Chinabomb Disc Brake Road Bike Build
Old 03-30-17, 07:54 AM
  #101
rpenmanparker
rpenmanparker's Avatar
Quoted: 6556 Post(s)
Liked 58 Times in 36 Posts
Originally Posted by blazin
Just guessing, but maybe he meant 25mm deep, not 25mm wide?
Oh, yeah. Just guessing, but I think you are right.
Robert
Originally Posted by LAJ
No matter where I go, here I am...
rpenmanparker is offline
Old 03-30-17, 07:57 AM
  #102
blazin
Blazer of saddles, trails
Quoted: 115 Post(s)
Liked 33 Times in 25 Posts
And thus was another BF blood feud avoided. Too bad...
blazin is offline
Old 03-30-17, 07:58 AM
  #103
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
Originally Posted by rpenmanparker
Why would you run 23 mm tires on 25 mm tubular rims? There is no affect on the tire width by the width of a tubular rim like there is with clinchers. You might as well just save the weight and get narrower rims. The aero drag coefficient would be better. Or run 25 mm tires on the 25 mm rims if you want another approach to improved aero effect that provide wider tires. The one thing you don't want is to run smaller tires on wider tubular rims. They would be sitting in the middle of the rim, with some edge exposed. Besides aero I don't know what is wrong with that, but it must be something.
Current rims are 40mm deep (27mm wide) and ~405 grams. I have seen 25mm deep (~22mm wide) rims advertised at 260-280 grams. As you say, I would not use narrow tubulars on wide rims aside from briefly mounting a skinny spare to get home.
joejack951 is offline
  #104
rpenmanparker
Indeed.
Robert
Old 03-30-17, 10:56 AM
  #105
Maelochs
Maelochs's Avatar
Quoted: 7649 Post(s)
Liked 3,465 Times in 1,831 Posts
You guys give up too easily ...
We just lost four pages of drama so you guys could act like rational adults.
I hope it's worth it to you.
Maelochs is offline
Old 03-30-17, 11:26 AM
  #106
joejack951
joejack951's Avatar
Originally Posted by Maelochs
That works. The curtains accent the gumwwalls.
Looks great .... but the amount of mechanical fiddling that went into it puts it beyond me. But it looks real good.
Thanks! Ironically, those 'curtains' are a photo backdrop that I was too lazy to pull out.
Most of the fiddling was my own doing. A Shimano group on the same frame would be very straightforward. Campy and TRP, not so much.
Originally Posted by zymphad
That looks awesome. How is Chorus? Damn looks fast.
Thanks! I have about 0.1 miles on the bike so can't really comment on using Chorus other than shifting it on the stand. I agree it looks fast. I need to work on the engine to match.
Old 03-30-17, 11:31 AM
  #107
rpenmanparker
Mine are 20 mm deep at that weight...I think.
Robert
Old 03-30-17, 11:38 AM
  #108
joejack951
joejack951's Avatar
There are a lot of options but here is one 25mm deep x 23mm wide quoted at 250 grams: 25mmx23mm tubular - Far Sports
The lack of a braking surface may be why they are lighter than yours even for a larger profile. Or the claim is just that and they really weigh 25 grams each more. Regardless, much lighter than my 40mm rims and good for half a pound off the bike.
Old 03-31-17, 10:50 AM
  #109
joejack951
joejack951's Avatar
Final build was as follows:
frame/fork: Hongfu FM-079-F w/ BB30
rims: Hongfu 40mm carbon tubular, 25mm wide, no brake track
tires: Vittoria Corsa G+ Isotech tubular, 25mm with Mastik One, Continental valve extenders
Brakes: TRP HY/RD Flat Mount, custom arms for Campagnolo levers
Rotors: Shimano ICE tech Freeza 160 front, 140 rear
front hub: Bitex BX106F centerlock 24H, 15mm thru, white!
front thru axle: Rock Shox Maxle, 15x100 (125mm overall length)
rear hub: Bitex BX106R Centerlock 28H 12mm thru, Campy, white!
Rear thru axle: Ibis Hexle Boost 148, 12mm x 171mm overall
Rear axle nut: Shimano e-thru nut (milled down a bit for more thread engagement)
Spokes: Sapim CX-Ray, black
Nipples: Sapim 12mm
Groupset: Campy Chorus, 50/34 crank, 12/29 cassette
Cable housing: Yokozuna Reaction, white
Pedals: Shimano Ultegra 6800
Saddle: Fizik Arione R1, white
Seatpost: Ritchey Superlogic UD Carbon
Handlebars: Ritchey WCS Streem II, 40cm
Stem: Ritchey WCS C260 110mm
Bar Tape: Fizik Classic, white
Weight as pictured above: 16.65 lbs./7.57 kg
Old 04-03-17, 01:27 PM
  #110
joejack951
joejack951's Avatar
Standard drive side shot (yes, I know, my cranks moved a bit):
Aero handlebars and those shiny white hubs:
Business end. Derailleur housing runs all the way to the bottom bracket cable guide. Hongfu provided a short noodle which looked like it might have allowed me to only use housing from the dropout exit point to the derailleur but I didn't trust what the cable might be rubbing on internally. Hongfu provided a crappy fitting grommet to use at the dropout exit point in lieu of the noodle which I needed to trim to fit even close to nicely (ugliness hidden in this pic):
Front TRP HY/RD Flat Mount caliper with custom arm sort of showing awkward housing entry into caliper:
Campy stuff is P R E T T Y pretty
Front TRP HY/RD Flat Mount caliper with custom arm again sort of showing awkward housing entry into caliper, also Rockshox Maxle:
Rear TRP HY/RD Flat Mount caliper with custom arm sort of showing awkward housing entry into caliper, also Ibis Hexle:
Flush cut fork with custom steerer reinforcement piece, no top cap:
Old 04-03-17, 01:46 PM
  #111
Maelochs
Maelochs's Avatar
Yup.
Maelochs is offline
Old 04-05-17, 08:01 AM
  #112
Fiery
Fiery's Avatar
Quoted: 242 Post(s)
Liked 18 Times in 13 Posts
Wide rims are more aero than narrow rims (at least in some conditions), but wide tires are most definitely not more aero than narrow tires, even when used on wide rims. For best aerodynamics, you want the brake tracks to be wider than the tire. This is why Zipp recommends using a 23 mm tire with their Firecrest rims for best aero performance.
The numerous other reasons for not having narrow tires on wide rims still stand, of course.
Fiery is offline
Old 04-05-17, 10:31 AM
  #113
zymphad
Bikes: Super Cheap gc3 approved Bike
Quoted: 572 Post(s)
Liked 52 Times in 30 Posts
Eh... If I had a 25mm wide rims, I'd use 25mm tires. The aero difference for my riding ability would be negligible, but the ride feel and comfort would not be.
zymphad is offline
Old 04-05-17, 01:35 PM
  #114
joejack951
joejack951's Avatar
The bike pictured has 25mm tires and these rims (tubular version):
Old 04-05-17, 03:21 PM
  #115
rpenmanparker
We've pretty well established he meant 25 mm deep, not wide.
Robert
Old 04-05-17, 03:59 PM
  #116
zymphad
Quoted: 572 Post(s)
I thought he clarified it's 40mm deep, 25mm wide.
zymphad is offline
Old 04-05-17, 04:07 PM
  #117
rpenmanparker
Whoops. I missed that. Sorry.
Robert
Old 04-05-17, 04:08 PM
  #118
rpenmanparker
Why do you need that custom steerer piece? Why not just remove the cap after the stem is tightened.
Robert
Old 04-05-17, 04:41 PM
  #119
Maelochs
Maelochs's Avatar
What's up with that steerer-tube reinforcement? Is it simply a XF tube wedged down the steerer to reinforce it> I like the idea a lot. (Rathe,r I hated the weight of an expander, but the only one which didn't weigh a ton was pretty pricey on a gram/dollar scale.)
Maelochs is offline
Old 04-05-17, 06:59 PM
  #120
joejack951
joejack951's Avatar
Currently, yes. When I mentioned using '25mm' rims as a weight savings measure down the road (which was the comment initially misunderstood by Robert), I was referring to 25mm deep rims. Just so we're all clear, not that it matters.
Old 04-05-17, 07:29 PM
  #121
joejack951
joejack951's Avatar
Need? Maybe not, but maybe. Hongfu provided a compression device with my fork that fits a full 38mm into the steerer tube. The impression that gave me is that they intend for the steerer tube to be fully supported in the clamp zone of the stem. It seems nearly every carbon fiber fork manufacturer expects a compression device to be used, too, so the idea of not using anything in the ID, or even one of the minimali$$$t expanders didn't sit well with me. But, the provided device weighs a ton (60 grams, or nearly 60% of the weight of the stem on my bike!) and I'm not guaranteed that it won't slip.
It's also an idea I've been kicking around in my head for years after two bad experiences with expanders, both of which had to be torqued just right not to slip but not too much so that they deformed the steerer tube. I won't lie that I got the idea from Aplha Q (I believe) who used to provide a simple sleeve and star nut with their forks, where the sleeve would be epoxied to the fork ID and the star nut driven in like it would be on a metal steerer.
Not sure what a 'XF tube' is but it is a custom piece sized for a tight slip fit in the steerer tube and bonded in place with Loctite 648, not something I found that happened to fit. Here's a cross section of the part:
Nominal wall is 1mm to keep the weight down (18 grams on my scale) and there are M6 threads in the thick section to work with your typical headset cap.
My initial design goals of this piece were:
1. provide a non-slip means of adjusting bearing preload
2. reinforce stem clamping zone
3. further reinforce steerer tube at the upper headset bearing (hence the 60mm total length, enough to get below the upper bearing with my slammed stem)
4. simple installation (hence the lip at the top to prevent pushing it in too far)
I didn't initially intend to run this part without a top cap (I would have made some changes, and plan to in the future, for a cleaner final appearance assuming there is interest and I make more) but figured why not. I think it looks good enough as-is and I saw no reason to leave any protruding steerer tube above the stem given this solid reinforcement. I have the tapped hole plugged with a short plastic screw to keep water out.
Old 04-05-17, 07:38 PM
  #122
Maelochs
Maelochs's Avatar
Machined it out of what?
I agree, the tube is designed to keep the stem from crushing the fork, and is needed---which is why I went with the disgustingly heavy compression cap, rather than collapsing my steerer while trying to turn.
Maelochs is offline
Old 04-05-17, 07:48 PM
  #123
joejack951
joejack951's Avatar
6061-T6 aluminum, anodized black.
I'm more concerned about repeated stress from me pulling/pushing on the handlebars and, less so, the annoyance of having headset play develop, but the result of a fork failure for any reason would be similarly bad.
Old 04-05-17, 09:20 PM
  #124
rpenmanparker
I'm completely satisfied with my Carbon-Ti expander that weighs 14 g. Support for the steerer seems to be fine. I still don't understand why you don't use a cap. How does a screw keep the water out?
Robert
Old 04-05-17, 10:03 PM
  #125
joejack951
joejack951's Avatar
If I reduce the height of my part down to 40mm from 60 to only support just the stem clamp area (which is more support than the Carbon-Ti unit offers) it would weigh 14 grams, too.
I don't use a cap because 1. I don't need one and 2. 4 grams is 4 grams and 3. I'm so vane that any benefits of using a cap are negated instantly by how ugly my stem area would look with the added height of a spacer and cap.
The screw/plug keeps water from getting down into the fork. Water can still collect in the depression in the top of my part. Had I originally planned to not use a cap I would have made that whole top surface flush, and will do so on any additional parts I produce.
