Tire recommendations for CAAD12
Old 10-19-18, 10:20 AM
Robert A
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 559 Post(s)
Liked 63 Times in 45 Posts
Looking for 28c clinchers for my new CAAD12 Ultegra with rim brakes. Priority is good ride quality,freedom from harshness, and reasonable puncture resistance. My riding is on urban roads
Been reading lots reviews and comments on the Cont GP4000sii and the Schwalbe One V-Guard as well as the new Michelin Power series. I know Conti is the go-to for a lot of riders. Some have said it tends to pass more road shock through than others. Lot of people also like Schwalbe.
Most reviews focus on speed and puncture resistance, less so with ride quality. I suppose it's very subjective.
Comments and suggestions would be appreciated.
Robert A is offline
Old 10-19-18, 10:26 AM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
Schwalbe pro one tubeless
Elvo is offline
Robert A
Quoted: 559 Post(s)
Please explain.
Robert A is offline
Old 10-19-18, 10:38 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
Those people are totally full of it.
rubiksoval is offline
Robert A
Quoted: 559 Post(s)
Please explain your comment.
Robert A is offline
Old 10-19-18, 11:00 AM
rms13
Quoted: 276 Post(s)
Liked 6 Times in 3 Posts
I like Schwalbe One mostly because I have usually been able to find them for less then the equivalent Conti or Michelin. If anyone can really tell the difference between ride quality and road shock between three tires that are basically identical other then brand name then you are a better man than I am.
Puncture resistance comes with weight and ride quality penalty so I'd just go with good tires and a spare tube/air supply which you should have regardless
rms13 is offline
Old 10-19-18, 11:12 AM
rubiksoval
Bikes: bikes
Those people claiming that are full of crap. They can't feel that any more than they can feel a difference in a few lbs of air pressure.
Old 10-19-18, 11:18 AM
Elvo
Quoted: 630 Post(s)
Please explain.
https://www.bicyclerollingresistance...d-bike-reviews
Highest puncture resistance out of the top 10 lowest rolling resistance tires.
Elvo is offline
Old 10-19-18, 11:46 AM
Robert A
Quoted: 559 Post(s)
Yes, but what about ride quality between the different tires?
Robert A is offline
Old 10-19-18, 11:58 AM
Elvo
Quoted: 630 Post(s)
It's tubeless so you will run 10-15% lower PSI than tubed tires which makes significantly more comfortable.
Elvo is offline
Old 10-19-18, 12:11 PM
Robert A
Quoted: 559 Post(s)
I was only asking about standard clinchers, not tubless tires.
Robert A is offline
Old 10-19-18, 12:24 PM
Elvo
Quoted: 630 Post(s)
Tubeless will be lighter, will seal up punctures up to 0.25", is just as fast, and is more comfortable.
Elvo is offline
Old 10-19-18, 12:29 PM
Robert A
Quoted: 559 Post(s)
Okay, worth noting. My current rims don't take tubeless.
Robert A is offline
Old 10-19-18, 03:55 PM
Dean V
Quoted: 1067 Post(s)
Liked 259 Times in 153 Posts
The more relevant question for the Conti's is not ride quality, but if they will fit?
I do not know as I don't have a Caad 12 but they are quite a big tyre.
Dean V is offline
Old 10-19-18, 03:56 PM
Robert A
Quoted: 559 Post(s)
I'm told they do. I've installed Michelin Pro4 Endurance in 28c and they fit with plenty of room to spare.
Robert A is offline
Old 10-19-18, 04:02 PM
Dean V
Don't think you could go wrong with the Conti's then.
They will be as fast as anything else and I have found them to have adequate wear and puncture resistance qualities.
I would not believe any comments about them having a harsh ride. They do not and really I do not think any fast rolling tyres do.
Dean V is offline
Old 10-19-18, 06:28 PM
TiHabanero
Quoted: 1740 Post(s)
Liked 1,369 Times in 718 Posts
How about running the Conti Ultra Sport tire in 28c? I use them for all riding and run at 100 psi rear, 90 psi front and find them comfortable and durable. No flats in 2 years and the tires have about 4000 miles on them. Air pressure will affect ride quality as much as thread count and tire construct, which is why I run 90 up front.
Added benefit: Low cost.
TiHabanero is offline
Old 10-19-18, 08:48 PM
Blackie59
When I picked up my Caad12 with 105s, LBS said the Conti 28’s were actually narrower than the 25’s but not to go larger than the 28’s. I’m not going to measure the widths but the Conti’s are very nice and smooth.
Blackie59 is offline
Old 10-20-18, 12:15 AM
Elvo
Quoted: 630 Post(s)
I have GP4000S II 28mm on my road wheelset. They measured 31mm on my 17mm inner width wheelset and now measure 32mm wide on my 22mm inner width wheelset so make sure you have the clearance.
Elvo is offline
Old 10-20-18, 04:23 AM
Campag4life
Voice of the Industry
Campag4life's Avatar
Quoted: 1188 Post(s)
Liked 8 Times in 8 Posts
Tires are largely personal preference OP. Most have their favorites. For example, I have had great luck on Vittoria Rubio Pros with 150TPI. Fast, great puncture resistance, good durability and not too pricey. Great training tire. There are 'slightly' faster tires out there but have other trade offs.
Many believe there is some side wall integrity sacrifice for the rolling resistance of the Conti GP4000's. Many have had issues with side wall blow outs with them. Go out on the web. You don't read about this with Vittoria, or Michelins. I find Michelins also to be great tires but they seem to wear quickly.
So, we each have our favorites.
Conti's aren't harsh...or rather I agree with others that say that is baloney. But, sidewall issues are reported. Many will come to this thread and say, that is baloney as well because they love their Conti's and low rolling resistance for a training clincher.
You will derive a more plush ride by going to 28's, not the brand of tire. If want plushness, actually racing tires roll the softest, but you give up puncture resistance and generally durability as well with softer rubber compound. Racing tires are the fastest of course with their more supple carcass.
No free lunch. I like Vittorias because of the ten's of thousands of miles I have gone on them with relatively low punctures, good durability and a relatively fast and durable training clincher that you can pick up for less than $40/tire.
Campag4life is offline
Old 10-20-18, 05:17 AM
thenewjs
Quoted: 32 Post(s)
Liked 5 Times in 3 Posts
I just put 28 conti's on my 2016 caad12 and there is some rubbage when i get out the saddle and the bike is flexing.
thenewjs is offline
Old 10-20-18, 06:50 AM
rubiksoval
Bikes: bikes
GP4000s measure much wider than their stated width on wider rims. 23 is 26, 25 is 28, etc.
Old 10-20-18, 09:51 AM
surak
surak's Avatar
Quoted: 871 Post(s)
Liked 726 Times in 436 Posts
The Pro4 Es also inflate wider than specified. Still, why change when they're pretty good tires already? Are they worn out?
surak is offline
Old 10-20-18, 09:52 AM
Robert A
Quoted: 559 Post(s)
They're two years old already.
Robert A is offline
Old 10-20-18, 03:33 PM
raria
Quoted: 761 Post(s)
They fit on my CAAD12
Go for it.
they
raria is offline
