New Tiagra 4700 compatibility with 11s Shimano parts
I have been reading BikeForums for a long time but never had a reason to join, but I was very curious on this question, so after finding this thread, I decided to find out for myself since it looks like no one else has tried yet. I work in a shop that sells Trek and we carry the Emonda ALR 4 (which comes stock with the full Tiagra 4700 grouppo). So I pulled the bike into the stand and installed a 6800 derailleur and it works! Beautifully! Even though I was using the Tiagra shifters, chain, and cassette, the Ultegra derailleur shifted quite a bit cleaner than the stock 4700 derailleur did. For the first time in a long time, as a mechanic, I am super happy about something Shimano changed! I have pictures and video on my phone that I'll upload and post here when I get home from work.
L-I-V-I-N
I have not tried it. TRi_Crinale did.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I wonder what this will mean for the future, if Tiagra will be a weird 10-speed not-SIS orphan, or if the new geometry will move down to 9x Sora, or some other alternative. The most recent lower MTB groups (M4000 and M3000) did not go 10x Dyna-Sys, they are both still 9x SIS.
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,102 Times
https://www.amazon.com/Shimano-M772-S...himano+rd-m772
Genesis 49:16-17
Genesis 49:16-17
Bikes: Stevens Super Prestige CX, 2005 Bianchi Cross Concept, 2000 Breezer Venturi, Bianchi's: Project 7 (&5 &3), 2005 & 2002 Volpe, 2007 San Jose, 1990 Boardwalk semi-mixte, 2005 Eros; 1996 Cannondale M300 A-frame, Schwinn 2010 Tourist
Quoted: 7 Post(s)
Liked 5 Times
This is just like the pre-4700 world where an Ultegra 10-speed rear derailleur works with 8-speed shifters, and 8-speed rear derailleur works with pre-4700 road 10-speed shifters (and MTB 9-speed shifters). But based on how you've expressed it, these wouldn't work.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I wrote a series of articles on my blog about compatibility and mix-matching:
Compatibility Archives - Cycle Gremlin
Brake compatibility is up next, when I get the time.
And, yes, 4700 RD has the same pull ratio as 11 speed Shimano road RDs. That means it will work with any 11 speed Shimano shifter, and with 4700 shifters - old 10 speed shifters will not pull enough cable for it to work. Of course, if using 4700 shifters, only 10 speed cassettes will do, while 11 speed shifters will work fine with 10 speed cassettes.
4700 shifters will work with 10 speed cassettes and 4700 RDs, as well as any Shimano road 11 speed RD.
If shifter number of speeds does not match the cassette number of speeds, alternate cable routing can help, but the more speeds, the more tightly spaced cogs, the less likely it is to work well.
How does Dyna-Sys fit into all this. Do the Dyna-Sys RD's have the same cable pull as 4700/5800 etc. shifters, like it was with the older 9/10 speed road groups and 9 speed MTB RDs?
And are the FDs still incompatible between mountain and road, like they were before?
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
Wolf Tooth makes an adapter that lets you use a Dyna-Sys RD with 11-speed Shimano STI's. Gevenalle makes brake/shift levers for drop bars that work directly with Dyna-Sys RDs. I'm using the latter on one of my bikes with a Deore 615 Shadow Plus RD, and it's been working flawlessly.
My Bikes
My Bikes
Ahh, too bad. I was hoping Shimano would re-establish the old status quo of being able to interchange road and mountain RDs.
The Gevenalle stuff looks very nice though. I really like that you can get them with linear pull levers for V brakes and MTB disc brakes. They even have hydraulic levers (though I don't remember what system they're compatible with).
[QUOTE=dtrain;18393909]Yes, I understand that's true nearly across the board. But I think the new 4700 is now the exception. It uses ratios that more closely match the redesigned (11 speed) stuff; FD for example. So it's more likely to work with 5800 than 5700. The rear shifting is the larger mystery: likely a different cable pull from older 10 speed groups (like CafeVelo says)...but still 10 speed spacing which is different than 11.
Sounds like if I were to consider this, running a 4700 RD would be a safer bet.[/QUOT
I believe you are correct. Tiara uses the same actuation ratio as the 11 speed groups. It just shifts one less cog.
Quoted: 5 Post(s)
Can someone confirm that the Tiagra 4700 series cassettes (CS-HG500-10) are interchangeable with prior road/MTB Shimano 10-speed cassettes (CS-HG62-10 etc)?
Edit: also: are the new cassettes on spiders, or can the individual cogs be removed?
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Quoted: 7 Post(s)
Liked 5 Times
It is the best 10-speed shifting I've experienced.
As has been said, the rear cable pull ratio of the ST-4700 and RD-4700 now match that of the Dura-Ace/Ultegra/105 11-speed mechanical groupos. Thus you can mix and match them. You could also use a ST-6800 and RD-4700 long cage.
RD-4700 GS with ST-5800/6800
Quoted: 7 Post(s)
Liked 5 Times
Bikes: Road/Race: 2012 Breezer Venturi; Trail: 2016 Scott Scale 720 Plus
Quoted: 12 Post(s)
This is all pretty interesting; based on what all of you are saying, there is a distinct possibility that the new RD-8000 long cage, which is rated up to 34T (to match the new CS-HG800 11-34 cassette), is basically an Ultegra-fied RD-4700 long cage. Hmm...
-Ed
-Ed
4700 shifters along with 11sp RD and 11sp cassette
Hello to all.
I know it's an old thread, but I just registered because I read some very nice compatibility specs but I'm not sure for some others not mentioned.
My bike has a full 4700 tiagra groupset, except from TRP Spyre-C mechanical disc brakes. I'm really happy with the whole Tiagra groupset but not with the brakes so I'm thinking changing to hydraulic.
Since I need at least to buy new hydraulic shifters and disc calipers, I'm also thinking on upgrading some parts of the groupset, so spending some cash in phases.
Just to make that clearer:
I was thinking to buy 105 (R7000) or Ultegra (R8000) shifters and calipers, and not the 4700. So to my first question that I believe I will have a positive answer:
1. Will the R7000 or R8000 shifters work with 4700 FD and RD, along with the current 10sp 11-32 CS-HG500 cassette?
If I don't upgrade the shifters now:
2. Will the Tiagra 4700 shifters handle an 105 (R7000) RD (or Ultegra R8000 RD) with an 11sp 11-34 CS-HG700-11 cassette. If not, that means that the 4700 shifters are locked to 10sp changes and not 11sp, since the cable pull ratio is the same on 4700, R7000, R8000 shifters when used with 4700, R7000, R8000 RDs. Please do not answer this just theoritical, I would like to have an answer from someone tested or using it, like
I know that they can handle an 105 (R7000) RD with 10sp 11-32 or 11-34 CS-HG500 cassette, but I'm happy with Tiagra mechs on the current bike and the only reason I would go for the upgrade is the 11sp cassette, so I don't need any other RD on my current 4700 if 11sp cassette cannot be applied.
Quoted: 6178 Post(s)
Liked 4,795 Times
keyboardologist Second dead thread you've dredged up. By the time others read down to what is a new question, there might be some confusion as to what the discussion really is.
Please, in the future, just start your own new topic. If another thread is pertinent, then just link it.
Anyhow.... #2 . No, I answered that in the other zombie thread you dug up.
Welcome to BF!
Welcome to BF!
I got some new pads and nice tuning and seems to work well and also get some good bite, but nothing special or close to a good set of 105 rim brake calipers tested on a dry day.
I hope tiagra hydraulic are like 105 rim brakes or better comparing with the power effort. It's not that the Spyres can't 'lock' the wheels or stop the bike, but you need some extra hand power effort that I cannot apply when riding on-top of the bars, specially with my weak left-hand.
Welcome to BF!
Welcome to BF!
So if I want to upgrade to 11sp, I will have to start now with 11-sp shifters...
I really don't like creating new threads for the same topics, I believe that the title 'new Tiagra 4700 compatibility with 11s Shimano parts' is a superset of my question.
Liked 4,795 Times
For some types of very specialized forums, that might be the norm. But this is a pretty high volume site and old with many long threads. I and others certainly don't want to hash through the potential 100's of response to the OP before getting to yours. And IMO, any thread with 5 or more answers is already ripe for going off topic. And using the OP's thread is considered by me and other as hijacking. Even if it's a similar issue. Though I admit I've hijacked very new threads in the past. But not Zombie threads.
Besides, your questions are very cut and dried. There is no supporting conversation needed to understand your questions.
