Most desirable tubing for an XL touring bike ?
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
Try bending aluminium back into shape without it fracturing. You can't. Try finding someone who can weld aluminium in a far flung place. You won't. The same applies to new-fangled materials like carbon fibre. Try repairing that if it fails.
The only answer is good old-fashioned, but tried and tested steel. Steel alloys have continuously evolved with the times, ever since good old Reynolds 531. With lighter, but stonger tubing, but still retaining the advantage of steel.
You can't beat the "feel of steel." Remember only "steel is real", especially in a touring bike. Where reliability and durability, are more important than anything else.
even I find your poetic waxing over the romantic idea of a steel frame touring bike to be over the top.
Rather than ask the forum to micromanage this,
crack that wallet open and get that build money out... 4 figures..
Tell experienced builders , of touring bikes , like Co.Motion, Size;
how big a frame you need, how heavy you are,
and how much you plan to carry , on tours
and leave it to them to pick the tubing brands, wall thickness, and diameters..
As they make tandems, they are experienced in this, also..
few have given it more thought than Trek and for 2019...
Ok, the most controversial change to the Trek 520 is the new aluminium fork. Really, a steel frame and aluminium fork?
Bikes: 92 Bridgestone xo-2 Turner Sultan
Quoted: 47 Post(s)
1- a bike thats meant to handle weight well wont then feel lively when unloaded. Conversely, a bike thats meant to feel lively when unloaded wont handle weight as well.
Life just doesn't work that way.
2- with that said- quality double butted cromo tubing that is oversize(OS) works great for an XL size frame touring bike. 9/6/9 tubing is thin enough to feel fun when riding and thick enough to handle loaded touring.
- OS tubes are stiffer than traditional sized tubes.
- .9/.6/.9 will be great if the weight makes sense. A 220# rider with 40# of gear may be fine while a 260# rider with 40# of gear may feel some flex.
- .9/.6/.9 wont be as lively or as light as .8/.5/.8 tubing on the same bike.
you need to decide if you value the unloaded feel or the loaded feel more.
also- more important than material details is geometry. Geometry will affect how a bike feels when riding more than small tubing differences.
Let's start with a seat tube angle of 73, chainstay at 450...what else ?
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
I (6'5", 230lbs) finished a fully-loaded tour this summer on my no-name aluminum touring frame with aluminum fork. My chum (6'4" 260 lbs) was riding a new brand name steel tourer. We tried eachothers bikes and he claimed to prefer my bike as he felt his was too flexy. My bike was also noticeable lighter when unloaded (my friend packed the kitchen sink as a place to keep the bathroom and laundry room sink he also packed, so loaded comparison is not valid).
In my experience, aluminum is a better material for heavy riders. Steel may be easier to repair, but aluminum, in my experience, is less likely to need repair.
Signed,
Lover of steel and classic bikes
Signed,
Sunshine
Liked 7,485 Times
depending on 72.5 or 73 HTA and 50 or 55mm fork rake- you will get a trail of between 49 and 58mm, the 49mm of trail is with 73HTA and 55mm fork rake for the least trail of the different combinations.
As for stack, reach, and bottom bracket height- all those would be dependent on the actual frame size needed. I would certainly want a taller head tube to allow for fewer spacers. most likely a 6degree sloping top tube to help with stack height and make mount/dismount easier.
Quoted: 47 Post(s)
Thanks for all the comments. Please critique this geo (XL/59 Rocky Mountain Sherpa 30);
TTL 630
HTA 69
HTL 130
STA 73
STL 508
CL 445
BBD30
REach 438
Stack 631
Standover 723
Wheelbase 1159
Tubing- Reynolds 725
TTL 630
HTA 69
HTL 130
STA 73
STL 508
CL 445
BBD30
REach 438
Stack 631
Standover 723
Wheelbase 1159
Going to build it yourself ? consult this section; https://www.bikeforums.net/framebuilders/
Quoted: 47 Post(s)
Quoted: 47 Post(s)
Bob
This may be a shock to you, but I'm not a frame builder...I interpreted yourself as having one custom built, but after checking it's out of my budget. Now,considering buying a Soma Saga frame and building it up...
63 is a pretty long top tube, especially for a 59... "XL" is more like a size 61 or more and it'd be pretty long for that size bike too-- that's a feature that Lemond road bikes exhibited and many commented about being too stretched out. Heat tube length would be much better over 200... maybe 230 or more on a XL
Without question the only touring bike I have ridden over 60cm in size with burdened with 40-50 lbs of gear that performed like a road bike was the old Cannondale Touring (This bike has been mentioned in an earlier post). They were magically competent loaded touring rigs.
Cannondale does have a touring model available now. It has updated tubing and design along with disc brakes. Rides like a road bike unloaded for sure. Have yet to load one up with gear, but I suspect it will do just fine. If you can find a vintage Cdale Touring frame in your size do consider it as they really were great bikes out on the road with gear.
So as a tall rider myself, 6’ 4” 190lbs, I tour on a 2016 Trek 520 Disc 63cm frame. Even when I have done my best to even out the load front to back and side to side I still experience a lot of frame “shimmy” at speeds over 14mph... The bike is built to handle a lot of weight but I don’t think they put much or any thought into the dynamics of the frame at the larger sizes. It’s sad when you feel unstable going down hill on a bike that is purpose built for loaded long distance touring.
I wish I would have considered AL or even (the ugly IMO) double top tubes of a rivendale... I still have some stuff I can try on this bike 1. A IRD double roller bearing headset and 2. probably a velo orange front wheel stabilizer. If that doesn’t work then I am out of luck and will probably sell the bike or just keep it around as a winter commuter.
I primarily own steel bikes except for a carbon fatbike, so I do appreciate the dampening qualities of steel but in this case it is to much of a good thing. I have mostly kept slient on people criticizing Treks choice for a AL fork on the new 520 but part of me wonders if it does stiffen things up a bit, especially on a bike with disc brakes that can be a good thing.
Sunshine
Liked 7,485 Times
My touring bike is a 64cm frame from 1990. It has a 25.4 top tube and steerer and a 28.6 down tube and seat tube. Handles my 230# plus gear just fine. I have about 30# on it, give or take.
Everyone’s expectations for ride are different. Everyone’s perception of what is safe is different. Everyone’s level of comfort is different.
Etc etc etc.
There is no right or wrong frame design or tubing for a touring bike as its simply individual in nature and everyone like something a little different than others.
I mention all this because I often see claims that traditional tubing is too flexible and even sometimes see a comment that its flexible to the point of dangerous. I chuckle when I read that since I am in the high 90th% for height and weight and somehow manage to feel totally confident on a traditional tube sized touring bike that’s 64cm. I have never felt unsafe on it.
The tubing is splined, which creates a stiffer main triangle compared to un-splined tubing, but I would guess it’s a small bit stiffer and not something wildly dramatic to where it makes traditional diameter tubing as stiff as OS tubing or something like that.
Anyways, there are a lot of touring bike styles available and that matches perfectly with there also being a lot of touring riders who like different styles.
Nothing is perfect for everyone. Someone may love a huge OS downtube Cannondale touring frame. Someone may love a whippy 531 frame from the early 80s. etc etc.
For what its worth, I have a Cannondale Touring frame from about ’93. HUGE downtube that’s bazooka in size. Its hanging on a hook in my garage waiting to be built up…maybe this winter. No desire to use it for loaded touring due to the tire size limitation, but it should be fun to build into a canti-brake road bike. I will be interested to see how harsh the ride is given the tubing design and riding it unloaded.
Etc etc etc.
Quoted: 3459 Post(s)
Liked 1,465 Times
If he did not like the bike, he would not have kept using it for all those trips.
Quoted: 2604 Post(s)
Liked 1,928 Times
Sunshine
Liked 7,485 Times
Pretty sure its a T700 from '93. max is 32mm tires with fender or 35mm tires otherwise. Thats going off what remember when I measured over a year ago after buuing the frame.
Im sure itll be a fun ride once built up. Itll be interesting to ride it right before/after my touring bike to feel the difference in flex with that seemingly 60mm downtube.
Liked 1,465 Times
Another friend of mine had an early Cannondale touring bike, but it took 27 inch tires. He no longer has that bike. I think that bike also had a freewheel instead of cassette.
My Lynskey Backroad has a downtube that measures about 1.75 inches in diameter.
I was not Either, but after gaining brazing and metalworking skills,
being mechanically inclined father in metal trades, my bike shop jobs, etc
I gave it a try.,
worked out OK.. I did not try making a business out of it...
Soma , surly, salsa, Trek 520, will all get you down the road.. carrying your stuff.
so in the end you just turn over all the 'most desirable materials' choices,
to the company, importing the frames from a big company in Taiwan,
probably Maxway ,
a big OEM factory all of the above have gone to for many years ,
because they're good an it and beat the costs
of doing it in the States..
Quoted: 137 Post(s)
Liked 81 Times
Where are you going to get the fibreglass from?
If you could get fibreglass, how effective would it be especially if the rear drop out had snapped. This tends to be the part of the frame under most stress. I have had a few frames fail in that particular place, rather than anywhere else. There is not much space between the drop out and the hub, which needs to rotate freely with no fouling.
You often see touring cycles massively loaded on the rear, with little on the front. Surely, that is asking for trouble, especially if the rider is heavy.
Personally, I would try and find the bloke with the two car batteries and a stick welder. He might make a rough repair, but hopefully it would hold and you can have a proper frame repair later.
If I had the choice of a fibreglass repair, which is epoxy resin (basically plastic), with small strands of glass in it. Or a repair using steel, which is much stronger and that the bike is already made out of. I would choose steel every time.
Actually a couple dozen ft of 1mm kevlar line and a couple tubes of epoxy could make a good mend where applicable. My experience is that purpose bult bikes very rarely fail. Can’t beat some of the early 80’s mtn bikes with big tubes.
Quoted: 137 Post(s)
Liked 81 Times
To reinforce what fietsbob said tell the builder what your intended use is and what you like to do then leave the geometry to him. Speaking as soneone who knew frame builders, toured a lot and raced a bit and had dozens of bikes and a couple custom steel frames. The frame builder has more experience seeing the results of their ideas than a riders extrapolations.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,646 Times
Quoted: 2482 Post(s)
Liked 2,952 Times
Shame that the OP is unlikely to consider aluminum, despite the positive reports in this thread from bigger riders who have toured on Cannondales and found them superior to steel-framed bikes. They remind me of the 285-pound weightlifter who bought a Cannondale from me and stopped by the bike shop a few weeks later to tell me how happy he was with it. He said that it was the first bike he'd ridden that didn't feel like overcooked spaghetti under him.
