Aftermarket kickstands for Brompton...anyone?
Real-world input would be nice...the Missus is really tearing her mudguard and rollers up and has expressed interest in a more traditional style kickstand for her M6L.
At the princely price of most of them I'd like to know a bit more BEFORE I buy.
Anyone using one of the 3 or 4 available aftermarket/purpose-built Brompton stands for a more traditional parking experience?
Thanks in advance...
Schwinnasaur
My advice, and I have tried more expensive ones is to get the one from Greenfield. It sticks out further than the others. There are two problems. It weighs double and it interferes with the Brompton pump. I over came the first by replacing my extended seatpost with a ti post. I replaced my pump with a Lezyene pump that fits inside the seatpost and it has a hose and is an improvement over the Brompton one. The kickstand has better stability. It needs to be cut to size which is easy.
My initial reaction to some of the others is the fastening point appears to be less than ideal, and I'd worry about it swiveling under weight since there is no redundant anchor-point except the axle nut. The Greenfield apparently is anchored at two points.
Schwinnasaur
Good input..Thank You. Can you elaborate on your preference over the pricier (smaller) ones you've tried?
