Latex Inner Tubes: More Than They're Worth?
Quoted: 24 Post(s)
Latex Inner Tubes: More Trouble Than They're Worth?
I've heard so much about latex tubes, about how nice they are to ride on, I wanted to give them a try. I picked up a pair a while ago, but hadn't got around to installing them yet. Anyway, tonight I thought I'd stick them in so I could try them out tomorrow. Took the rear wheel off, removed the butyl tube, stuck the latex one in, started pumping, seemed ok, got to around 50 or 60 psi and BANG! Took it out and examined the tube, and there was a very large hole (so large that I could see through it) in it. I put a patch on it and then tried again, BANG! Did the same thing and tried for a third time, BANG! I gave up, stuck the butyl tube back in and stuck the wheel back on the bike.
Bearing in mind that I'm uber careful when installing inner tubes (putting a bit of air in before installation, and examining both sides afterwards to check the tube isn't caught between the tyre and the rim, and I've installed the ultra thin Supersonic tubes with success) are they just too much trouble?
Quoted: 1975 Post(s)
Liked 232 Times
Something obviously is wrong with your technique or rim/tire that is causing the damage. I've never had this issue with butyl or latex tubes. Install is about the same, at least with the vittoria latex tubes.The bang for the buck in terms of suppleness and watts savings is hard to beat.
Liked 232 Times
It should be obvious from the location of the hole in the tube what caused it, whether it was a pinch between the rim and the tire, spoke hole not covered properly, sharp rim strip edge, or debris in the tire.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Your rim strip is likely the issue. You need to use tubeless tape.
Latex tubes are the biggest bang for the buck performance wise you can possibly get. Installation takes some prep and care, but I usually get a full season out of mine unless I hit a big rock or something.
Google slowtwitch.com and how to install a latex tube and you should get lots of info.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I tried the Latex on clinchers.... after riding tubulars for 12 years... thought I'd get the ride feel back. No go. Same result as OP. My theory ....Latex goes bad when exposed to light. How are they stored before you purchase them (unknown)? In tubular tires latex tubes never see sunlight, except to repair them. Not really any weight savings. Went back to Conti Race Light about 70grams... the same weight as latex. Can anybody tell the difference? Clinchers are so good now, not like 40 years ago.
Best Bang For The Buck?..... not IMO
Quoted: 24 Post(s)
Liked 232 Times
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
FWIW I started running latex tubes a couple months ago. Installation was a pain as it was very tough to get the tube past the bead.
That said, I have been pleased with the ride.
My guess is you have a tiny rough spot that is puncturing the tube. See if you can identify where the pops were and focus your efforts there.
Role of patching latex tubes is a separate issue that is controversial, save that for another thread.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
This is funny, because I'm a monkey with mechanical stuff and never had these issues with Vittoria or Michelin latex tubes. Yank out the existing rim tape and use a double wrap of Stan's, and wide enough that it goes from wall to wall (not whatever's recommended). Slightly pre-inflate the tube prior to installation. Ensure the tube is entirely within the tire before locking the second bead, and ensure the tube is not pinched. I can all but guarantee you that will work, reliably, for as long as you care to use them.
Note also that those are the best practices for butyl tubes as well.
Bikes: FM098-V2, '16 Synapse
Quoted: 81 Post(s)
I've had similar problems as the OP on some wheels, in spite of retaping and what-not. On other wheels, it's been entirely straightforward.
Quoted: 2323 Post(s)
Liked 4,988 Times
Yep, been using the Vittoria's for years with no issues. I tried a different brand once (can't remember which) and it split when first inflated. Vittoria latex tubes have been rock solid for me and I guess around half of my 30 or so bikes have them on them. Something weird must be going on with the install
Steel is real...and comfy.
Quoted: 1020 Post(s)
Liked 463 Times
I have been using Vittoria latex inner tubes for many years with no issues.
They are comfortable and seem to be more puncture resistant than butyl tubes.
The only issue is that you can’t use CO2 cartridges (or at least I have not been able to use cartridges). When I’ve tried it the sudden drop in temperature made the tube burst.
Other than that, they are great.
Quoted: 645 Post(s)
Liked 797 Times
I've ridden latex for the last couple of years - Vittorias, IIRC. Mild PITA to install, rode beautifully, but just a little too fragile. I had the occasional flat from no obvious cause except the tube just decided it was time. They're readily patchable, but I've had more flats in those couple of years than in the preceding 10 years on butyls.. I think when the current latex tubes finally give up the ghost, I'll switch back to butyls full time
I run latex tubes and have experienced far less issues then using butyl tubes.
Interesting read, I have been told latex tubes are more puncture prone and likely to get flats if ridding on rough or poorly maintained roads so I've stayed away. Some here state the opposite....
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Saving 5 watts per tire, probably even more with some of the tubes I use, I would gladly pay the extra cost and put up with the relative fragility. But having to air them up all the time is the deal-killer for me.
Bikes: bikes
Liked 1,429 Times
Nearly the whole of the professional peloton uses latex tubes (in tubulars). Paris Roubaix, Flanders, Strade Bianchi, etc., etc.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
The OP's experience with latex tubes is all too familiar. After several customers demanded their money back on the "defective" latex tubes we stopped bringing them in. Nothing defective about them, total operator error. Tires are tougher to seat with them, that's all. When done correctly they don't go "BANG!"
Farmer tan
I used a latex tube as my spare for a couple years due to the fact that it rolled up so small.
It never occurred to me that it might be difficult to install roadside.
Luckily I never needed it.
