Belt driven drivetrain
Psycholist
Bikes: Devinci Amsterdam, Litespeed Teramo
I think this is a picture of the Paragon drops in use:
If you simply must build a belt drive, do yourself a favor and use vertical dropouts with either an EBB or sliding dropout system. Messing around with belt tension and alignment would be a side of the road nightmare; vertical d/o's make wheel replacement real easy.
lube addict
Bikes: Specialized FSR-XC, Optima Baron, Bianchi Pista, Strida 5.0
Does anyone yet sell the new Gates Carbon Drive CDX-CT? This new belt and pulley system seems to be a marked improvement over the current offerings. Just wondering what thoughts there were here.
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Quoted: 474 Post(s)
Liked 204 Times
Sit on ground with one foot on each crank, hold wheel with one hand and push the legs to tension. Use free hand to tighten up axle nut on one side, swap hands, check wheel is straight, tighten other nut. Spin wheel to check. Ride on.
Took me about 5 mins. I'd need to do at least that much messing about with sliding dropouts.
Bikes: Specialized Tarmac Expert, 2002 TREK 520, Schwinn Mesa WINTER BIKE, Huffy Rock Creek 29er, 1970s-era Ross ten speed. All my bikes are highly modified(except the Tarmac) yet functional, and generally look beat to ****. .
Quoted: 68 Post(s)
Liked 88 Times
Not so hard.
I was imagining that a belt drive system on a low speed vehicle like a bicycle could probably be adjusted better by the human eye and hand (feet?) than any tool.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Why notched belts on bicycles? I know it may be a dumb question with a simple answer but ... I understand that those belts are optimal on motorcycles with high torque requirements, but are low hp V belts ever used on bicycles? It seems like alignment, tensioning and slippage would no longer be issues, and bicycles are fractional HP.
Randomhead
Liked 3,696 Times
I don't think a v belt would work well in a bicycle application. There is no room for error or you end up on your face. In fact, it's really hard to beat a chain and if it weren't for Gates wanting to sell into a new market, the timing belts wouldn't be available for bikes either.
Bikes: Nashbar Road
Liked 341 Times
Randomhead
Liked 3,696 Times
a v belt slips when it's loose. They also slip when they aren't loose. Not exactly the kind of thing that I would feel comfortable trusting my teeth to. I will admit to being a bit of a luddite when it comes to bicycle tech. As a class, belts are less efficient than chains in applications like the bicycle.
Quoted: 5 Post(s)
Liked 11 Times
I like the belt concept. Not sold on the practicality. I've broken chains on a ride & fixed them in less than 10 minutes. Break a belt, walk home.
Bikes: Nashbar Road
Liked 341 Times
Hi torque=slip=lower efficiency, pretty much as I suspected. Thanks.
Sorry to derail the thread ... carry on please
Re the hub, I've been using mine on my commuter year round for 5 + years..
just got a second bike with one, a Bike Friday..
no belt drive as the frame folds behind the BB for 20" wheels.
It has a spring tensioner .
It is an option on their 349 wheel bikes as rear section is a unit,
fold is including the BB, hinge ahead of the BB.
IGH dropout swings rearward to tension drive, chain or belt.
Rohloff has drawings to manufacture sliding dropouts ,
their sliding track spec was angled at 20 degrees.
I see that as moving in a direction to not move the brake shoes away from the rim
and the weight of the bike, when one has loosened the bolts,
tensions the drive chain, because the slide has slope,
so perhaps also valid for the belt scheme.
Quoted: 68 Post(s)
Liked 88 Times
Seems like the biggest challenge with belt drive is the continuous belt, and having to split the frame to replace it.
Why not: design a frame with rear stays just wide enough for the internally geared hub; good, strong axle with extension on right side; and belt pulley on the outside of the frame? Slot the dropouts for adjustment? Belt replacement would take seconds...
Liked 13 Times
I've seen a few frames over the years that are set up like that, although all of them were chain drive. It's an attractive concept, but has obviously never caught on. Probably just the fact that it requires a complete redesign of the entire rear end, which will then be incompatible with pretty much anything else ever made...
That's too bad about your District Carbon. I have had nothing but good luck with my District grey/orange, and so I bought a District Carbon to upgrade. It hasn't been on the road yet (I'm upgrading some bits) but I hope I'll have the same experience that I've had thus far, which has been nothing but easy and reliable.
Belt drive in my opinion sucks !!!! may i say NOISE and slippage , bout a 2011 district carbon went to a chain drive & now perfect ( no wonder the chain is well over 100 years old ) Trek was nothing but good in helping me they tried everything and included new everything as far as drivetrain to try to fix it
I've got 2 bikes with belt setups and there are 2 key things that must be tuned correctly:
- The belt line must be absolutely straight. Gates Belts only allows +/- 1mm of variance in alignment between the front and rear sprocket. If the belt line is off, the result is noise. The Center Track is especially sensitive to alignment due to the center spline on the belt.
- Proper tension must be set. The frame must have a way to apply belt tension. You cannot pull it with your hand. You simply cannot create enough tension if there's not a belt tensioner used. Use an instrument to measure the tension.
If the belt is loose, the result is the belt skipping tooth.
The Tout Terrain design seems good , right dropout is 2 pieces
sandwiched together
1 attached to seat stay, other to chainstay ,
so IGH axle holds them together when ready to go.
BB is Front of a Tandem Eccentric. to snug up chain or belt.
sandwiched together
Randomhead
Liked 3,696 Times
this is a really old thread, I'm closing it before things go sour and people start arguing with someone that's no longer around.
