Internally routing cables
Randomhead
Liked 3,713 Times
It's a chain slap protector. It was pretty common on French randonneuring bikes. You can buy them from Compass.
Quoted: 45 Post(s)
Liked 44 Times
I spent quite a while admiring the clever features and top craftmanship on that frame but the chainstay protector looked out of place and a bit naff. Looks like something a barber would have on the wall for stropping his razors :-)
Inside
The orange bike has a brass tube silver brazed in side for full outer brake cable housing no rattle at all . Check out M.A. P. Bicycles you’ll like it.
Quoted: 4220 Post(s)
Liked 3,906 Times
I see that the orange bike took enough care to supply a spare tube so that after the top one cracks you can use the spare . Andy
AndrewRStewart
AndrewRStewart
So where on the top tube is the proper area to place the holes for the routing? Closer to the joints are farther away? I would put the entry on the "lower left 45" on the front, and then more in the "upper center-leftish" on the rear; if that makes sense. But how far away from the joints themselves? 2", 4", 6?
Trying to learn. Thanks in advance.
Brandon
Brandon
Liked 3,906 Times
Since there's some greater possibility for the tube to suffer a crack at the cable port I suggest it's placed in the thick walled section. Perhaps the butt lengths should be figured out WRT to the ports. Andy.
AndrewRStewart
AndrewRStewart
Quoted: 716 Post(s)
Liked 804 Times
There is a series of photos in this Flickr album, showing how I did the internal brake routing on one of my frames. https://www.flickr.com/photos/starrc...57641510596513
Randomhead
Liked 3,713 Times
I had it in the back of my mind that 1/4" .028 tubing will work for this, but brake housing is 5mm and that means that .026-ish wall tubing is needed. I have seen reference to 7mm tubing, where can I get some of that?
On edit: I see there is 1/4" OD, .2" wall which should work. Wonder if I have any.
I use these guys for SS tubing for internal routing.
https://www.mcmaster.com/catalog/124/172
Randomhead
Liked 3,713 Times
yeah, I have almost $300 of small parts in my cart at mcmaster right now
That's where I saw you could get 1/4" OD, .020 wall tubing
Quoted: 716 Post(s)
Liked 804 Times
I have a milling machine now, so I would use a 1/4" end mill to make a slot and then fine tune the fit with a file.
Its best to practice on a scrap piece of tube to figure out how wide and long to make the slot.
Randomhead
Liked 3,713 Times
doing it on a practice tube is a good idea. I have a pile of tubes I bought to practice with, have to do this on one of those
Hello there,
Do you think it is doable to Stuff internal routing with a piece of metal and braze it then fill it to get back to a plain tube so you can put external routing ?
The internal routing is made by a tiny tube wich goes in the top tube.
Thank's
Thank's
Liked 3,906 Times
Sure, one can fill a accessible tube with all kinds of stuff. Calking comes to mind. If you ever wanted to go back to internal routing I suggest thinking about what you use as a plug/filler. Andy
AndrewRStewart
AndrewRStewart
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times
On the older (bonded) aluminum Trek road bikes, they would have a huge hole on the seat tube where the top tube joined, and you would insert a long foam tube into the top tube (after the brake cable was installed) to keep the brake cable housing from making noise.
Sunshine
Quoted: 11015 Post(s)
Liked 7,559 Times
My frame used cable stops and a brass internal guide tube. If there is cable slap inside the tube, I sure cant hear it. Its all brazed together and quite solid. Making the entry and exit ports at an angle(other than at 12oclock. mine are about 7:30) will help reduce the chance of water penetration, as well as the fact that its just an overall snug fit.
Thank you! Do you happen to have a pic of the tubing you run in the top tube? Last night I ran my first brass tubing for the brake cable. It will be for the full housing. It came out really good actually and I thought it was easy. Just took some time to get it right. I can refine the process a bit more though. I was on the fence of running a housing stop set up, but thought I'd give that a go on the next one. I'll take some pictures when I get home today and put them up.
Here are the pics. I got a little silver happy but overall, I'm very pleased.
Randomhead
Liked 3,713 Times
thanks for posting. I have to do that this week, it's bike building week. Now I'm thinking about retrofitting a frame with this first.
Randomhead
Liked 3,713 Times
I don't understand what you're getting at, can you elaborate why would want to remove it?
