x25.
Is this the wrong tire? Aren't these rims made for Clinchers? The old tire just seems much smaller and especially thinner and lighter. Thanks!
Edit: See below.
Edit: See below.
Well the tire is fine when I spin it and pedal it in the work stand. However, when I pedal on the road it is binding somewhere due to the larger size of the tire. It is either binding on the front derailleur braze on, or the chains stay where it connects to the seat tube, or both. Very little tolerance in both locations. It is annoying as hell, and I can feel the additional resistance. I don't know if others have experienced this. I may have to go to a 700x23 tire which I really didn't want to do as the newer 700x25's are just too big.
So this issue isn't as stupid as I originally thought. The Vittoria 700x25 tire is Significantly bigger than the Specialized 700x25 tire it replaced in both height and width. Be careful if you have an older frame with tight tolerances. This tire probably won't work for me.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
The older tires must have shrunk over the years. Just kidding. There is much variability of actual tire sizes compared to labeled sizes among different manufacturers and between different models. Going down to 23mm likely only way to be sure of getting a tire that fits.
Thanks, that's what I may have to do or mic the width, and length and see what other tires will fit. However, I doubt even a 23mm sidewall height will be shorter, and I think that's the bigger problem.
The late 1980s was when the narrow tire fad struck hard. Even though your tires are labelled 25mm, it's possible that they measured closer to 20mm.
If you can't fit 23s, then unfortunately your options get pretty thin, pun not intended. A few specialty time trial racing tires can still be found in 700x20-ish sizes (like the Continental Gran Prix Supersonic), but across most tire styles they've vanished; there just aren't very many road frames being ridden anymore than can't fit at least a 23.
Can anyone recommend tires that will fit this 1987 Cannondale SR500 road bike?
Quoted: 152 Post(s)
Liked 173 Times
If you go to The Bicycle Rolling Resistance website you can look check the actual width of a whole bunch of tires they have tested. You can also go into the filter section and order the table by tire width. Looks there is a 24mm & a bunch of 25mm actual width tires available. The really skinny ones are higher priced but if you amortize the purchase over 30 years it doesn't seem so bad Also, be aware the width of the tires will differ depending on the inner width of the wheel they are mounted on. The wider the wheel, the wider the tire will inflate to. Most of the tires they test are 25mm but it will give some reference anyway.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Hunh.
My 1988 Cannondale SR500 fits Vittoria Rubino Pro III tires quite easily, and they measure out mounted at 24.85mm on Mavic Open Pro rims. 1988 and 1987 frames are identical.
Admittedly, the tight spot on those frames is always going to be the mount for the front derailleur. But most 25's and all 23's should fit just fine. I'm wondering if the bead got seated properly into the rim.
Hunh.
The Zaffiro looks like a Mountain Bike tire compared to the original Panaracer on the front and the Specialized that I put on the rear when I shredded the rear Panaracer 30 years ago.
Let us know what it measures. I have '85 & '86 SRxxx frames and never had a problem. With tires that measure 23mm, regardless of label, I have ample room on all sides at the chainstays. The brake clearance was my main concern. Although, these are smaller frames, with slightly steeper seat tubes.
Bad example
Quoted: 828 Post(s)
Liked 215 Times
So the tire rubs only at this point, rather than over its entire circumference? If so, true the wheel first, before you try anything else.
The original 700x25 tires that are on there are actually 21.4 mm in width and the new 700x25 tire is 25.2 mm in width, so a pretty large difference.
Quoted: 850 Post(s)
Liked 344 Times
There are two potential rub points, but yes it only rubs at those points not the entire circumference, I am going to true the wheel anyway and see if it works.
Very frustrated. I had my LBS true the tire today. I installed it after work for a short test ride and it still rubs on the chain stay near the attach point to the frame. There is now a wear point where the paint has been removed where the tire is rubbing. The tech at the LBS said that I could wear a hole in the frame in a very short amount of time and few miles. Maybe the Vittoria Zaffiro is just a thick tire. I ordered a 23mm tire to see if that will fit.
Quoted: 4560 Post(s)
Liked 2,802 Times
I've used 'em on two road bikes for the past 17 months and thousands of miles including rough Texas chipseal (basically, gravel bound in polymer-modified bitumen), no problems. One set in 700x25 on the '89 Centurion Ironman, another in 700x23 on the early '90s Trek 5900. Those chipseal roads chewed up my favorite road tires, the Schwalbe One V-Guards, which had few flats but got lots of nicks and cuts in the tread. The Conti Ultra Sport II is much tougher, yet cost less, ride almost as well. Can't find a thing to complain about.
The Trek 5900, their early pro road racing bike, has fairly narrow chainstay clearance and even 700x25 might be pushing it a bit. But it's fine with 700x23.
Incidentally, my Trek 5900 has the same Wolber Alpine rims laced to Shimano 600 hubs. Good wheels, no problems with various 700x23 tires I've tried.
If your C'dale has really narrow clearance, you can still find some 700x20 tires. These are usually mid- to high-grade road racing tires, but discontinued or unsold new/old stock, often heavily discounted. Good way to play with some fancy tires for not much money. But they probably won't last long, maybe a few hundred miles or up to 1,000 miles according to some users. Merlin in UK has some spiffy Veloflex and Onza racing tires in 700x20 now for less than $30 each. I'm kinda tempted.
I've tried the Vittoria Zaffiro 700x23 wire bead tires and they were just ... meh. For the same price the Conti Ultra Sport II is much better. The Zaffiro's felt harsh at full pressure, sluggish at lower pressure, cut easily, skid too easily and didn't grip as well as the Contis. Zaffiro is an okay tire for non-critical use, but not a good value compared with the Conti.
Likes For canklecat:
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
Michelin Lithon, Conti GP4000 and any number of similar folding bead performance oriented or road training tires will fit. Your insistence upon using a tire that is too large on an out of true wheel is going to/will/already has ruined your frame.
That's the most ridiculous thing I have read here. I've only put a few miles in the bike since the tire change. The wheel is now true but only had a slight wobble in it previously. The frame is NOT ruined. A 700x25 tire SHOULD fit as others have stated. I have ordered a Conti 700x23 to be safe. In the meantime I am re-installing the old tire until the new one arrives.
Note: For the late 80's Cannondale SRxxx frames the Vittoria Zaffiro 700x25 tires will not fit on the rear. It has too tall of a sidewall and the 25mm is too wide. The 23mm may fit though, but I am not going to use that tire for this bike again.
And no, I didn't have the bead installed improperly.
